[petsc-users] Eliminating rows and columns which are zeros
Barry Smith
bsmith at petsc.dev
Tue Feb 7 13:52:00 CST 2023
> On Feb 7, 2023, at 1:20 PM, Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Thank you Barry for your detailed response.
> I would like to shed some light into what I try to accomplish using PETSc and AMReX. Please see the attachment adaptive mesh image (and ignore the mesh-order legend for now).
> The number of elements on each level is a geometric progression.
> N - Number elements on each level indexed by ‘n’
> n - Adaptive mesh level index (starting from 1)
> a - Number of elements on the base mesh = 16
> r = 4 (each element is divided into four on the next higher level of refinement)
> N = a r^(n-1)
> The final solution u, is the super imposition of solutions from all levels (here we have a total of 7 levels).
> u = u^(1) + u^(2) + … + u^(7)
> Hence I have seven system matrix and solution vector pairs, one for each level.
> On each level the element index vary from 1 to N. But on each level NOT all elements are ‘active’.
> As you can see from the attached image not all elements are active (a lot of white hollow spaces). So the ‘active’ indexes can be scatted anywhere between 1 to N = 65536 for n = 7.
> (Q1) In my case, I can’t at the moment insert 1 on the diagonal because during assembly I am using ADD_VALUES as a node can be common to many elements. So I added 0.0 to ALL diagonals. After global assembly, I find that the linear solver converges.
> (Q2) After adding 0.0 to all diagonal. I able to solve using either
> ierr = PetscOptionsSetValue(NULL,"-redistribute_pc_type", "jacobi"); CHKERRQ(ierr);
> or
> ierr = PetscOptionsSetValue(NULL," pc_type", "jacobi"); CHKERRQ(ierr);
> I was able to solve using hypre as well.
> Do I need to use -pc_type redistribute or not? Because I am able to solve without it as well.
No you do not need redistribute, but for large problems with many empty rows using a solver inside redistribute will be faster than just using that solver directly on the much larger (mostly empty) system.
> (Q3) I am sorry, if I sound like a broken record player. On each level I request allocation for A[N][N]
Not sure what you mean by this? Call MatMPIAIJSetPreallocation(... N,NULL); where N is the number of columns in the matrix?
If so, yes this causes a huge malloc() by PETSc when it allocates the matrix. It is not scalable. Do you have a small upper bound on the number of nonzeros in a row, say 9 or 27? Then use that instead of N, not perfect but much better than N.
Barry
> as the indexes can be scatted anywhere between 1 to N but most are ‘inactive rows’. Is -pc_type redistribute the way to go for me to save on memory? Though I request A[N][N] allocation, and not all rows are active - I wonder if I am wasting a huge amount of memory?
> Kind regards,
> Karthik.
> From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Date: Monday, 6 February 2023 at 22:42
> To: Chockalingam, Karthikeyan (STFC,DL,HC) <karthikeyan.chockalingam at stfc.ac.uk <mailto:karthikeyan.chockalingam at stfc.ac.uk>>
> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: Re: [petsc-users] Eliminating rows and columns which are zeros
> Sorry was not clear MatZero*. I just meant MatZeroRows() or MatZeroRowsColumns()
> On Feb 6, 2023, at 4:45 PM, Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk <mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
> No problem. I don’t completely follow.
> (Q1) I have used MATMPIAJI but not sure what is MatZero* (star) and what it does? And its relevance to my problem.
> (Q2) Since I am creating a MATMPIAJI system– what would be the best way to insert 0.0 in to ALL diagonals (both active and inactive rows) to begin with?
> Yes, just have each MPI process loop over its rows and put zero on the diagonal (actually, you could put a 1 if you want). Then have your code use AMReX to
> put all its values in, I am assuming the code uses INSERT_VALUES so it will always overwrite the value you put in initially (hence putting in 1 initially will be fine; the advantage of 1 is if you do not use PCREDISTIBUTE the matrix is fully defined and so any solver will work. If you know the inactive rows you can just put the diagonal on those since AMReX will fill up the rest of the rows, but it is harmless to put values on all diagonal entries. Do NOT call MatAssemblyBegin/End between filling the diagonal entries and having AMReX put in its values.
> (Q3) If I have to insert 0.0 only into diagonals of “inactive” rows after I have put values into the matrix would be an effort. Unless there is a straight forward to do it in PETSc.
> (Q4) For my problem do I need to use PCREDISTIBUTE or any linear solve would eliminate those rows?
> Well no solver will really make sense if you have "inactive" rows, that is rows with nothing in them except PCREDISTIBUTE.
> When PETSc was written we didn't understand having lots of completely empty rows was a use case so much of the functionality does not work in that case.
> Best,
> Karthik.
> Date: Monday, 6 February 2023 at 20:18
> Sorry, I had a mistake in my thinking, PCREDISTRIBUTE supports completely empty rows but MatZero* does not.
> When you put values into the matrix you will need to insert a 0.0 on the diagonal of each "inactive" row; all of this will be eliminated during the linear solve process. It would be a major project to change the MatZero* functions to handle empty rows.
> Barry
> On Feb 4, 2023, at 12:06 PM, Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk <mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
> Thank you very much for offering to debug.
> I built PETSc along with AMReX, so I tried to extract the PETSc code alone which would reproduce the same error on the smallest sized problem possible.
> I have attached three files:
> petsc_amrex_error_redistribute.txt – The error message from amrex/petsc interface, but THE linear system solves and converges to a solution.
> problem.c – A simple stand-alone petsc code, which produces almost the same error message.
> petsc_ error_redistribute.txt – The error message from problem.c but strangely it does NOT solve – I am not sure why?
> Please use problem.c to debug the issue.
> Kind regards,
> Karthik.
> Date: Saturday, 4 February 2023 at 00:22
> If you can help me reproduce the problem with a simple code I can debug the problem and fix it.
> Barry
> On Feb 3, 2023, at 6:42 PM, Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk <mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
> I updated the main branch to the below commit but the same problem persists.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.18.4-529-g995ec06f92 GIT Date: 2023-02-03 18:41:48 +0000
> Date: Friday, 3 February 2023 at 18:51
> If you switch to use the main branch of petsc https://petsc.org/release/install/download/#advanced-obtain-petsc-development-version-with-git you will not have the problem below (previously we required that a row exist before we zeroed it but now we allow the row to initially have no entries and still be zeroed.
> Barry
> On Feb 3, 2023, at 1:04 PM, Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk <mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
> Thank you. The entire error output was an attachment in my previous email. I am pasting here for your reference.
> [1;31m[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0;39m[0;49m[0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Matrix is missing diagonal entry in row 0 (65792)
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could be the program crashed before they were used or a spelling mistake, etc!
> [0]PETSC ERROR: Option left: name:-options_left (no value)
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.18.1-127-ga207d08eda GIT Date: 2022-10-30 11:03:25 -0500
> [0]PETSC ERROR: /Users/karthikeyan.chockalingam/AMReX/amrFEM/build/Debug/amrFEM on a named HC20210312 by karthikeyan.chockalingam Fri Feb 3 11:10:01 2023
> [0]PETSC ERROR: Configure options --with-debugging=0 --prefix=/Users/karthikeyan.chockalingam/AMReX/petsc --download-fblaslapack=yes --download-scalapack=yes --download-mumps=yes --with-hypre-dir=/Users/karthikeyan.chockalingam/AMReX/hypre/src/hypre
> [0]PETSC ERROR: #1 MatZeroRowsColumns_SeqAIJ() at /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/impls/aij/seq/aij.c:2218
> [0]PETSC ERROR: #2 MatZeroRowsColumns() at /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/interface/matrix.c:6085
> [0]PETSC ERROR: #3 MatZeroRowsColumns_MPIAIJ() at /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/impls/aij/mpi/mpiaij.c:879
> [0]PETSC ERROR: #4 MatZeroRowsColumns() at /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/interface/matrix.c:6085
> [0]PETSC ERROR: #5 MatZeroRowsColumnsIS() at /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/interface/matrix.c:6124
> [0]PETSC ERROR: #6 localAssembly() at /Users/karthikeyan.chockalingam/AMReX/amrFEM/src/FENodalPoisson.cpp:435
> Residual norms for redistribute_ solve.
> 0 KSP preconditioned resid norm 5.182603110407e+00 true resid norm 1.382027496109e+01 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 1.862430383976e+00 true resid norm 4.966481023937e+00 ||r(i)||/||b|| 3.593619546588e-01
> 2 KSP preconditioned resid norm 2.132803507689e-01 true resid norm 5.687476020503e-01 ||r(i)||/||b|| 4.115313216645e-02
> 3 KSP preconditioned resid norm 5.499797533437e-02 true resid norm 1.466612675583e-01 ||r(i)||/||b|| 1.061203687852e-02
> 4 KSP preconditioned resid norm 2.829814271435e-02 true resid norm 7.546171390493e-02 ||r(i)||/||b|| 5.460217985345e-03
> 5 KSP preconditioned resid norm 7.431048995318e-03 true resid norm 1.981613065418e-02 ||r(i)||/||b|| 1.433844891652e-03
> 6 KSP preconditioned resid norm 3.182040728972e-03 true resid norm 8.485441943932e-03 ||r(i)||/||b|| 6.139850305312e-04
> 7 KSP preconditioned resid norm 1.030867020459e-03 true resid norm 2.748978721225e-03 ||r(i)||/||b|| 1.989091193167e-04
> 8 KSP preconditioned resid norm 4.469429300003e-04 true resid norm 1.191847813335e-03 ||r(i)||/||b|| 8.623908111021e-05
> 9 KSP preconditioned resid norm 1.237303313796e-04 true resid norm 3.299475503456e-04 ||r(i)||/||b|| 2.387416685085e-05
> 10 KSP preconditioned resid norm 5.822094326756e-05 true resid norm 1.552558487134e-04 ||r(i)||/||b|| 1.123391894522e-05
> 11 KSP preconditioned resid norm 1.735776150969e-05 true resid norm 4.628736402585e-05 ||r(i)||/||b|| 3.349236115503e-06
> Linear redistribute_ solve converged due to CONVERGED_RTOL iterations 11
> KSP Object: (redistribute_) 1 MPI process
> type: cg
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object: (redistribute_) 1 MPI process
> type: jacobi
> type DIAGONAL
> linear system matrix = precond matrix:
> Mat Object: 1 MPI process
> type: mpiaij
> rows=48896, cols=48896
> total: nonzeros=307976, allocated nonzeros=307976
> total number of mallocs used during MatSetValues calls=0
> not using I-node (on process 0) routines
> End of program
> solve time 0.564714744 seconds
> Starting max value is: 0
> Min value of level 0 is: 0
> Interpolated min value is: 741.978761
> Unused ParmParse Variables:
> [TOP]::model.type(nvals = 1) :: [3]
> [TOP]::ref_ratio(nvals = 1) :: [2]
> AMReX (22.10-20-g3082028e4287) finalized
> #PETSc Option Table entries:
> -ksp_type preonly
> -options_left
> -redistribute_ksp_converged_reason
> -redistribute_ksp_monitor_true_residual
> -redistribute_ksp_type cg
> -redistribute_ksp_view
> -redistribute_pc_type jacobi
> #End of PETSc Option Table entries
> There are no unused options.
> Program ended with exit code: 0
> Best,
> Karthik.
> Date: Friday, 3 February 2023 at 17:41
> We need all the error output for the errors you got below to understand why the errors are happening.
> On Feb 3, 2023, at 11:41 AM, Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk <mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
> Hello Barry,
> I would like to better understand pc_type redistribute usage.
> I am plan to use pc_type redistribute in the context of adaptive mesh refinement on a structured grid in 2D. My base mesh (level 0) is indexed from 0 to N-1 elements and refined mesh (level 1) is indexed from 0 to 4(N-1) elements. When I construct system matrix A on (level 1); I probably only use 20% of 4(N-1) elements, however the indexes are scattered in the range of 0 to 4(N-1). That leaves 80% of the rows and columns of the system matrix A on (level 1) to be zero. From your earlier response, I believe this would be a use case for petsc_type redistribute.
> Indeed the linear solve will be more efficient if you use the redistribute solver.
> But I don't understand your plan. With adaptive refinement I would just create the two matrices, one for the initial grid on which you solve the system, this will be a smaller matrix and then create a new larger matrix for the refined grid (and discard the previous matrix).
> Question (1)
> If N is really large, I would have to allocate memory of size 4(N-1) for the system matrix A on (level 1). How does pc_type redistribute help? Because, I did end up allocating memory for a large system, where most of the rows and columns are zeros. Is most of the allotted memory not wasted? Is this the correct usage?
> See above
> Question (2)
> I tried using pc_type redistribute for a two level system.
> I have attached the output only for (level 1)
> The solution converges to right solution but still petsc outputs some error messages.
> But the there were no unused options
> -ksp_type preonly
> -options_left
> I cannot explain this
> Question (2)
> What does this error message imply? Given I only use 20% of 4(N-1) indexes, I can imagine most of the diagonal entrees are zero. Is my understanding correct?
> Question (3)
> I am using MatZeroRowsColumnsIS to set the homogenous Dirichelet boundary. I don’t follow why I get this error message as the linear system converges to the right solution.
> Thank you for your help.
> Kind regards,
> Karthik.
> Date: Tuesday, 10 January 2023 at 18:50
> Yes, after the solve the x will contain correct values for ALL the locations including the (zeroed out rows). You use case is exactly what redistribute it for.
> Barry
> On Jan 10, 2023, at 11:25 AM, Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk <mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
> Thank you Barry. This is great!
> I plan to solve using ‘-pc_type redistribute’ after applying the Dirichlet bc using
> MatZeroRowsColumnsIS(A, isout, 1, x, b);
> While I retrieve the solution data from x (after the solve) – can I index them using the original ordering (if I may say that)?
> Kind regards,
> Karthik.
> Date: Tuesday, 10 January 2023 at 16:04
> https://petsc.org/release/docs/manualpages/PC/PCREDISTRIBUTE/#pcredistribute -pc_type redistribute
> It does everything for you. Note that if the right hand side for any of the "zero" rows is nonzero then the system is inconsistent and the system does not have a solution.
> Barry
> On Jan 10, 2023, at 10:30 AM, Karthikeyan Chockalingam - STFC UKRI via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Hello,
> I am assembling a MATIJ of size N, where a very large number of rows (and corresponding columns), are zeros. I would like to potentially eliminate them before the solve.
> For instance say N=7
> 0 0 0 0 0 0 0
> 0 1 -1 0 0 0 0
> 0 -1 2 0 0 0 -1
> 0 0 0 0 0 0 0
> 0 0 0 0 0 0 0
> 0 0 0 0 0 0 0
> 0 0 -1 0 0 0 1
> I would like to reduce it to a 3x3
> 1 -1 0
> -1 2 -1
> 0 -1 1
> I do know the size N.
> Q1) How do I do it?
> Q2) Is it better to eliminate them as it would save a lot of memory?
> Q3) At the moment, I don’t know which rows (and columns) have the zero entries but with some effort I probably can find them. Should I know which rows (and columns) I am eliminating?
> Thank you.
> Karthik.
> This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
> <petsc_redistribute.txt>
> <petsc_error_redistribute.txt><petsc_amrex_error_redistribute.txt><problem.c>
> <adaptive_mesh_level.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230207/a3a912f6/attachment-0001.html>
