[petsc-users] Question about linking LAPACK library
권승리 / 학생 / 항공우주공학과
ksl7912 at snu.ac.kr
Tue Apr 25 05:03:18 CDT 2023
Thank you for your reply.
I think I gave an example of an unrealistic problem.
I just wanted to know how to compute the inverse matrix, so I was wondering
if there is an example of computing the inverse matrix in PETSc.
Alternatively, I want to know how to link the LAPACK library.
best,
Seung Lee Kwon
2023년 4월 25일 (화) 오후 6:44, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Mon, Apr 24, 2023 at 11:47 PM 권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
> wrote:
>> Dear all
>> It depends on the problem. It can have hundreds of thousands of degrees
>> of freedom.
> Suppose your matrix was dense and had 1e6 dofs. The work to invert a
> matrix is O(N^3) with a small
> constant, so it would take 1e18 = 1 exaflop to invert this matrix and
> about 10 Terabytes of RAM to store
> it. Is this available to you? PETSc's supports Elemental and SCALAPACK for
> this kind of calculation.
> If the system is sparse, you could invert it using MUMPS, SuperLU_dist, or
> Pardiso. Then the work and
> storage depend on the density. There are good estimates for connectivity
> based on regular grids of given
> dimension. The limiting resource here is usually memory, which motivates
> people to try iterative methods.
> The convergence of iterative methods depend on detailed properties of your
> system, like the operator spectrum.
> Thanks,
> Matt
>> best,
>> Seung Lee Kwon
>> 2023년 4월 25일 (화) 오후 12:32, Barry Smith <bsmith at petsc.dev>님이 작성:
>>> How large are the dense matrices you would like to invert?
>>> On Apr 24, 2023, at 11:27 PM, 권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
>>> wrote:
>>> Dear all
>>> Hello.
>>> I want to make an inverse matrix like inv(A) in MATLAB.
>>> Are there some methods to inverse matrix in petsc?
>>> If not, I want to use the inverse function in the LAPACK library.
>>> Then, how to use the LAPACK library in petsc? I use the C language.
>>> Best,
>>> Seung Lee Kwon
>>> Seung Lee Kwon, Ph.D.Candidate
>>> Aerospace Structures and Materials Laboratory
>>> Department of Mechanical and Aerospace Engineering
>>> Seoul National University
>>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
>>> E-mail : ksl7912 at snu.ac.kr
>>> Office : +82-2-880-7389
>>> C. P : +82-10-4695-1062
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230425/282a4e46/attachment.html>
