[petsc-users] MPI+OpenMP+MKL
Matthew Knepley
knepley at gmail.com
Fri Apr 7 14:25:11 CDT 2023
On Fri, Apr 7, 2023 at 2:26 PM Astor Piaz <appiazzolla at gmail.com> wrote:
> Hi Matthew, Jungchau,
> Thank you for your advice. The code still does not work, I give more
> details about it below, I can specify more about it as you wish.
> I am implementing a spectral method resulting in a block matrix where the
> off-diagonal blocks are Poincare-Steklov operators of
> impedance-to-impedance type.
> Those Poincare-Steklov operators have been created hierarchically merging
> subdomain operators (the HPS method), and I have a well tuned (but rather
> complex) OpenMP+MKL code that can apply this operator very fast.
> I would like to use PETSc's MPI-parallel GMRES solver with a MatShell that
> calls my OpenMP+MKL code, while each block can be in a different MPI
> process.
> At the moment the code runs correctly, except that PETSc is not letting my
> OpenMP+MKL code make the scheduling of threads as I choose.
PETSc does not say anything about OpenMP threads. However, maybe you need
to launch the executable with the correct OMP env variables?
Matt
> I am using
> ./configure --with-scalar-type=complex --prefix=../install/fast/
> --with-debugging=0 -with-openmp=1 --with-blaslapack-dir=${MKLROOT}
> --with-mkl_cpardiso-dir=${MKLROOT} --with-threadsafety --with-log=0
> COPTFLAGS=-g -Ofast CXXOPTFLAGS=-g -Ofast FOPTFLAGS=-g -Ofast
> Attached is an image of htop showing that the MKL threads are indeed being
> spawn, but they remain unused by the code. The previous calculations on the
> code show that it is capable of using OpenMP and MKL, only when PETSC
> KSPSolver is called MKL seems to be turned off.
> On Fri, Apr 7, 2023 at 8:10 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Apr 7, 2023 at 10:06 AM Astor Piaz <appiazzolla at gmail.com> wrote:
>>> Hello petsc-users,
>>> I am trying to use a code that is parallelized with a combination of
>>> OpenMP and MKL parallelisms, where OpenMP threads are able to spawn MPI
>>> processes.
>>> I have carefully scheduled the processes such that the right amount is
>>> launched, at the right time.
>>> When trying to use my code inside a MatShell (for later use in an FGMRES
>>> KSPSolver), MKL processes are not being used.
>>> I am sorry if this has been asked before.
>>> What configuration should I use in order to profit from MPI+OpenMP+MKL
>>> parallelism?
>> You should configure using --with-threadsafety
>> Thanks,
>> Matt
>>> Thank you!
>>> Astor
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230407/6af91930/attachment.html>
