[petsc-users] GPUs and the float-double dilemma
    Matthew Knepley
    knepley at gmail.com
    Fri Feb 10 10:50:51 CST 2023
On Fri, Feb 10, 2023 at 11:31 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> On Fri, Feb 10, 2023 at 8:16 AM Ces VLC <cesarillovlc at gmail.com> wrote:
>> Hi!
>> I searched if it’s supported to link an application to two different
>> builds of PETSc (one configured as float precision, and the other as
>> double). The last post I found on that topic was from 2016 and it said it’s
>> not recommended.
>> The point is that if you wish to prepare builds of your application for
>> end-users, and if your app offers the option of using GPUs, you have a
>> critical problem if you cannot link with two different PETSc builds in the
>> same executable: either you don’t provide support for most GPUs (as they
>> are float only), or you force float precision even when using the CPU. A
>> third option (shipping two executables for the app) is not practical, as
>> the user won’t be able to compare results without quitting the app and
>> running the other version.
> Why do you say most GPUs are float only?  I do not have a survey but the
> NVIDIA, AMD, Intel GPUs I have access to all support double :)
>> Has the situation changed since 2016, now that GPU support is being added
>> to PETSc?
>> An obvious solution would be if PETSc could be built prepending a prefix
>> to all symbols (functions, structs, types, everything).
> Sounds like a bomb
>> Any advances, plans, or thoughts on this?
> Interfacing petsc with libraries (e.g.,Gingko) that support
> mixed-precision could be an approach. But we have not tried that yet.
The datatype on device need not match the datatype on the CPU. This is how
I prefer to do things, running float on device and double on the CPU. This
is possible now I think.
   Matt
>> Thanks!
>> César
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230210/c9b27e74/attachment-0001.html>
