[petsc-users] Help for MatNullSpaceCreateRigidBody
Jordi Manyer Fuertes jordi.manyer at monash.edu
Mon Dec 4 08:44:41 CST 2023
Dear PETSc users/developpers,
I am currently trying to use the method `MatNullSpaceCreateRigidBody`
together with `PCGAMG` to efficiently precondition an elasticity solver
in 2D/3D.
I have managed to make it work in serial (or with 1 MPI rank) with
h-independent number of iterations (which is great), but the solver
diverges in parallel.
I assume it has to do with the coordinate vector I am building the
null-space with not being correctly setup. The documentation is not that
clear on which nodes exactly have to be set in each partition. Does it
require nodes corresponding to owned dofs, or all dofs in each partition
(owned+ghost)? What ghost layout should the `Vec` have?
Any other tips about what I might be doing wrong?
Jordi
