[petsc-users] Scattering a vector to/from a subset of processors
Sreeram R Venkat
srvenkat at utexas.edu
Tue Dec 5 22:09:21 CST 2023
Yes, I have an example code at github.com/s769/petsc-test. Only thing is,
when I described the example before, I simplified the actual use case in
the code to make things simpler. Here are the extra details relevant to
this code:
- We assume a 2D processor grid, given by the command-line args
-proc_rows and -proc_cols
- The total length of the vector is n_m*n_t given by command-line args
-nm and -nt. n_m corresponds to a space index and n_t a time index.
- In the "Start" phase, the vector is divided into n_m blocks each of
size n_t (indexed space->time). The blocks are partitioned over the first
row of processors. For example if -nm = 4 and -proc_cols = 4, each
processor in the first row will get one block of size n_t. Each processor
in the first row gets n_m_local blocks of size n_t, where the sum of all
n_m_locals for the first row of processors is n_m.
- In the "Finish" phase, the vector is divided into n_t blocks each of
size n_m (indexed time->space; this is the reason for the permutation of
indices). The blocks are partitioned over all processors. Each processor
will get n_t_local blocks of size n_m, where the sum of all n_t_locals for
all processors is n_t.
I think the basic idea is similar to the previous example, but these
details make things a bit more complicated. Please let me know if anything
is unclear, and I can try to explain more.
Thanks for your help,
Sreeram
On Tue, Dec 5, 2023 at 9:30 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> I think your approach is correct. Do you have an example code?
> --Junchao Zhang
> On Tue, Dec 5, 2023 at 5:15 PM Sreeram R Venkat <srvenkat at utexas.edu>
> wrote:
>> Hi, I have a follow up question on this.
>> Now, I'm trying to do a scatter and permutation of the vector. Under the
>> same setup as the original example, here are the new Start and Finish
>> states I want to achieve:
>> Start Finish
>> Proc | Entries Proc | Entries
>> 0 | 0,...,8 0 | 0, 12, 24
>> 1 | 9,...,17 1 | 1, 13, 25
>> 2 | 18,...,26 2 | 2, 14, 26
>> 3 | 27,...,35 3 | 3, 15, 27
>> 4 | None 4 | 4, 16, 28
>> 5 | None 5 | 5, 17, 29
>> 6 | None 6 | 6, 18, 30
>> 7 | None 7 | 7, 19, 31
>> 8 | None 8 | 8, 20, 32
>> 9 | None 9 | 9, 21, 33
>> 10 | None 10 | 10, 22, 34
>> 11 | None 11 | 11, 23, 35
>> So far, I've tried to use ISCreateGeneral(), with each process giving an
>> idx array corresponding to the indices it wants (i.e. idx on P0 looks like
>> [0,12,24] P1 -> [1,13, 25], and so on).
>> Then I use this to create the VecScatter with VecScatterCreate(x, is, y,
>> NULL, &scatter).
>> However, when I try to do the scatter, I get some illegal memory access
>> errors.
>> Is there something wrong with how I define the index sets?
>> Thanks,
>> Sreeram
>> On Thu, Oct 5, 2023 at 12:57 PM Sreeram R Venkat <srvenkat at utexas.edu>
>> wrote:
>>> Thank you. This works for me.
>>> Sreeram
>>> On Wed, Oct 4, 2023 at 6:41 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Hi, Sreeram,
>>>> You can try this code. Since x, y are both MPI vectors, we just need to
>>>> say we want to scatter x[0:N] to y[0:N]. The 12 index sets with your
>>>> example on the 12 processes would be [0..8], [9..17], [18..26], [27..35],
>>>> [], ..., []. Actually, you can do it arbitrarily, say, with 12 index sets
>>>> [0..17], [18..35], .., []. PETSc will figure out how to do the
>>>> communication.
>>>> PetscInt rstart, rend, N;
>>>> IS ix;
>>>> VecScatter vscat;
>>>> Vec y;
>>>> MPI_Comm comm;
>>>> VecType type;
>>>> PetscObjectGetComm((PetscObject)x, &comm);
>>>> VecGetType(x, &type);
>>>> VecGetSize(x, &N);
>>>> VecGetOwnershipRange(x, &rstart, &rend);
>>>> VecCreate(comm, &y);
>>>> VecSetSizes(y, PETSC_DECIDE, N);
>>>> VecSetType(y, type);
>>>> ISCreateStride(PetscObjectComm((PetscObject)x), rend - rstart, rstart,
>>>> 1, &ix);
>>>> VecScatterCreate(x, ix, y, ix, &vscat);
>>>> --Junchao Zhang
>>>> On Wed, Oct 4, 2023 at 6:03 PM Sreeram R Venkat <srvenkat at utexas.edu>
>>>> wrote:
>>>>> Suppose I am running on 12 processors, and I have a vector "v" of size
>>>>> 36 partitioned over the first 4. v still uses the PETSC_COMM_WORLD, so it
>>>>> has a layout of (9, 9, 9, 9, 0, 0, ..., 0). Now, I would like to
>>>>> repartition it over all 12 processors, so that the layout becomes (3, 3, 3,
>>>>> ..., 3). I've been trying to use VecScatter to do this, but I'm not sure
>>>>> what IndexSets to use for the sender and receiver.
>>>>> The result I am trying to achieve is this:
>>>>> Assume the vector is v = <0, 1, 2, ..., 35>
>>>>> Start Finish
>>>>> 0 | 0,...,8 0 | 0, 1, 2
>>>>> 1 | 9,...,17 1 | 3, 4, 5
>>>>> 2 | 18,...,26 2 | 6, 7, 8
>>>>> 3 | 27,...,35 3 | 9, 10, 11
>>>>> 4 | None 4 | 12, 13, 14
>>>>> 5 | None 5 | 15, 16, 17
>>>>> 6 | None 6 | 18, 19, 20
>>>>> 7 | None 7 | 21, 22, 23
>>>>> 8 | None 8 | 24, 25, 26
>>>>> 9 | None 9 | 27, 28, 29
>>>>> 10 | None 10 | 30, 31, 32
>>>>> 11 | None 11 | 33, 34, 35
>>>>> Appreciate any help you can provide on this.
>>>>> Thanks,
>>>>> Sreeram
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231205/966cc722/attachment.html>
