[petsc-users] Questions about the PetscDSSetResidual and Nedelec element.
    Matthew Knepley
    knepley at gmail.com
    Wed Apr  5 10:16:33 CDT 2023
On Wed, Apr 5, 2023 at 10:36 AM neil liu <liufield at gmail.com> wrote:
> Thanks, Matt.
> When you said "P and P minus space" , do you have some references about
> this terminology to build the Hdiv and Hcurl for triangles or tetrahedra?
The canonical reference is
https://www-users.cse.umn.edu/~arnold//papers/acta.pdf but that was hard to
understand for me. There must
be a better reference but I do not know it.
     Matt
> On Wed, Apr 5, 2023 at 10:12 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Apr 5, 2023 at 10:00 AM neil liu <liufield at gmail.com> wrote:
>>> Thanks, Matt.
>>> 1) You mentioned that "PETSc calculates u_x, given the PetscFE and the
>>> coefficients (and the geometry).".
>>> Could you please direct me the source code that calculates u_x ?
>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/dt/fe/interface/fe.c#L2124
>>> 2) Yes. Raviart-Thomas is one type of Nedelec element (Hdiv also called
>>> divergence conforming). Do you support Hcurl (curl conforming) Nedelec
>>> element ?
>> Yes, you make them in the same way using the P and P^- spaces.
>>   Thanks,
>>       Matt
>>> On Tue, Apr 4, 2023 at 10:59 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Apr 4, 2023 at 10:45 AM neil liu <liufield at gmail.com> wrote:
>>>>> Hello,
>>>>> I am learning this case,
>>>>> https://petsc.org/release/src/snes/tutorials/ex62.c.html
>>>>> . And try to make myself familiar with the FEM (PetscFE) there.
>>>>> Then I have several questions.
>>>>> 1)  PetscDSSetResidual
>>>>> <https://petsc.org/release/manualpages/DT/PetscDSSetResidual/>,
>>>>> For example, line 291,  PetscCall
>>>>> <https://petsc.org/release/manualpages/Sys/PetscCall/>(
>>>>> PetscDSSetResidual
>>>>> <https://petsc.org/release/manualpages/DT/PetscDSSetResidual/>(ds, 0,
>>>>> f0_quadratic_u, f1_u)), here, f0_quadratic_u and f1_u is function
>>>>> pointers. Where have the input parameter for these functions been
>>>>> calculated, e.g., u_x.
>>>> Line 291 sets callback functions. These functions are actually called
>>>> in the loop over the mesh which calculates the residual.
>>>> PETSc calculates u_x, given the PetscFE and the coefficients (and the
>>>> geometry).
>>>>> If I want to check the values of these parameters before line 291, how
>>>>> to print that ?
>>>> I output many thing with -dm_plex_print_fem 5, but I am not sure if I
>>>> print out the field jet. It would be easy to add.
>>>>> 2) Does PetscFE support Nedelec element? Will it be painful to add
>>>>> these modules myself ?
>>>> What kind? I think we support them, but have no tests. Take a look at
>>>> our support for Raviart-Thomas
>>>> https://gitlab.com/petsc/petsc/-/blob/main/src/dm/dt/dualspace/impls/lagrange/tutorials/ex1.c#L78
>>>> and see a use case here
>>>>   https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex24.c
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks ,
>>>>> Xiaodong
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230405/95584838/attachment.html>
