[petsc-users] [petsc-maint] DMSwarm with periodic B.C.
    Matthew Knepley
    knepley at gmail.com
    Wed Apr 19 08:13:41 CDT 2023
If this is a problem, let's make an example and I can debug it because I
thought that this worked.
I might have only tested with Plex.
     Matt
On Wed, Apr 12, 2023 at 11:32 AM Mark Adams <mfadams at lbl.gov> wrote:
> First, you don't want a DMShell. Just use da_swarm.
> See src/dm/tutorials/ex20.c
> You can run this test with
> > cd src/dm/tutorials
> > make ex20
> > ./ex20
> or
> > ./ex20 -mode 1
> See the end of ex20.c for these (lack of) arguments
> Now change that code to one periodic direction and test.
> This could be a bug. This code is not well tested.
> Thanks,
> Mark
> On Wed, Apr 12, 2023 at 4:02 AM Joauma Marichal <
> joauma.marichal at uclouvain.be> wrote:
>> Hello,
>> I am using petsc DMSwarm library for some Lagrangian particle tracking.
>> Until now, I was working in a closed box and was therefore initializing my
>> swarm object as:
>> // Create a DMDA staggered and without ghost cells (for DMSwarm to work)
>> DMDACreate3d(PETSC_COMM_WORLD,DM_BOUNDARY_NONE, DM_BOUNDARY_NONE,
>> DM_BOUNDARY_NONE,DMDA_STENCIL_BOX,M,N,P,m,n,p,1,1,lx,ly,lz,da_swarm);
>> DMSetFromOptions(*da_swarm);
>> DMSetUp(*da_swarm);
>> PetscScalar xmin, xmax, ymin, ymax, zmin, zmax;
>> xmin = ymin = zmin = 0.;
>> xmax = ymax = zmax = 1.;
>> DMDASetUniformCoordinates(*da_swarm,xmin, xmax, ymin, ymax, zmin, zmax);
>> //SetNonUniform3DCoordinates(*da_swarm, cornp, gridp, rank);
>> /* Create a DMShell for point location purposes */
>> DMShellCreate(PETSC_COMM_WORLD,dmcell);
>> DMSetApplicationContext(*dmcell,*da_swarm);
>> (*dmcell)->ops->locatepoints = DMLocatePoints_DMDARegular;
>> (*dmcell)->ops->getneighbors = DMGetNeighbors_DMDARegular;
>> // Create a Swarm DMDA
>> DMCreate(PETSC_COMM_WORLD,swarm);
>> DMSetType(*swarm,DMSWARM);
>> DMSetDimension(*swarm,3);
>> DMSwarmSetType(*swarm,DMSWARM_PIC);
>> DMSwarmSetCellDM(*swarm,*dmcell);
>> I am now trying to work with periodic boundary conditions. I tried
>> replacing DM_BOUNDARY_NONE by DM_BOUNDARY_PERIODIC but it does not work…
>> I checked for examples using periodic B.C. but have not found any. Is it
>> possible? And if yes, how can I make it work?
>> Thanks a lot for your answer.
>> Best regards,
>> Joauma
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230419/71721c12/attachment-0001.html>
