[petsc-users] 捕获
Matthew Knepley
knepley at gmail.com
Thu Dec 14 06:52:58 CST 2023
On Thu, Dec 14, 2023 at 1:27 AM 2111191--- via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear SLEPc Developers,
> I a am student from Tongji University. Recently I am trying to write a c++
> program for matrix solving, which requires importing the PETSc library that
> you have developed. However a lot of errors occur in the cpp file when I
> use #include <petscts.h> directly. I also try to use extern "C" but it
> gives me the error in the picture below. Is there a good way to use the
> PETSc library in a c++ program? (I compiled using cmake and my compiler is
> g++ (GCC) 4.8.5 20150623 (Red Hat 4.8.5-44)).
> My cmakelists.txt is:
> cmake_minimum_required(VERSION 3.1.0)
> set(CMAKE_INSTALL_RPATH_USE_LINK_PATH TRUE)
> set(PETSC $ENV{PETSC_DIR}/$ENV{PETSC_ARCH})
> set(SLEPC $ENV{SLEPC_DIR}/$ENV{PETSC_ARCH})
> set(ENV{PKG_CONFIG_PATH} ${PETSC}/lib/pkgconfig:${SLEPC}/lib/pkgconfig)
> set (CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11")
> set (CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -std=c99")
> project(test)
> add_executable(${PROJECT_NAME} eigen_test2.cpp)
> find_package(PkgConfig REQUIRED)
> pkg_search_module(PETSc REQUIRED IMPORTED_TARGET PETSc)
> target_link_libraries(${PROJECT_NAME} PkgConfig::PETSc)
> The testing code is:eigen_test2.cpp
First, get rid of the "extern C" in front of the headers.
Matt
> extern "C"{
> //#include <petsc.h>
> #include <petscdm.h>
> #include <petscdmda.h>
> #include <petscdraw.h>
> int main(int argc,char **argv)
> return 0;
> Best regards
> Weijie Xu
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231214/09afedb9/attachment.html>
