[petsc-users] Make error --download-hdf5-fortran-bindings=1
Park, Heeho heepark at sandia.gov
Thu Sep 8 19:38:12 CDT 2022
Hi PETSc Developers,
I am having trouble compiling with the --download-hdf5-fortran-bindings=yes option on Sandia’s HPC system.
It compiles with make version 3.82, but fails to compile with make version 4.2.1 in the environment.
The issues I’m having redirecting to make version 3.82 while having the more recent versions of gnu compilers like gnu/10.2.1
Is there a way around this? By the way, adding --download-make=1 did not help
Attached is the configure log. Thank you for your help.
heepark at boca1:/projects/ADSM/software/petsc-v3.17.2$ make -v
GNU Make 4.2.1
Built for x86_64-redhat-linux-gnu
Copyright (C) 1988-2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
heepark at boca1:/projects/ADSM/software/petsc-v3.17.2$ ./run_configure_gnu_O.sh
                         Configuring PETSc to compile on your system
            Running configure on HDF5; this may take several minutes
Running make on HDF5; this may take several minutes
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Error running make; make install on HDF5
Best,
Heeho D. Park, Ph.D.
   Computational Scientist & Engineer
    Center for Energy & Earth Systems
    Applied Systems Analysis and Research Dept.
   Sandia National Laboratories
   Email: heepark at sandia.gov<mailto:heepark at sandia.gov>
   Web: Homepage<https://www.linkedin.com/in/heeho-daniel-park-1a628517/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220909/bfe46112/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220909/bfe46112/attachment-0001.obj>
