[petsc-users] PETSc Windows Installation
Matthew Knepley
knepley at gmail.com
Fri Oct 28 08:30:31 CDT 2022
On Fri, Oct 28, 2022 at 9:11 AM Mohammad Ali Yaqteen <mhyaqteen at sju.ac.kr>
wrote:
> Dear Sir,
> During the Installation of PETSc in windows, I installed Cygwin and the
> required libraries as mentioned on your website:
> However, when I install PETSc using the configure commands present on the
> petsc website:
> ./configure --with-cc=gcc --with-cxx=0 --with-fc=0
> --download-f2cblaslapack --download-mpich
> it gives me the following error:
> I already installed OpenMPI using Cygwin installer but it still asks me
> to. When I configure without “—download-mpich” and run “make check”
> command, it gives me the following errors:
> Could you kindly look into this and help me with this? Your prompt
> response will highly be appreciated.
The runs look fine.
The test should not try to attach the debugger. Do you have that in the
PETSC_OPTIONS env variable?
Matt
> Thank you!
> Mohammad Ali
> Researcher, Sejong University
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221028/69ee1d65/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221028/69ee1d65/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221028/69ee1d65/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221028/69ee1d65/attachment-0005.png>
