[petsc-users] Problem setting Fieldsplit fields
Nicolas Barnafi nbarnafi at cmm.uchile.cl
Tue Apr 4 15:02:31 CDT 2023
Hi Matt,
One further question on this. I am working on the code now, but have one
issue.
The IS I grab from all fields need to be set to the sub PCs, but they
will have a local ordering of the dofs. Is there a tool in PETSc to make
this coherent? I.e. if I will set the IS fields '0,4,7' to a a subPC
object within the Fieldsplit structure, how to build a new PC such that
setting
PCSetFieldIS(pc, '0', field[0])
PCSetFieldIS(pc, '1', field[4])
PCSetFieldIS(pc, '2', field[7])
makes sense in the new subPC?
Thanks for the help.
Best,
NB
On 22-02-23 14:54, Nicolas Barnafi wrote:
> Hi Matt,
> Sorry for the late answer, it was holiday time.
>> Just to clarify, if you call SetIS() 3 times, and then give
>>   -pc_fieldsplit_0_fields 0,2
>> then we should reduce the number of fields to two by calling
>> ISConcatenate() on the first and last ISes?
> Exactly
>> I think this should not be hard. It will work exactly as it does on
>> the DM case, except the ISes will come from
>> the PC, not the DM. One complication is that you will have to hold the
>> new ISes until the end, and then set them.
>>    Thanks,
>>      Matt
> Nice, then it is exactly what I want. I will work on it, and create a PR
> when things are starting to fit in.
> Best,
> NB
