[petsc-users] PETSc usage issues
wangzj997
wangzj997 at foxmail.com
Tue Sep 27 22:47:36 CDT 2022
Dear PETSc development team:
Currently, I am learning and trying to use PETSc's KSP to solve large-scale sparse linear systems Ax= b, where A is symmetric positive definite and nonsingular. However, the main diagonal of A contains many 0 items, which leads to the fact that many preconditioners cannot be used when using MPI for multi-process solution, and the number of iterations is large, and the convergence is slow. May I ask how to solve this problem? If it is necessary to make the main diagonal of A all non-zero items, is there any solution in PETSc?
I would be grateful if you would reply and answer my question.
Best Regards.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220928/301fe064/attachment.html>
