[petsc-users] Effect of -pc_gamg_threshold vs PETSc version
Jeremy Theler jeremy at seamplex.com
Thu Apr 13 07:17:19 CDT 2023
When using GAMG+cg for linear elasticity and providing the near
nullspace computed by MatNullSpaceCreateRigidBody(), I used to find
"experimentally" that a small value of -pc_gamg_threshold in the order
of 0.0001 would slightly decrease the solve time.
Starting with 3.18, I started seeing that any positive value for the
treshold would increase the solve time. I did a quick parametric
(serial) run solving an elastic problem with a matrix size of approx
570k x 570k for different values of GAMG threshold and different PETSc
versions (compiled with the same compiler, options and flags).
I noted that
 1. starting from 3.18, a threshold of 0.0001 that used to improve the
speed now worsens it.
 2. PETSc 3.17 looks like a "sweet spot" of speed
I would like to hear any comments you might have.
The wall time shown includes the time needed to read the mesh and
assemble the stiffness matrix. It is a refined version of the NAFEMS
LE10 benchmark described here:
https://seamplex.com/feenox/examples/mechanical.html#nafems-le10-thick-plate-pressure-benchmark
If you want, I could dump the matrix, rhs and near nullspace vectors
and share them.
jeremy theler
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230413/6912e270/attachment-0001.pdf>
15 30.06
16 30.44
17 26.29
18 28.61
19 29.65
15 29.23
16 29.54
17 24.70
18 29.44
19 30.58
15 30.11
16 30.51
17 25.80
18 32.68
19 33.78
15 31.68
16 31.96
17 26.98
18 43.36
19 44.24
15 36.74
16 37.06
17 31.96
18 69.54
19 70.14
