[petsc-users] PCMG Interpolation/Restriction Defaults
Grosse-Bley, Paul
paul.grosse-bley at ziti.uni-heidelberg.de
Thu Feb 2 08:26:42 CST 2023
The documentation says that
> The multigrid routines, which determine the solvers and interpolation/restriction operators that are used, are mandatory.
But using code that doesn't contain any multigrid-specific routines e.g. ex45 and running it with
-da_grid_x 129 -da_grid_y 129 -da_grid_z 129
-pc_type mg
-pc_mg_type multiplicative
-pc_mg_cycle_type v
-pc_mg_levels 5
seems to work fine and also not fall-back to algebraic multigrid/PCGAMG from what I see with -log_view.
What interpolation/restriction operators are used by default with PCMG?
Is it cleverly using the geometric information from DA?
Paul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230202/d022891c/attachment.html>
