[petsc-users] Fwd: Inquiry about the dual space (PetscFECreateTabulation_Basic)
Fri Apr 21 09:05:08 CDT 2023
On Fri, Apr 21, 2023 at 10:02 AM neil liu <liufield at gmail.com> wrote:
> Hello, Petsc group,
> I am learning the FE structure in Petsc by running case
> https://petsc.org/main/src/snes/tutorials/ex12.c.html with -run_type test
> -bc_type dirichlet -dm_plex_interpolate 0 -petscspace_degree 1
> -show_initial -dm_plex_print_fem 1
-dm_plex_print_fem 5 will print much more
> When I check the subroutine PetscFECreateTabulation_Basic, I can not
> understand some parameters there.
> For the following lines in the file (
> https://petsc.org/release//src/dm/dt/fe/impls/basic/febasic.c.html#PETSCFEBASIC
> 135:   PetscCall <https://petsc.org/release//manualpages/Sys/PetscCall/>(PetscDualSpaceGetDimension <https://petsc.org/release//manualpages/DUALSPACE/PetscDualSpaceGetDimension/>(fem->dualSpace, &pdim));136:   PetscCall <https://petsc.org/release//manualpages/Sys/PetscCall/>(PetscFEGetNumComponents <https://petsc.org/release//manualpages/FE/PetscFEGetNumComponents/>(fem, &Nc));
> Here, Nc = 2, pdim =6. I am running a scalar case with degree of 1,
> I expect Nc = 1 and pdim =3. Could you please explain this? In addition,
> Sure. I am guessing that you are looking at the tabulation for the
coordinate space. Here you are in 2 dimensions, so the
coordinate space has Nc = 2. For multicomponent spaces, we currently do not
represent it as a tensor product over the
scalar space, so we see 6 basis vectors.
     Matt
> Thanks,
> Xiaodong
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230421/782981e7/attachment-0001.html>
