[petsc-users] Installation issue of 3.18.* and 3.19.0 on Apple systems
Stefano Zampini
stefano.zampini at gmail.com
Wed Apr 5 15:32:07 CDT 2023
It seems there's some typo/error in the configure command that is being
executed. Can you post it here?
Il giorno mer 5 apr 2023 alle ore 23:18 Kaus, Boris <kaus at uni-mainz.de> ha
scritto:
> Hi everyone,
> I’m trying to install precompiled binaries for PETSc 3.18.5 & 3.19.0 using
> the BinaryBuilder cross-compilation:
> https://github.com/JuliaPackaging/Yggdrasil/pull/6533, which mostly works
> fine: https://buildkite.com/julialang/yggdrasil/builds/2093).
> Yet, on apple systems I receive a somewhat weird bug during the configure
> step:
> [22:08:49]
> [22:08:49] TypeError or ValueError possibly related to ERROR in
> COMMAND LINE ARGUMENT while running ./configure
> [22:08:49]
> [22:08:49] invalid literal for int() with base 10: ''
> [22:08:49]
> [22:08:49]
> [22:08:49]
> [22:08:49] /workspace/srcdir/petsc-3.18.0/lib/petsc/conf/rules:860:
> /workspace/srcdir/petsc-3.18.0//lib/petsc/conf/petscrules: No such file or
> directory
> [22:08:49] make[1]: *** No rule to make target
> '/workspace/srcdir/petsc-3.18.0//lib/petsc/conf/petscrules'. Stop.
> directory
> [22:08:49] make: *** [GNUmakefile:17:
> /workspace/srcdir/petsc-3.18.0//lib/petsc/conf/petscvariables] Error 2
> [22:08:49] make: *** Waiting for unfinished jobs....
> [22:08:49] make: *** [GNUmakefile:17: lib/petsc/conf/petscvariables] Error
> 2
> The log file is rather brief:
> sandbox:${WORKSPACE}/srcdir/petsc-3.18.0 # more configure.log
> Executing: uname -s
> stdout: Darwin
> It works fine for PETSc 3.16.5/3.17.5, and this first occurs in 3.18.0.
> Is there something that changed between 3.17 & 3.18 that could cause this?
> The build system seems to use python3.9 (3.4+ as required)
> Thanks!
> Boris
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230405/f8277abb/attachment-0001.html>
