[petsc-users] KSP on GPU
Barry Smith
bsmith at petsc.dev
Sun Oct 30 14:52:30 CDT 2022
In general you should expect similar but not identical conference behavior.
I suggest running with all the monitoring you can. -ksp_monitor_true_residual -fieldsplit_0_monitor_true_residual -fieldsplit_1_monitor_true_residual and compare the various convergence between the CPU and GPU. Also run with -ksp_view and check that the various solver options are the same (they should be).
Barry
> On Oct 30, 2022, at 11:02 AM, Carl-Johan Thore via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi,
> I'm solving a topology optimization problem with Stokes flow discretized by a stabilized Q1-Q0 finite element method
> and using BiCGStab with the fieldsplit preconditioner to solve the linear systems. The implementation
> is based on DMStag, runs on Ubuntu via WSL2, and works fine with PETSc-3.18.1 on multiple CPU cores and the following
> options for the preconditioner:
> -fieldsplit_0_ksp_type preonly \
> -fieldsplit_0_pc_type gamg \
> -fieldsplit_0_pc_gamg_reuse_interpolation 0 \
> -fieldsplit_1_ksp_type preonly \
> -fieldsplit_1_pc_type jacobi
> However, when I enable GPU computations by adding two options -
> -dm_vec_type cuda \
> -dm_mat_type aijcusparse \
> - KSP still works fine the first couple of topology optimization iterations but then
> stops with "Linear solve did not converge due to DIVERGED_DTOL ..".
> My question is whether I should expect the GPU versions of the linear solvers and pre-conditioners
> to function exactly as their CPU counterparts (I got this impression from the documentation),
> in which case I've probably made some mistake in my own code, or whether there are other/additional
> settings or modifications I should use to run on the GPU (an NVIDIA Quadro T2000)?
> Kind regards,
> Carl-Johan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221030/68d1da64/attachment.html>
