[petsc-users] DMSTAG Gathering Vector on single process
Colton Bryant
coltonbryant2021 at u.northwestern.edu
Wed Dec 6 17:37:59 CST 2023
Ah excellent! I was not aware of the ability to preallocate the objects and
migrate them each time.
Thanks!
-Colton
On Wed, Dec 6, 2023 at 5:18 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Dec 6, 2023 at 5:54 PM Colton Bryant <
> coltonbryant2021 at u.northwestern.edu> wrote:
>> Hello,
>> I am working on a code in which a DMSTAG object is used to solve a fluid
>> flow problem and I need to gather this flow data on a single process to
>> interact with an existing (serial) library at each timestep of my
>> simulation. After looking around the solution I've tried is:
>> -use DMStagVecSplitToDMDA to extract vectors of each component of the flow
>> -use DMDACreateNaturalVector and DMDAGlobalToNatural to get the
>> components naturally ordered
>> -use VecScatterCreateToZero to set up and then do the scatter to gather
>> on the single process
>> Unless I'm misunderstanding something this method results in a lot of
>> memory allocation/freeing happening at each step of the evolution and I was
>> wondering if there is a way to directly perform such a scatter from the
>> DMSTAG object without splitting as I'm doing here.
> 1) You can see here:
> https://petsc.org/main/src/dm/impls/stag/stagda.c.html#DMStagVecSplitToDMDA
> that this function is small. You can do the DMDA creation manually, and
> then just call DMStagMigrateVecDMDA() each time, which will not create
> anything.
> 2) You can create the natural vector upfront, and just scatter each time.
> 3) You can create the serial vector upfront, and just scatter each time.
> This is some data movement. You can compress the g2n and 2zero scatters
> using
> https://petsc.org/main/manualpages/PetscSF/PetscSFCompose/
> as an optimization.
> Thanks,
> Matt
>> Any advice would be much appreciated!
>> Best,
>> Colton Bryant
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231206/40acde73/attachment-0001.html>
