[petsc-users] Question on output vector in vtk file
Matthew Knepley
knepley at gmail.com
Mon Dec 11 07:07:21 CST 2023
On Mon, Dec 11, 2023 at 4:32 AM Gong Yujie <yc17470 at connect.um.edu.mo>
wrote:
> Dear PETSc developers,
> I have a DMPlex DM with 1 field 1dof. I'd like to output a vector with
> block size equals to 3. It seems that there is no response using command
> line option or using some code about PetscViewer.
I am not sure how we can do this. If you only have 1 dof per cell (I
assume), how can we have a blocksize of 3?
Matt
> The DM is generated with (note that I'm not using PetscFE for
> discretization, just for allocate dof.)
> *PetscCall(DMPlexCreateExodusFromFile(PETSC_COMM_WORLD,"tube.exo",interpolate,&dm));*
> *PetscCall(PetscFECreateLagrange(PETSC_COMM_SELF,dim,1,PETSC_TRUE,1,PETSC_DETERMINE,&fe));*
> *PetscCall(PetscObjectSetName((PetscObject)fe,"potential_field"));*
> *PetscCall(DMSetField(dm,0,NULL,(PetscObject)fe));*
> *PetscCall(DMPlexDistribute(dm,0,&sf,&dmParallel));*
> The Vector is created using
> *PetscCall(DMCreateGlobalVector(dm,&phi_1));*
> *PetscCall(VecSetLocalToGlobalMapping(phi_1,Itog));*
> *PetscCall(VecGetLocalSize(phi_1,&vec_local_size_test));*
> *PetscCall(VecCreateMPI(PETSC_COMM_WORLD, vec_local_size_test*3,
> PETSC_DETERMINE, &u_grad_psi));*
> *PetscCall(VecSetBlockSize(u_grad_psi, 3));*
> *PetscCall(VecSetLocalToGlobalMapping(u_grad_psi,Itog));*
> The output command line option is just --vec_view vtk:test.vtk. The PETSc
> version I'm using is 3.19.5.
> Could you please give me some advice?
> Best Regards,
> Yujie
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231211/14c3c514/attachment.html>
