[petsc-users] Question about MatGetRow
김성익 ksi2443 at gmail.com
Fri Feb 3 07:45:09 CST 2023
Following your comments,
If I extract first row of below matrix.
[image: image.png]
IS isrow;
PetscInt *indices;
PetscMalloc1(1, *indices);
Indices[0] = 0;
ISCreateGenreral(PETSC_COMM_WORLD, 1, indices, PETSC_COPY_VALUES, &isrow);
MatCreateSubMatrix(mat,isrow,NULL,MAT_INITIAL_MATRIX,&newmat);
Then can I get the array about first row of global matrix in all processes?
Hyung Kim
2023년 2월 3일 (금) 오후 10:26, Matthew Knepley <knepley at gmail.com>님이 작성:
>> I want to check below things.
>> For example, the global dense matrix are as below.
>> [image: image.png]
>> If I want to get first row ('1 2 0 0 3 0 0 4') in Proc 1.
>> Then I should put 'MatCreateSubMatrix
>> <https://petsc.org/main/docs/manualpages/Mat/MatCreateSubMatrix/>(mat,
>> isrow, NULL, MAT_INITIAL_MATRIX, *&*newmat)'
>> and isrow will be [0 1 2 3 4 5 6 7].
>> In this case, How can I make isrow?
>> Actually I can't understand the procedure of handling isrow.
> You create an IS object of type ISGENERAL and give it the array of global
> indices that you want to extract.
>   Thanks,
>      Matt
>> Hyung Kim
>> 2023년 2월 3일 (금) 오후 9:03, Mark Adams <mfadams at lbl.gov>님이 작성:
>>> Note, PETSc lets you give NULL arguments if there is a reasonable
>>> default.
>>> In this case give NULL for the column IS and you will get the whole
>>> columns.
>>> Mark
>>> On Fri, Feb 3, 2023 at 4:05 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>> Hello,
>>>> By using MatGetRow, user can get vectors from local matrix (at each
>>>> process).
>>>> However, I need other process's row values.
>>>> So I have 2 questions.
>>>> 1. Is there any function for getting arrays from other process's??
>>>> 2. Or is there any function like matrix version of vecscattertoall??
>>>> Thanks,
>>>> Hyung Kim
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/e10ea2e0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/e10ea2e0/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230203/e10ea2e0/attachment-0003.png>
