[petsc-users] Using nonzero -pc_hypre_boomeramg_restriction_type in field split
Thu Apr 13 19:10:20 CDT 2023
On Thu, Apr 13, 2023 at 5:07 PM Alexander Lindsay <alexlindsay239 at gmail.com>
wrote:
> Here's the result.
>     0 KSP unpreconditioned resid norm 1.033076851740e+03 true resid norm
> 1.033076851740e+03 ||r(i)||/||b|| 1.000000000000e+00
>       Residual norms for fieldsplit_u_ solve.
>       0 KSP Residual norm           -nan
>       Residual norms for fieldsplit_p_ solve.
>       1 KSP Residual norm           -nan
>   Linear solve did not converge due to DIVERGED_PC_FAILED iterations 0
>                  PC failed due to SUBPC_ERROR
> I probably should have read the FAQ on `-fp_trap` before sending my first
> email.
I think this can be mailed to Hypre now. We do not interfere in
their SetUp, so I think it has to be on their side.
     Matt
> Working with this stack trace
>  (gdb) bt
> #0  0x00007fffe83a4286 in hypre_ParMatmul._omp_fn.1 () at
> par_csr_matop.c:1124
> #1  0x00007ffff4982a16 in GOMP_parallel () from
> /lib/x86_64-linux-gnu/libgomp.so.1
> #2  0x00007fffe83abfd1 in hypre_ParMatmul (A=<optimized out>, B=B at entry=0x55555da2ffa0)
> at par_csr_matop.c:967
> #3  0x00007fffe82f09bf in hypre_BoomerAMGSetup (amg_vdata=<optimized out>,
> A=<optimized out>, f=<optimized out>,
>     u=<optimized out>) at par_amg_setup.c:2790
> #4  0x00007fffe82d54f0 in HYPRE_BoomerAMGSetup (solver=<optimized out>,
> A=<optimized out>, b=<optimized out>,
>     x=<optimized out>) at HYPRE_parcsr_amg.c:47
> #5  0x00007fffe940d33c in PCSetUp_HYPRE (pc=<optimized out>)
>     at /home/lindad/projects/moose/petsc/src/ksp/pc/impls/hypre/hypre.c:418
> #6  0x00007fffe9413d87 in PCSetUp (pc=0x55555d5ef390)
>     at /home/lindad/projects/moose/petsc/src/ksp/pc/interface/precon.c:1017
> #7  0x00007fffe94f856b in KSPSetUp (ksp=ksp at entry=0x55555d5eecb0)
>     at /home/lindad/projects/moose/petsc/src/ksp/ksp/interface/itfunc.c:408
> #8  0x00007fffe94fa6f4 in KSPSolve_Private (ksp=ksp at entry=0x55555d5eecb0,
> b=0x55555d619730, x=<optimized out>)
>     at /home/lindad/projects/moose/petsc/src/ksp/ksp/interface/itfunc.c:852
> #9  0x00007fffe94fd8b1 in KSPSolve (ksp=ksp at entry=0x55555d5eecb0,
> b=<optimized out>, x=<optimized out>)
>     at
> /home/lindad/projects/moose/petsc/src/ksp/ksp/interface/itfunc.c:1086
> #10 0x00007fffe93d84a1 in PCApply_FieldSplit_Schur (pc=0x555555bef790,
> x=0x555556d5a510, y=0x555556d59e30)
>     at
> /home/lindad/projects/moose/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c:1185
> #11 0x00007fffe9414484 in PCApply (pc=pc at entry=0x555555bef790, x=x at entry=0x555556d5a510,
> y=y at entry=0x555556d59e30)
>     at /home/lindad/projects/moose/petsc/src/ksp/pc/interface/precon.c:445
> #12 0x00007fffe9415ad7 in PCApplyBAorAB (pc=0x555555bef790, side=PC_RIGHT,
> x=0x555556d5a510,
>     y=y at entry=0x555556e922a0, work=0x555556d59e30)
>     at /home/lindad/projects/moose/petsc/src/ksp/pc/interface/precon.c:727
> #13 0x00007fffe9451fcd in KSP_PCApplyBAorAB (w=<optimized out>,
> y=0x555556e922a0, x=<optimized out>,
>     ksp=0x555556068fc0) at
> /home/lindad/projects/moose/petsc/include/petsc/private/kspimpl.h:421
> #14 KSPGMRESCycle (itcount=itcount at entry=0x7fffffffcca0, ksp=ksp at entry
> =0x555556068fc0)
>     at
> /home/lindad/projects/moose/petsc/src/ksp/ksp/impls/gmres/gmres.c:162
> #15 0x00007fffe94536f9 in KSPSolve_GMRES (ksp=0x555556068fc0)
>     at
> /home/lindad/projects/moose/petsc/src/ksp/ksp/impls/gmres/gmres.c:247
> #16 0x00007fffe94fb1c4 in KSPSolve_Private (ksp=0x555556068fc0, b=b at entry=0x55555568e510,
> x=<optimized out>,
>     x at entry=0x55555607cce0) at
> /home/lindad/projects/moose/petsc/src/ksp/ksp/interface/itfunc.c:914
> #17 0x00007fffe94fd8b1 in KSPSolve (ksp=<optimized out>, b=b at entry=0x55555568e510,
> x=x at entry=0x55555607cce0)
>     at
> #18 0x00007fffe9582850 in SNESSolve_NEWTONLS (snes=0x555556065610)
>     at /home/lindad/projects/moose/petsc/src/snes/impls/ls/ls.c:225
> #19 0x00007fffe959c7ee in SNESSolve (snes=0x555556065610, b=0x0,
> x=<optimized out>)
>     at /home/lindad/projects/moose/petsc/src/snes/interface/snes.c:4809
> On Thu, Apr 13, 2023 at 1:54 PM Barry Smith <bsmith at petsc.dev> wrote:
>>   It would be useful to see the convergences inside the linear solve so
>> perhaps start with
>> -ksp_monitor_true_residual
>> -fieldsplit_u_ksp_type richardson    (this is to allow the monitor below
>> to work)
>> -fieldsplit_u_ksp_max_its 1
>> -fieldsplit_u_ksp_monitor
>> Perhaps others, Matt/Jed/Pierre/Stefano likely know better off the cuff
>> than me.
>> We should have a convenience option like -pc_fieldsplit_schur_monitor
>> similar to the -pc_fieldsplit_gkb_monitor
>> On Apr 13, 2023, at 4:33 PM, Alexander Lindsay <alexlindsay239 at gmail.com>
>> wrote:
>> Hi, I'm trying to solve steady Navier-Stokes for different Reynolds
>> numbers. My options table
>> -dm_moose_fieldsplit_names u,p
>> -dm_moose_nfieldsplits 2
>> -fieldsplit_p_dm_moose_vars pressure
>> -fieldsplit_p_ksp_type preonly
>> -fieldsplit_p_pc_type jacobi
>> -fieldsplit_u_dm_moose_vars vel_x,vel_y
>> -fieldsplit_u_ksp_type preonly
>> -fieldsplit_u_pc_hypre_type boomeramg
>> -fieldsplit_u_pc_type hypre
>> -pc_fieldsplit_schur_fact_type full
>> -pc_fieldsplit_schur_precondition selfp
>> -pc_fieldsplit_type schur
>> -pc_type fieldsplit
>> works wonderfully for a low Reynolds number of 2.2. The solver
>> performance crushes LU as I scale up the problem. However, not surprisingly
>> this options table struggles when I bump the Reynolds number to 220. I've
>> read that use of AIR (approximate ideal restriction) can improve
>> performance for advection dominated problems. I've tried
>> setting -pc_hypre_boomeramg_restriction_type 1 for a simple diffusion
>> problem and the option works fine. However, when applying it to my
>> field-split preconditioned Navier-Stokes system, I get immediate
>> non-convergence:
>>  0 Nonlinear |R| = 1.033077e+03
>>       0 Linear |R| = 1.033077e+03
>>   Linear solve did not converge due to DIVERGED_NANORINF iterations 0
>> Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0
>> Does anyone have an idea as to why this might be happening? If not, I'd
>> take a suggestion on where to set a breakpoint to start my own
>> investigation. Alternatively, I welcome other preconditioning suggestions
>> for an advection dominated problem.
>> Alex
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230413/00e8f7bd/attachment-0001.html>
