[petsc-users] Eliminating rows and columns which are zeros
Fri Feb 3 12:35:28 CST 2023
On Fri, Feb 3, 2023 at 1:05 PM Karthikeyan Chockalingam - STFC UKRI via
petsc-users <petsc-users at mcs.anl.gov> wrote:
> Thank you. The entire error output was an attachment in my previous email.
> I am pasting here for your reference.
The options "-options_left" does not take effect until PetscFinalize(), but
your program crashed before that ran, so it comes up as
not used in the error message, but then it runs and it is used.
The main problem is that you have not preallocated the matrix to match your
input.
    Matt
> [1;31m[0]PETSC ERROR: --------------------- Error Message
> [0;39m[0;49m[0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Matrix is missing diagonal entry in row 0 (65792)
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> be the program crashed before they were used or a spelling mistake, etc!
> [0]PETSC ERROR: Option left: name:-options_left (no value)
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.18.1-127-ga207d08eda
> GIT Date: 2022-10-30 11:03:25 -0500
> [0]PETSC ERROR:
> /Users/karthikeyan.chockalingam/AMReX/amrFEM/build/Debug/amrFEM on a  named
> HC20210312 by karthikeyan.chockalingam Fri Feb  3 11:10:01 2023
> [0]PETSC ERROR: Configure options --with-debugging=0
> --prefix=/Users/karthikeyan.chockalingam/AMReX/petsc
> --download-fblaslapack=yes --download-scalapack=yes --download-mumps=yes
> --with-hypre-dir=/Users/karthikeyan.chockalingam/AMReX/hypre/src/hypre
> [0]PETSC ERROR: #1 MatZeroRowsColumns_SeqAIJ() at
> /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/impls/aij/seq/aij.c:2218
> [0]PETSC ERROR: #2 MatZeroRowsColumns() at
> /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/interface/matrix.c:6085
> [0]PETSC ERROR: #3 MatZeroRowsColumns_MPIAIJ() at
> /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/impls/aij/mpi/mpiaij.c:879
> [0]PETSC ERROR: #4 MatZeroRowsColumns() at
> [0]PETSC ERROR: #5 MatZeroRowsColumnsIS() at
> /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/interface/matrix.c:6124
> [0]PETSC ERROR: #6 localAssembly() at
> /Users/karthikeyan.chockalingam/AMReX/amrFEM/src/FENodalPoisson.cpp:435
>     Residual norms for redistribute_ solve.
>     0 KSP preconditioned resid norm 5.182603110407e+00 true resid norm
> 1.382027496109e+01 ||r(i)||/||b|| 1.000000000000e+00
>     1 KSP preconditioned resid norm 1.862430383976e+00 true resid norm
> 4.966481023937e+00 ||r(i)||/||b|| 3.593619546588e-01
>     2 KSP preconditioned resid norm 2.132803507689e-01 true resid norm
> 5.687476020503e-01 ||r(i)||/||b|| 4.115313216645e-02
>     3 KSP preconditioned resid norm 5.499797533437e-02 true resid norm
> 1.466612675583e-01 ||r(i)||/||b|| 1.061203687852e-02
>     4 KSP preconditioned resid norm 2.829814271435e-02 true resid norm
> 7.546171390493e-02 ||r(i)||/||b|| 5.460217985345e-03
>     5 KSP preconditioned resid norm 7.431048995318e-03 true resid norm
> 1.981613065418e-02 ||r(i)||/||b|| 1.433844891652e-03
>     6 KSP preconditioned resid norm 3.182040728972e-03 true resid norm
> 8.485441943932e-03 ||r(i)||/||b|| 6.139850305312e-04
>     7 KSP preconditioned resid norm 1.030867020459e-03 true resid norm
> 2.748978721225e-03 ||r(i)||/||b|| 1.989091193167e-04
>     8 KSP preconditioned resid norm 4.469429300003e-04 true resid norm
> 1.191847813335e-03 ||r(i)||/||b|| 8.623908111021e-05
>     9 KSP preconditioned resid norm 1.237303313796e-04 true resid norm
> 3.299475503456e-04 ||r(i)||/||b|| 2.387416685085e-05
>    10 KSP preconditioned resid norm 5.822094326756e-05 true resid norm
> 1.552558487134e-04 ||r(i)||/||b|| 1.123391894522e-05
>    11 KSP preconditioned resid norm 1.735776150969e-05 true resid norm
> 4.628736402585e-05 ||r(i)||/||b|| 3.349236115503e-06
>   Linear redistribute_ solve converged due to CONVERGED_RTOL iterations 11
> KSP Object: (redistribute_) 1 MPI process
>   type: cg
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: (redistribute_) 1 MPI process
>   type: jacobi
>     type DIAGONAL
>   linear system matrix = precond matrix:
>   Mat Object: 1 MPI process
>     type: mpiaij
>     rows=48896, cols=48896
>     total: nonzeros=307976, allocated nonzeros=307976
>     total number of mallocs used during MatSetValues calls=0
>       not using I-node (on process 0) routines
> End of program
>  solve time 0.564714744 seconds
> Starting max value is: 0
> Min value of level 0 is: 0
> Interpolated min value is: 741.978761
> Unused ParmParse Variables:
>   [TOP]::model.type(nvals = 1)  :: [3]
>   [TOP]::ref_ratio(nvals = 1)  :: [2]
> AMReX (22.10-20-g3082028e4287) finalized
> #PETSc Option Table entries:
> -ksp_type preonly
> -options_left
> -pc_type redistribute
> -redistribute_ksp_converged_reason
> -redistribute_ksp_monitor_true_residual
> -redistribute_ksp_type cg
> -redistribute_ksp_view
> -redistribute_pc_type jacobi
> #End of PETSc Option Table entries
> There are no unused options.
> Program ended with exit code: 0
> Best,
> Karthik.
> *From: *Barry Smith <bsmith at petsc.dev>
> *Date: *Friday, 3 February 2023 at 17:41
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> karthikeyan.chockalingam at stfc.ac.uk>
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Eliminating rows and columns which are zeros
>    We need all the error output for the errors you got below to understand
> why the errors are happening.
> On Feb 3, 2023, at 11:41 AM, Karthikeyan Chockalingam - STFC UKRI <
> karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Hello Barry,
> I would like to better understand pc_type redistribute usage.
> I am plan to use pc_type *redistribute* in the context of adaptive mesh
> refinement on a structured grid in 2D. My base mesh (level 0) is indexed
> from 0 to N-1 elements and refined mesh (level 1) is indexed from 0 to
> 4(N-1) elements. When I construct system matrix A on (level 1); I probably
> only use 20% of 4(N-1)  elements, however the indexes are scattered in the
> range of 0 to 4(N-1). That leaves 80% of the rows and columns of the system
> matrix A on (level 1) to be zero. From your earlier response, I believe
> this would be a use case for petsc_type redistribute.
>   Indeed the linear solve will be more efficient if you use the
> redistribute solver.
>   But I don't understand your plan. With adaptive refinement I would just
> create the two matrices, one for the initial grid on which you solve the
> system, this will be a smaller matrix and then create a new larger matrix
> for the refined grid (and discard the previous matrix).
> Question (1)
> If N is really large, I would have to allocate memory of size 4(N-1) for
> the system matrix A on (level 1). How does pc_type redistribute help?
> Because, I did end up allocating memory for a large system, where most of
> the rows and columns are zeros. Is most of the allotted memory not wasted?
>  *Is this the correct usage?*
>   See above
> Question (2)
> I tried using pc_type redistribute for a two level system.
> I have *attached* the output only for  (level 1)
> The solution converges to right solution but still petsc outputs some
> error messages.
> But the there were no unused options
> -ksp_type preonly
> -options_left
> *There are no unused options.*
> I cannot explain this
> Question (2)
> What does this error message imply? Given I only use 20% of 4(N-1)
> indexes, I can imagine most of the diagonal entrees are zero. *Is my
> understanding correct?*
> Question (3)
> I am using MatZeroRowsColumnsIS to set the homogenous Dirichelet boundary.
> I don’t follow why I get this error message as the linear system converges
> to the right solution.
> Thank you for your help.
> Kind regards,
> Karthik.
> *Date: *Tuesday, 10 January 2023 at 18:50
>   Yes, after the solve the x will contain correct values for ALL the
> locations including the (zeroed out rows). You use case is exactly what
> redistribute it for.
>   Barry
> On Jan 10, 2023, at 11:25 AM, Karthikeyan Chockalingam - STFC UKRI <
> Thank you Barry. This is great!
> I plan to solve using ‘-pc_type redistribute’ after applying the Dirichlet
> bc using
> MatZeroRowsColumnsIS(A, isout, 1, x, b);
> While I retrieve the solution data from x (after the solve) – can I index
> them using the original ordering (if I may say that)?
> Kind regards,
> Karthik.
> *Date: *Tuesday, 10 January 2023 at 16:04
> https://petsc.org/release/docs/manualpages/PC/PCREDISTRIBUTE/#pcredistribute
> It does everything for you. Note that if the right hand side for any of
> the "zero" rows is nonzero then the system is inconsistent and the system
> does not have a solution.
> Barry
> On Jan 10, 2023, at 10:30 AM, Karthikeyan Chockalingam - STFC UKRI via
> Hello,
> I am assembling a MATIJ of size N, where a very large number of rows (and
> corresponding columns), are zeros. I would like to potentially eliminate
> them before the solve.
> For instance say N=7
> 0 0  0  0 0 0 0
> 0 1 -1  0 0 0 0
> 0 -1 2  0 0 0 -1
> 0 0  0  0 0 0 0
> 0 0  0  0 0 0 0
> 0 0  0  0 0 0 0
> 0 0  -1 0 0 0 1
> I would like to reduce it to a 3x3
> 1 -1 0
> -1 2 -1
> 0 -1 1
> I do know the size N.
> Q1) How do I do it?
> Q2) Is it better to eliminate them as it would save a lot of memory?
> Q3) At the moment, I don’t know which rows (and columns) have the zero
> entries but with some effort I probably can find them. Should I know which
> rows (and columns) I am eliminating?
> Thank you.
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
> <petsc_redistribute.txt>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/aed9c77e/attachment-0001.html>
