[petsc-users] PETSC ERROR in DMGetLocalBoundingBox?
Danyang Su
danyang.su at gmail.com
Sun Apr 30 01:57:43 CDT 2023
Hi Matt,
Just let you know that the error problem in DMGetLocalBoundingBox seems fixed in the latest dev version. I didn’t catch the error information any more.
Danyang
Date: Friday, March 17, 2023 at 11:02 AM
To: 'Matthew Knepley' <knepley at gmail.com>
Cc: <petsc-users at mcs.anl.gov>
Subject: RE: [petsc-users] PETSC ERROR in DMGetLocalBoundingBox?
Hi Matt,
I am following up to check if you can reproduce the problem on your side.
Thanks and have a great weekend,
Danyang
Sent: March 4, 2023 4:38 PM
To: Matthew Knepley <knepley at gmail.com>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] PETSC ERROR in DMGetLocalBoundingBox?
Hi Matt,
Attached is the source code and example. I have deleted most of the unused source code but it is still a bit length. Sorry about that. The errors come after DMGetLocalBoundingBox and DMGetBoundingBox.
-> To compile the code
Please type 'make exe' and the executable file petsc_bounding will be created under the same folder.
-> To test the code
Please go to fold 'test' and type 'mpiexec -n 1 ../petsc_bounding'.
-> The output from PETSc 3.18, error information
input file: stedvs.dat
global control parameters
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Corrupt argument: https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: Object already free: Parameter # 1
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.18.3, Dec 28, 2022
[0]PETSC ERROR: ../petsc_bounding on a linux-gnu-dbg named starblazer by dsu Sat Mar 4 16:20:51 2023
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mpich --download-scalapack --download-parmetis --download-metis --download-mumps --download-ptscotch --download-chaco --download-fblaslapack --download-hypre --download-superlu_dist --download-hdf5=yes --download-ctetgen --download-zlib --download-pnetcdf --download-cmake --with-hdf5-fortran-bindings --with-debugging=1
[0]PETSC ERROR: #1 VecGetArrayRead() at /home/dsu/Soft/petsc/petsc-3.18.3/src/vec/vec/interface/rvector.c:1928
[0]PETSC ERROR: #2 DMGetLocalBoundingBox() at /home/dsu/Soft/petsc/petsc-3.18.3/src/dm/interface/dmcoordinates.c:897
[0]PETSC ERROR: #3 /home/dsu/Work/bug-check/petsc_bounding/src/solver_ddmethod.F90:1920
Total volume of simulation domain 0.20000000E+01
-> The output from PETSc 3.17 and earlier, no error
Danyang
Date: Friday, March 3, 2023 at 8:58 PM
To: <danyang.su at gmail.com>
On Sat, Mar 4, 2023 at 1:35 AM <danyang.su at gmail.com> wrote:
Hi All,
I get a very strange error after upgrading PETSc version to 3.18.3, indicating some object is already free. The error is begin and does not crash the code. There is no error before PETSc 3.17.5 versions.
We have changed the way coordinates are handled in order to support higher order coordinate fields. Is it possible
to send something that we can run that has this error? It could be on our end, but it could also be that you are
destroying a coordinate vector accidentally.
Matt
!Check coordinates
call DMGetCoordinateDM(dmda_flow%da,cda,ierr)
CHKERRQ(ierr)
call DMGetCoordinates(dmda_flow%da,gc,ierr)
CHKERRQ(ierr)
call DMGetLocalBoundingBox(dmda_flow%da,lmin,lmax,ierr)
CHKERRQ(ierr)
call DMGetBoundingBox(dmda_flow%da,gmin,gmax,ierr)
CHKERRQ(ierr)
[0]PETSC ERROR: ../min3p-hpc-mpi-petsc-3.18.3 on a linux-gnu-dbg named starblazer by dsu Fri Mar 3 16:26:03 2023
[0]PETSC ERROR: #3 /home/dsu/Work/min3p-dbs-backup/src/project/makefile_p/../../solver/solver_ddmethod.F90:2140
Any suggestion on this?
Danyang
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230429/efec95eb/attachment-0001.html>
