[petsc-users] MPI linear solver reproducibility question
Mark McClure
mark at resfrac.com
Sun Apr 2 11:35:50 CDT 2023
Ok, good to know. I'll update to latest Petsc, and do some testing, and let
you know either way.
On Sun, Apr 2, 2023 at 6:31 AM Jed Brown <jed at jedbrown.org> wrote:
> Vector communication used a different code path in 3.13. If you have a
> reproducer with current PETSc, I'll have a look. Here's a demo that the
> solution is bitwise identical (the sha256sum is the same every time you run
> it, though it might be different on your computer from mine due to compiler
> version and flags).
> $ mpiexec -n 8 ompi/tests/snes/tutorials/ex5 -da_refine 3 -snes_monitor
> -snes_view_solution binary && sha256sum binaryoutput
> 0 SNES Function norm 1.265943996096e+00
> 1 SNES Function norm 2.831564838232e-02
> 2 SNES Function norm 4.456686729809e-04
> 3 SNES Function norm 1.206531765776e-07
> 4 SNES Function norm 1.740255643596e-12
> 5410f84e91a9db3a74a2ac33603bbbb1fb48e7eaf739614192cfd53344517986
> binaryoutput
> Mark McClure <mark at resfrac.com> writes:
> > In the typical FD implementation, you only set local rows, but with FE
> and
> > sometimes FV, you also create values that need to be communicated and
> > summed on other processors.
> > Makes sense.
> > Anyway, in this case, I am certain that I am giving the solver bitwise
> > identical matrices from each process. I am not using a preconditioner,
> > using BCGS, with Petsc version 3.13.3.
> > So then, how can I make sure that I am "using an MPI that follows the
> > suggestion for implementers about determinism"? I am using MPICH version
> > 3.3a2, didn't do anything special when installing it. Does that sound OK?
> > If so, I could upgrade to the latest Petsc, try again, and if confirmed
> > that it persists, could provide a reproduction scenario.
> >> > Thank you, I will try BCGSL.
> >> > And good to know that this is worth pursuing, and that it is possible.
> >> Step
> >> > 1, I guess I should upgrade to the latest release on Petsc.
> >> > How can I make sure that I am "using an MPI that follows the
> suggestion
> >> for
> >> > implementers about determinism"? I am using MPICH version 3.3a2.
> >> > I am pretty sure that I'm assembling the same matrix every time, but
> I'm
> >> > not sure how it would depend on 'how you do the communication'. Each
> >> > process is doing a series of MatSetValues with INSERT_VALUES,
> >> > assembling the matrix by rows. My understanding of this process is
> that
> >> > it'd be deterministic.
> and
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230402/51b61fa5/attachment.html>
