[petsc-users] Problem solving Ax=b with rectangular matrix A
fujisan fujisan43 at gmail.com
Mon Sep 26 02:06:25 CDT 2022
Thank you Pierre,
I used PCNONE along with KSPLSQR and it worked.
But as for PCQR, it cannot be found. There is nothing about it in the
documentation as well.
Fuji
On Wed, Sep 21, 2022 at 12:20 PM Pierre Jolivet <pierre at joliv.et> wrote:
> Yes, but you need to use a KSP that handles rectangular Mat, such as
> KSPLSQR (-ksp_type lsqr).
> PCLU does not handle rectangular Pmat. The only PC that handle rectangular
> Pmat are PCQR, PCNONE.
> If you supply the normal equations as the Pmat for LSQR, then you can use
> “standard” PC.
> You can have a look at
> https://petsc.org/main/src/ksp/ksp/tutorials/ex27.c.html that covers most
> of these cases.
> Thanks,
> Pierre
> (sorry for the earlier answer sent wrongfully to petsc-maint, please
> discard the previous email)
> On 21 Sep 2022, at 10:03 AM, fujisan <fujisan43 at gmail.com> wrote:
> I'm trying to solve Ax=b with a sparse rectangular matrix A (of size 33x17
> in my test) using
> options '-ksp_type stcg -pc_type lu' on 1 or 2 cpus.
> And I always get an error saying "Incompatible vector local lengths" (see
> below).
> Here is the relevant lines of my code:
> program test
>     ! Variable declarations
>     PetscCallA(PetscInitialize(PETSC_NULL_CHARACTER,ierr))
>     PetscCall(MatCreate(PETSC_COMM_WORLD,A,ierr))
>     PetscCall(MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,m,n,ierr))
>     PetscCall(MatSetType(A,MATMPIAIJ,ierr))
>     PetscCall(MatSetFromOptions(A,ierr))
>     PetscCall(MatSetUp(A,ierr))
>     PetscCall(MatGetOwnershipRange(A,istart,iend,ierr))
>     do irow=istart,iend-1
>         ... Reading from file ...
>         PetscCall(MatSetValues(A,1,irow,nzv,col,val,ADD_VALUES,ierr))
>     enddo
>     PetscCall(MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr))
>     PetscCall(MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr))
>     ! Creating vectors x and b
>     PetscCallA(MatCreateVecs(A,x,b,ierr))
>     ! Duplicating x in u.
>     PetscCallA(VecDuplicate(x,u,ierr))
>     ! u is used to calculate b
>     PetscCallA(VecSet(u,1.0,ierr))
>     PetscCallA(VecAssemblyBegin(u,ierr))
>     PetscCallA(VecAssemblyEnd(u,ierr))
>     ! Calculating Au = b
>     PetscCallA(MatMult(A,u,b,ierr)) ! A.u = b
>     PetscCallA(KSPSetType(ksp,KSPCG,ierr))
>     PetscCallA(KSPSetOperators(ksp,A,A,ierr))
>     PetscCallA(KSPSetFromOptions(ksp,ierr))
>     ! Solving Ax = b, x unknown
>     PetscCallA(KSPSolve(ksp,b,x,ierr))
>     PetscCallA(VecDestroy(x,ierr))
>     PetscCallA(VecDestroy(u,ierr))
>     PetscCallA(VecDestroy(b,ierr))
>     PetscCallA(MatDestroy(A,ierr))
>     PetscCallA(KSPDestroy(ksp,ierr))
>     call PetscFinalize(ierr)
> end program
> The code reads a sparse matrix from a binary file.
> I also output the sizes of matrix A and vectors b, x, u.
> They all seem consistent.
> What am I doing wrong?
> Is it possible to solve Ax=b with A rectangular?
> Thank you in advance for your help.
> Have a nice day.
> Fuji
>  Matrix size : m=          33  n=          17  cpu size:            1
>  Size of matrix A  :           33          17
>  Size of vector b :           33
>  Size of vector x :           17
>  Size of vector u :           17
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Arguments are incompatible
> [0]PETSC ERROR: Incompatible vector local lengths parameter # 1 local size
> 33 != parameter # 2 local size 17
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.17.4-1341-g91b2b62a00
> GIT Date: 2022-09-15 19:26:07 +0000
> [0]PETSC ERROR: ./bin/solve on a x86_64 named master by fujisan Tue Sep 20
> 16:56:37 2022
> [0]PETSC ERROR: Configure options --with-petsc-arch=x86_64 --COPTFLAGS="-g
> -O3" --FOPTFLAGS="-g -O3" --CXXOPTFLAGS="-g -O3" --with-debugging=0
> --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort
> --with-single-library=1 --with-mpiexec=mpiexec --with-precision=double
> --with-fortran-interfaces=1 --with-make=1 --with-mpi=1
> --with-mpi-compilers=1 --download-fblaslapack=0 --download-hypre=1
> --download-cmake=0 --with-cmake=1 --download-metis=1 --download-parmetis=1
> --download-ptscotch=0 --download-suitesparse=1 --download-triangle=1
> --download-superlu=1 --download-superlu_dist=1 --download-scalapack=1
> --download-mumps=1 --download-elemental=1 --download-spai=0
> --download-parms=1 --download-moab=1 --download-chaco=0 --download-fftw=1
> --with-petsc4py=1 --download-mpi4py=1 --download-saws
> --download-concurrencykit=1 --download-revolve=1 --download-cams=1
> --download-p4est=0 --with-zlib=1 --download-mfem=1 --download-glvis=0
> --with-opengl=0 --download-libpng=1 --download-libjpeg=1 --download-slepc=1
> --download-hpddm=1 --download-bamg=1 --download-mmg=0 --download-parmmg=0
> --download-htool=1 --download-egads=0 --download-opencascade=0
> PETSC_ARCH=x86_64
> [0]PETSC ERROR: #1 VecCopy() at
> /data/softs/petsc/src/vec/vec/interface/vector.c:1607
> [0]PETSC ERROR: #2 KSPSolve_BiCG() at
> /data/softs/petsc/src/ksp/ksp/impls/bicg/bicg.c:40
> [0]PETSC ERROR: #3 KSPSolve_Private() at
> /data/softs/petsc/src/ksp/ksp/interface/itfunc.c:877
> [0]PETSC ERROR: #4 KSPSolve() at
> /data/softs/petsc/src/ksp/ksp/interface/itfunc.c:1048
> [0]PETSC ERROR: #5 solve.F90:218
> Abort(75) on node 0 (rank 0 in comm 16): application called
> MPI_Abort(MPI_COMM_SELF, 75) - process 0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220926/771ec8cd/attachment-0001.html>
