[petsc-users] C++ error! MPI_Finalize() could not be located!
Laryssa Abdala
la.abdala at gmail.com
Sun Sep 25 16:30:02 CDT 2022
Amazing. Thank you so much for your clear explanation, Barry!
Laryssa
On Sun, Sep 25, 2022 at 5:06 PM Barry Smith <bsmith at petsc.dev> wrote:
> It appears you want to use MPI (if not pass --with-mpi=0 also).
> Thus you must either
> 1) have the MPI compiler wrappers in your path (mpicc, mpicxx,
> mpif90) or use --with-mpi-dir=somedirectory where MPI is installed and do
> NOT provide the compiler names (since MPI provides compiler wrappers). or
> 2) use the current configure options and add --download-mpich to have
> MPI installed for you.
> Barry
> > On Sep 25, 2022, at 4:49 PM, Laryssa Abdala <la.abdala at gmail.com> wrote:
> > Hello,
> > I am trying to configure PETSc and have been getting the following
> message:
> > TESTING: CxxMPICheck from
> config.packages.MPI(config/BuildSystem/config/packages/MPI.py:416)
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> for details):
> > I attached my configure.log file. Any suggestions on how to fix this
> issue would be appreciated.
> > Thanks,
> > Laryssa
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220925/f0c58606/attachment.html>
