[petsc-users] Report Bug TaoALMM class
Stephan Köhler stephan.koehler at math.tu-freiberg.de
Fri Oct 28 03:27:47 CDT 2022
Dear PETSc/Tao team,
it seems to be that there is a bug in the TaoALMM class:
In the methods TaoALMMSubsolverObjective_Private and
TaoALMMSubsolverObjectiveAndGradient_Private the vector where the
function value for the augmented Lagrangian is evaluate
is copied into the current solution, see, e.g.,
https://petsc.org/release/src/tao/constrained/impls/almm/almm.c.html
line 672 or 682.  This causes subsolver routine to not converge if the
line search for the subsolver rejects the step length 1. for some
update.  In detail:
Suppose the current iterate is xk and the current update is dxk. The
line search evaluates the augmented Lagrangian now at (xk + dxk).  This
causes that the value (xk + dxk) is copied in the current solution.  If
the point (xk + dxk) is rejected, the line search should
try the point (xk + alpha * dxk), where alpha < 1.  But due to the
copying, what happens is that the point ((xk + dxk) + alpha * dxk) is
evaluated, see, e.g.,
https://petsc.org/release/src/tao/linesearch/impls/armijo/armijo.c.html
line 191.
Best regards
Stephan Köhler
Stephan Köhler
TU Bergakademie Freiberg
Institut für numerische Mathematik und Optimierung
Akademiestraße 6
09599 Freiberg
Gebäudeteil Mittelbau, Zimmer 2.07
Telefon: +49 (0)3731 39-3173 (Büro)
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221028/d8bfc018/attachment-0001.bin>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221028/d8bfc018/attachment-0001.sig>
