[petsc-users] basis/basisDer/Jac in FE
Mark Adams
mfadams at lbl.gov
Thu Oct 27 11:23:17 CDT 2022
Area of a unit triangle is (1x1)/2 I would guess.
On Thu, Oct 27, 2022 at 11:32 AM Yann Jobic <yann.jobic at univ-amu.fr> wrote:
> Hello,
> I'm trying to understand how to use the lowlevel Petsc Finit Element
> Framework. I've got few questions about it.
> 1) I'm checking the determinant of the Jacobian transformation from real
> space to the parametric one. The source code is in :
> https://petsc.org/main/src/dm/impls/plex/plexgeometry.c.html#DMPlexComputeTriangleGeometry_Internal
> I don't quite understand the 0.5 factor in front of it.
> Geometrically, it should be the ratio of the area/volume of the reel
> element over the referenced one. It's not the case here no ?
> It seems that, for other elements, this factor still applies.
> What this factor represent ?
> 2) I only checked triangle elements here. The ordering of the test
> functions and its derivatives is different it seems, with also the 0.5
> factor. Am i mistaken ?
> I could not find any informations about it in the user-doc. Maybe it's
> written somewhere else ?
> Many Thanks,
> Best regards,
> Yann
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221027/8fb19a99/attachment.html>
