[petsc-users] makefile error
Wed Apr 26 09:54:06 CDT 2023
yes - if you need mumps:
./configure --download-mpich --download-mumps --download-scalapack
make
make check
Also we recommend using latest petsc release - i.e petsc-3.19.0
Satish
On Wed, 26 Apr 2023, ­권승리 / 학생 / 항공우주공학과 wrote:
> thank you.
> As you said, I did run the command. But I didn't remove the "arch"
> directory.
> cd #petcs_dir
> make
> After that, makefile works well.
> But errors are occured like as below,
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: See https://petsc.org/release/overview/linear_solve_table/
> for possible LU and Cholesky solvers
> [0]PETSC ERROR: Could not locate solver type mumps for factorization type
> LU and matrix type seqaij. Perhaps you must ./configure with
> --download-mumps
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.18.5, unknown
> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksl Wed Apr
> 26 04:13:01 2023
> [0]PETSC ERROR: Configure options --download-mpich
> [0]PETSC ERROR: #1 MatGetFactor() at
> /home/ksl/petsc/src/mat/interface/matrix.c:4751
> [0]PETSC ERROR: #2 PCFactorSetUpMatSolverType_Factor() at
> /home/ksl/petsc/src/ksp/pc/impls/factor/factimpl.c:10
> [0]PETSC ERROR: #3 PCFactorSetUpMatSolverType() at
> /home/ksl/petsc/src/ksp/pc/impls/factor/factor.c:99
> [0]PETSC ERROR: #4 main() at /home/ksl/Downloads/coding_friction/a1.c:737
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> Then, can I download the mumps as the message?
> 2023년 4월 26일 (수) 오후 8:05, Matthew Knepley <knepley at gmail.com>님이 작성:
> > On Wed, Apr 26, 2023 at 6:42 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
> > wrote:
> >> Thank you for your reply.
> >> This problem occurred after I downloaded mpich.
> > This is not the reason. The error say "libpetsc is not located
> > in /home/ksl/petsc/arch-linux-c-debug/lib". So there is some reason it is
> > not there.
> >> Is there any way  to solve this problem? Or Do I have to reinstall PETSc?
> > Just rebuild
> >   cd $PETSC_DIR
> >   make
> >   Thanks,
> >      Matt
> >> Best regards
> >> Seung Lee Kwon
> >> 2023년 4월 26일 (수) 오후 7:05, Matthew Knepley <knepley at gmail.com>님이 작성:
> >>> On Wed, Apr 26, 2023 at 6:02 AM ­권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
> >>> wrote:
> >>>> Dear developers
> >>>> Could you recommend the error messages below?
> >>>> /home/ksl/petsc/arch-linux-c-debug/bin/mpicxx -Wall -Wwrite-strings
> >>>> -Wno-strict-aliasing -Wno-unknown-pragmas -Wno-lto-type-mismatch
> >>>> -fstack-protector -fvisibility=hidden -g -O0  -I/home/ksl/petsc/include
> >>>> -I/home/ksl/petsc/arch-linux-c-debug/include     -o app a1.o a2.o a3.o a4.o
> >>>> a5.o -Wl,-rpath,/home/ksl/petsc/arch-linux-c-debug/lib
> >>>> -L/home/ksl/petsc/arch-linux-c-debug/lib
> >>>> -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/9
> >>>> -L/usr/lib/gcc/x86_64-linux-gnu/9 -lpetsc -llapack -lblas -lpthread -lm
> >>>> -lstdc++ -ldl -lmpifort -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s
> >>>> -lquadmath -lstdc++ -ldl
> >>>> /usr/bin/ld: cannot find -lpetsc
> >>>> collect2: error: ld returned 1 exit status
> >>>> make: *** [makefile:33: app] Error 1
> >>> It could be
> >>> 1) Your build failed, so libpetsc was not produced
> >>> 2) arch-linux-c-debug is not the PETSC_ARCH that you built
> >>>   Thanks,
> >>>      Matt
> >>>> Best regards
> >>>> Seung Lee Kwon
> >>>> Seung Lee Kwon, Ph.D.Candidate
> >>>> Aerospace Structures and Materials Laboratory
> >>>> Department of Mechanical and Aerospace Engineering
> >>>> Seoul National University
> >>>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
> >>>> E-mail : ksl7912 at snu.ac.kr
> >>>> Office : +82-2-880-7389
> >>>> C. P : +82-10-4695-1062
> >>> What most experimenters take for granted before they begin their
> >>> experiments is infinitely more interesting than any results to which their
> >>> experiments lead.
> >>> -- Norbert Wiener
> >>> https://www.cse.buffalo.edu/~knepley/
> >>> <http://www.cse.buffalo.edu/~knepley/>
> > experiments lead.
> > -- Norbert Wiener
