[petsc-users] Configure error while building PETSc with CUDA/MVAPICH2-GDR
Sreeram R Venkat
srvenkat at utexas.edu
Fri Dec 8 15:29:20 CST 2023
Thank you, changing to CUDA 11.4 fixed the issue. The mvapich2-gdr module
didn't require CUDA 11.4 as a dependency, so I was using 12.0
On Fri, Dec 8, 2023 at 1:15 PM Satish Balay <balay at mcs.anl.gov> wrote:
> Executing: mpicc -show
> stdout: icc -I/opt/apps/cuda/11.4/include -I/opt/apps/cuda/11.4/include
> -lcuda -L/opt/apps/cuda/11.4/lib64/stubs -L/opt/apps/cuda/11.4/lib64
> -lcudart -lrt -Wl,-rpath,/opt/apps/cuda/11.4/lib64
> -Wl,-rpath,XORIGIN/placeholder -Wl,--build-id -L/opt/apps/cuda/11.4/lib64/
> -lm -I/opt/apps/intel19/mvapich2-gdr/2.3.7/include
> -L/opt/apps/intel19/mvapich2-gdr/2.3.7/lib64 -Wl,-rpath
> -Wl,/opt/apps/intel19/mvapich2-gdr/2.3.7/lib64 -Wl,--enable-new-dtags -lmpi
> Checking for program /opt/apps/cuda/12.0/bin/nvcc...found
> Looks like you are trying to mix in 2 different cuda versions in this
> build.
> Perhaps you need to use cuda-11.4 - with this install of mvapich..
> Satish
> On Fri, 8 Dec 2023, Matthew Knepley wrote:
> > On Fri, Dec 8, 2023 at 1:54 PM Sreeram R Venkat <srvenkat at utexas.edu>
> wrote:
> > > I am trying to build PETSc with CUDA using the CUDA-Aware MVAPICH2-GDR.
> > > Here is my configure command:
> > > ./configure PETSC_ARCH=linux-c-debug-mvapich2-gdr --download-hypre
> > > --with-cuda=true --cuda-dir=$TACC_CUDA_DIR --with-hdf5=true
> > > --with-hdf5-dir=$TACC_PHDF5_DIR --download-elemental --download-metis
> > > --download-parmetis --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> > > which errors with:
> > > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > > details):
> > > CUDA compile failed with arch flags " -ccbin mpic++ -std=c++14
> > > -Xcompiler -fPIC
> > > -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
> > > arch=compute_80,code=sm_80"
> > > generated from "--with-cuda-arch=80"
> > > The same configure command works when I use the Intel MPI and I can
> build
> > > with CUDA. The full config.log file is attached. Please let me know if
> you
> > > need any other information. I appreciate your help with this.
> > The proximate error is
> > Executing: nvcc -c -o /tmp/petsc-kn3f29gl/config.packages.cuda/conftest.o
> > -I/tmp/petsc-kn3f29gl/config.setCompilers
> > -I/tmp/petsc-kn3f29gl/config.types
> > -I/tmp/petsc-kn3f29gl/config.packages.cuda -ccbin mpic++ -std=c++14
> > -Xcompiler -fPIC -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
> > arch=compute_80,code=sm_80 /tmp/petsc-kn3f29gl/config.packages.cuda/
> > conftest.cu
> > stdout:
> > /opt/apps/cuda/11.4/include/crt/sm_80_rt.hpp(141): error: more than one
> > instance of overloaded function "__nv_associate_access_property_impl" has
> > "C" linkage
> > 1 error detected in the compilation of
> > "/tmp/petsc-kn3f29gl/config.packages.cuda/conftest.cu".
> > Possible ERROR while running compiler: exit code 1
> > stderr:
> > "C" linkage
> > This looks like screwed up headers to me, but I will let someone that
> > understands CUDA compilation reply.
> > Thanks,
> > Matt
> > Thanks,
> > > Sreeram
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231208/a84ee2e8/attachment-0001.html>
