[petsc-users] PETSc with gcc/gfortran
Han Tran tranduchan at gmail.com
Tue Sep 6 10:59:51 CDT 2022
I used to compile my Fortran 90 code using intel compilers (i.e. intel and impi). However, when I tried to compile using gcc, it gave the following error.
  use petscksp
      1
Fatal Error: File 'petscksp.mod' opened at (1) is not a GNU Fortran module file
It would be appreciated if you could give any hints on this issue. Thank you so much!
-Han
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220906/95cba8f1/attachment.html>
