[petsc-users] multiple definition of `main' for a fortran example
erhan turan
turane at gmail.com
Fri Sep 9 06:56:24 CDT 2022
Hello,
I recently installed the latest version of Petsc and tried to build a case
with two fortran files (One main and one subroutine). I looked into similar
examples and found one in petsc/src/dm/tutorials: ex13f90.F90. This code
also needs a second file called ex13f90aux.F90
When I tried to build this example with "make ex13f90", I receive this
error warning:
src/dm/tutorials/ex13f90.F90:24: multiple definition of `main'
src/dm/tutorials/ex13f90.F90:24: first defined here
Hence, I was unable to run an example case from the tutorials folder. I
tested in two different pc's, one with Ubuntu 16 and one with Ubuntu 18.
Both cases use gnu compilers. Also test both mpich and openmpi.
Are there anyone that saw a similar problem who knows a workaround to
resolve this issue? Maybe a makefile example with multiple fortran files
would be useful. Thanks.
Best,
Erhan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220909/50b96c09/attachment.html>
