[petsc-users] Slepc, shell matrix, parallel, halo exchange
Matthew Knepley
knepley at gmail.com
Wed Sep 21 09:36:26 CDT 2022
On Wed, Sep 21, 2022 at 10:35 AM feng wang <snailsoar at hotmail.com> wrote:
> Hi Jose,
> For your 2nd suggestion on halo exchange, I get the idea and roughly know
> how to do it, but there are some implementation details which I am not
> quite sure.
> If I understand it correctly, in MatMult(Mat m ,Vec x, Vec y), Vec *x* is
> a normal parallel vector and it does not contain halo values. Suppose I
> create an auxiliary ghost vector * x_g*, then I assign the values of *x*
> to *x_g*. The values of the halo for each partition will not be assigned
> at this stage.
> But If I call VecGhostUpdateBegin/End(*x_g*, INSERT_VALUES,
> SCATTER_FORWARD), this will fill the values of the halo cells of *x_g *for
> each partition. Then *x_g* has local and halo cells assigned correctly
> and I can use *x_g* to do my computation. Is this what you mean?
Yes
Matt
> Thanks,
> Feng
> *From:* Jose E. Roman <jroman at dsic.upv.es>
> *Sent:* 21 September 2022 13:07
> *To:* feng wang <snailsoar at hotmail.com>
> *Cc:* Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov <
> petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Slepc, shell matrix, parallel, halo exchange
> > El 21 sept 2022, a las 14:47, feng wang <snailsoar at hotmail.com>
> escribió:
> > Thanks Jose, I will try this and will come back to this thread if I have
> any issue.
> > Besides, for EPSGetEigenpair, I guess each rank gets its portion of the
> eigenvector, and I need to put them together afterwards?
> Eigenvectors are stored in parallel vectors, which are used in subsequent
> parallel computation in most applications. If for some reason you need to
> gather them in a single MPI process you can use e.g.
> VecScatterCreateToZero()
> > Thanks,
> > Feng
> > From: Jose E. Roman <jroman at dsic.upv.es>
> > Sent: 21 September 2022 12:34
> > To: feng wang <snailsoar at hotmail.com>
> > Cc: Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov <
> > Subject: Re: [petsc-users] Slepc, shell matrix, parallel, halo exchange
> > If you define the MATOP_CREATE_VECS operation in your shell matrix so
> that it creates a ghost vector, then all vectors within EPS will be ghost
> vectors, including those that are received as arguments of MatMult(). Not
> sure if this will work.
> > A simpler solution is that you store a ghost vector in the context of
> your shell matrix, and then in MatMult() you receive a regular parallel
> vector x, then update the ghost points using the auxiliary ghost vector, do
> the computation and store the result in the regular parallel vector y.
> > Jose
> > > El 21 sept 2022, a las 14:09, feng wang <snailsoar at hotmail.com>
> escribió:
> > > Thanks for your reply.
> > > For GMRES, I create a ghost vector and give it to KSPSolve. For Slepc,
> it only takes the shell matrix for EPSSetOperators. Suppose the shell
> matrix of the eigensolver defines MatMult(Mat m ,Vec x, Vec y), how does it
> know Vec x is a ghost vector and how many ghost cells there are?
> > > Thanks,
> > > Feng
> > > From: Matthew Knepley <knepley at gmail.com>
> > > Sent: 21 September 2022 11:58
> > > Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> > > On Wed, Sep 21, 2022 at 7:41 AM feng wang <snailsoar at hotmail.com>
> wrote:
> > > Hello,
> > > I am using Slepc with a shell matrix. The sequential version seems
> working and now I am trying to make it run in parallel.
> > > The partition of the domain is done, I am not sure how to do the halo
> exchange in the shell matrix in Slepc. I have a parallel version of
> matrix-free GMRES in my code with Petsc. I was using VecCreateGhostBlock to
> create vector with ghost cells, and then used VecGhostUpdateBegin/End for
> the halo exchange in the shell matrix, would this be the same for Slepc?
> > > That will be enough for the MatMult(). You would also have to use a
> SLEPc EPS that only needed MatMult().
> > > Thanks,
> > > Matt
> > > Thanks,
> > > Feng
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220921/781d5237/attachment-0001.html>
