[petsc-users] Configure error while building PETSc with CUDA/MVAPICH2-GDR
Mark Adams mfadams at lbl.gov
Fri Dec 8 17:30:34 CST 2023
You may need to set some env variables. This can be system specific so you
might want to look at docs or ask TACC how to run with GPU-aware MPI.
On Fri, Dec 8, 2023 at 5:17 PM Sreeram R Venkat <srvenkat at utexas.edu> wrote:
> Actually, when I compile my program with this build of PETSc and run, I
> still get the error:
> PETSC ERROR: PETSc is configured with GPU support, but your MPI is not
> GPU-aware. For better performance, please use a GPU-aware MPI.
> I have the mvapich2-gdr module loaded and MV2_USE_CUDA=1.
> Is there anything else I need to do?
> Thanks,
> Sreeram
> On Fri, Dec 8, 2023 at 3:29 PM Sreeram R Venkat <srvenkat at utexas.edu>
> wrote:
>> Thank you, changing to CUDA 11.4 fixed the issue. The mvapich2-gdr module
>> didn't require CUDA 11.4 as a dependency, so I was using 12.0
>> On Fri, Dec 8, 2023 at 1:15 PM Satish Balay <balay at mcs.anl.gov> wrote:
>>> Executing: mpicc -show
>>> stdout: icc -I/opt/apps/cuda/11.4/include -I/opt/apps/cuda/11.4/include
>>> -lcuda -L/opt/apps/cuda/11.4/lib64/stubs -L/opt/apps/cuda/11.4/lib64
>>> -lcudart -lrt -Wl,-rpath,/opt/apps/cuda/11.4/lib64
>>> -Wl,-rpath,XORIGIN/placeholder -Wl,--build-id -L/opt/apps/cuda/11.4/lib64/
>>> -lm -I/opt/apps/intel19/mvapich2-gdr/2.3.7/include
>>> -L/opt/apps/intel19/mvapich2-gdr/2.3.7/lib64 -Wl,-rpath
>>> -Wl,/opt/apps/intel19/mvapich2-gdr/2.3.7/lib64 -Wl,--enable-new-dtags -lmpi
>>>     Checking for program /opt/apps/cuda/12.0/bin/nvcc...found
>>> Looks like you are trying to mix in 2 different cuda versions in this
>>> build.
>>> Perhaps you need to use cuda-11.4 - with this install of mvapich..
>>> Satish
>>> On Fri, 8 Dec 2023, Matthew Knepley wrote:
>>> > On Fri, Dec 8, 2023 at 1:54 PM Sreeram R Venkat <srvenkat at utexas.edu>
>>> wrote:
>>> > > I am trying to build PETSc with CUDA using the CUDA-Aware
>>> MVAPICH2-GDR.
>>> > > Here is my configure command:
>>> > > ./configure PETSC_ARCH=linux-c-debug-mvapich2-gdr --download-hypre
>>> > >  --with-cuda=true --cuda-dir=$TACC_CUDA_DIR --with-hdf5=true
>>> > > --with-hdf5-dir=$TACC_PHDF5_DIR --download-elemental --download-metis
>>> > > --download-parmetis --with-cc=mpicc --with-cxx=mpicxx
>>> --with-fc=mpif90
>>> > > which errors with:
>>> > >           UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
>>> for
>>> > > details):
>>> > >   CUDA compile failed with arch flags " -ccbin mpic++ -std=c++14
>>> > > -Xcompiler -fPIC
>>> > >   -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
>>> > > arch=compute_80,code=sm_80"
>>> > >   generated from "--with-cuda-arch=80"
>>> > > The same configure command works when I use the Intel MPI and I can
>>> build
>>> > > with CUDA. The full config.log file is attached. Please let me know
>>> if you
>>> > > need any other information. I appreciate your help with this.
>>> > The proximate error is
>>> > Executing: nvcc -c -o
>>> /tmp/petsc-kn3f29gl/config.packages.cuda/conftest.o
>>> > -I/tmp/petsc-kn3f29gl/config.setCompilers
>>> > -I/tmp/petsc-kn3f29gl/config.types
>>> > -I/tmp/petsc-kn3f29gl/config.packages.cuda  -ccbin mpic++ -std=c++14
>>> > -Xcompiler -fPIC -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
>>> > arch=compute_80,code=sm_80  /tmp/petsc-kn3f29gl/config.packages.cuda/
>>> > conftest.cu
>>> > stdout:
>>> > /opt/apps/cuda/11.4/include/crt/sm_80_rt.hpp(141): error: more than one
>>> > instance of overloaded function "__nv_associate_access_property_impl"
>>> has
>>> > "C" linkage
>>> > 1 error detected in the compilation of
>>> > "/tmp/petsc-kn3f29gl/config.packages.cuda/conftest.cu".
>>> > Possible ERROR while running compiler: exit code 1
>>> > stderr:
>>> has
>>> > "C" linkage
>>> > This looks like screwed up headers to me, but I will let someone that
>>> > understands CUDA compilation reply.
>>> >   Thanks,
>>> >      Matt
>>> > Thanks,
>>> > > Sreeram
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231208/0c6b1858/attachment.html>
