[petsc-users] [petsc-maint] DMSwarm on multiple processors
Joauma Marichal
joauma.marichal at uclouvain.be
Wed Dec 20 03:12:43 CST 2023
Hello,
I used Address Sanitizer on my laptop and I have no leaks.
I do have access to another machine (managed by the same people as the previous one) but I obtain similar errors…
Thanks again for your help.
Best regards,
Joauma
De : Matthew Knepley <knepley at gmail.com>
Date : mardi, 19 décembre 2023 à 14:30
À : Joauma Marichal <joauma.marichal at uclouvain.be>
Cc : petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-maint] DMSwarm on multiple processors
On Tue, Dec 19, 2023 at 5:11 AM Joauma Marichal <joauma.marichal at uclouvain.be<mailto:joauma.marichal at uclouvain.be>> wrote:
Hello,
I have used Address Sanitizer to check any memory errors. On my computer, no errors are found. Unfortunately, on the supercomputer that I am using, I get lots of errors… I attach my log files (running on 1 and 70 procs).
Do you have any idea of what I could do?
Run the same parallel configuration as you do on the supercomputer. If that is fine, I would suggest Address Sanitizer there. Something is corrupting the stack, and it appears that it is connected to that machine, rather than the library. Do you have access to a second parallel machine?
Matt
Thanks a lot for your help.
Best regards,
Joauma
De : Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Date : lundi, 18 décembre 2023 à 12:00
À : Joauma Marichal <joauma.marichal at uclouvain.be<mailto:joauma.marichal at uclouvain.be>>
Cc : petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov> <petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>>, petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
On Mon, Dec 18, 2023 at 5:09 AM Joauma Marichal <joauma.marichal at uclouvain.be<mailto:joauma.marichal at uclouvain.be>> wrote:
Hello,
Sorry for the delay. I attach the file that I obtain when running the code with the debug mode.
Okay, we can now see where this is happening:
malloc_consolidate(): invalid chunk size
[cns263:3265170] *** Process received signal ***
[cns263:3265170] Signal: Aborted (6)
[cns263:3265170] Signal code: (-6)
[cns263:3265170] [ 0] /lib64/libc.so.6(+0x4eb20)[0x7f3bd9148b20]
[cns263:3265170] [ 1] /lib64/libc.so.6(gsignal+0x10f)[0x7f3bd9148a9f]
[cns263:3265170] [ 2] /lib64/libc.so.6(abort+0x127)[0x7f3bd911be05]
[cns263:3265170] [ 3] /lib64/libc.so.6(+0x91037)[0x7f3bd918b037]
[cns263:3265170] [ 4] /lib64/libc.so.6(+0x9819c)[0x7f3bd919219c]
[cns263:3265170] [ 5] /lib64/libc.so.6(+0x98b68)[0x7f3bd9192b68]
[cns263:3265170] [ 6] /lib64/libc.so.6(+0x9af18)[0x7f3bd9194f18]
[cns263:3265170] [ 7] /lib64/libc.so.6(__libc_malloc+0x1e2)[0x7f3bd9196822]
[cns263:3265170] [ 8] /lib64/libc.so.6(posix_memalign+0x3c)[0x7f3bd91980fc]
[cns263:3265170] [ 9] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscMallocAlign+0x45)[0x7f3bda5f1625]
[cns263:3265170] [10] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscMallocA+0x297)[0x7f3bda5f1b07]
[cns263:3265170] [11] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMCreate+0x5b)[0x7f3bdaa73c1b]
[cns263:3265170] [12] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMDACreate+0x9)[0x7f3bdab0a2f9]
[cns263:3265170] [13] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMDACreate3d+0x9a)[0x7f3bdab07dea]
[cns263:3265170] [14] ./cobpor[0x402de8]
[cns263:3265170] [15] /lib64/libc.so.6(__libc_start_main+0xf3)[0x7f3bd9134cf3]
[cns263:3265170] [16] ./cobpor[0x40304e]
[cns263:3265170] *** End of error message ***
However, this is not great. First, the amount of memory being allocated is quite small, and this does not appear to be an Out of Memory error. Second, the error occurs in libc:
which means something is wrong internally. I agree with this analysis (https://stackoverflow.com/questions/18760999/sample-example-program-to-get-the-malloc-consolidate-error) that says you have probably overwritten memory somewhere in your code. I recommend running under valgrind, or using Address Sanitizer from clang.
Matt
Thanks for your help.
Best regards,
Joauma
Date : jeudi, 23 novembre 2023 à 15:32
On Thu, Nov 23, 2023 at 9:01 AM Joauma Marichal <joauma.marichal at uclouvain.be<mailto:joauma.marichal at uclouvain.be>> wrote:
Hello,
My problem persists… Is there anything I could try?
Yes. It appears to be failing from a call inside PetscSFSetUpRanks(). It does allocation, and the failure
is in libc, and it only happens on larger examples, so I suspect some allocation problem. Can you rebuild with debugging and run this example? Then we can see if the allocation fails.
Matt
Thanks a lot.
Best regards,
Joauma
Date : mercredi, 25 octobre 2023 à 14:45
On Wed, Oct 25, 2023 at 8:32 AM Joauma Marichal via petsc-maint <petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>> wrote:
Hello,
I am using the DMSwarm library in some Eulerian-Lagrangian approach to have vapor bubbles in water.
I have obtained nice results recently and wanted to perform bigger simulations. Unfortunately, when I increase the number of processors used to run the simulation, I get the following error:
free(): invalid size
[cns136:590327] *** Process received signal ***
[cns136:590327] Signal: Aborted (6)
[cns136:590327] Signal code: (-6)
[cns136:590327] [ 0] /lib64/libc.so.6(+0x4eb20)[0x7f56cd4c9b20]
[cns136:590327] [ 1] /lib64/libc.so.6(gsignal+0x10f)[0x7f56cd4c9a9f]
[cns136:590327] [ 2] /lib64/libc.so.6(abort+0x127)[0x7f56cd49ce05]
[cns136:590327] [ 3] /lib64/libc.so.6(+0x91037)[0x7f56cd50c037]
[cns136:590327] [ 4] /lib64/libc.so.6(+0x9819c)[0x7f56cd51319c]
[cns136:590327] [ 5] /lib64/libc.so.6(+0x99aac)[0x7f56cd514aac]
[cns136:590327] [ 6] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscSFSetUpRanks+0x4c4)[0x7f56cea71e64]
[cns136:590327] [ 7] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(+0x841642)[0x7f56cea83642]
[cns136:590327] [ 8] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscSFSetUp+0x9e)[0x7f56cea7043e]
[cns136:590327] [ 9] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(VecScatterCreate+0x164e)[0x7f56cea7bbde]
[cns136:590327] [10] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp_DA_3D+0x3e38)[0x7f56cee84dd8]
[cns136:590327] [11] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp_DA+0xd8)[0x7f56cee9b448]
[cns136:590327] [12] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp+0x20)[0x7f56cededa20]
[cns136:590327] [13] ./cobpor[0x4418dc]
[cns136:590327] [14] ./cobpor[0x408b63]
[cns136:590327] [15] /lib64/libc.so.6(__libc_start_main+0xf3)[0x7f56cd4b5cf3]
[cns136:590327] [16] ./cobpor[0x40bdee]
[cns136:590327] *** End of error message ***
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpiexec noticed that process rank 84 with PID 590327 on node cns136 exited on signal 6 (Aborted).
When I reduce the number of processors the error disappears and when I run my code without the vapor bubbles it also works.
The problem seems to take place at this moment:
DMCreate(PETSC_COMM_WORLD,swarm);
DMSetType(*swarm,DMSWARM);
DMSetDimension(*swarm,3);
DMSwarmSetType(*swarm,DMSWARM_PIC);
DMSwarmSetCellDM(*swarm,*dmcell);
Things that would help us track this down:
1) The smallest example where it fails
2) The smallest number of processes where it fails
3) A stack trace of the failure
4) A simple example that we can run that also fails
Matt
Best regards,
Joauma
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231220/f5269ee4/attachment-0001.html>
Desc: log_1proc_SC2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231220/f5269ee4/attachment-0002.obj>
Desc: log_70proc_SC2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231220/f5269ee4/attachment-0003.obj>
