[petsc-users] Periodic boundary condition
Fri Oct 21 06:49:45 CDT 2022
On Thu, Oct 20, 2022 at 10:27 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Some of the valgrind information does not appear to make sense
> PetscMemcpy() is not calling SNESSolve() so I suspect there must be some
> serious corruption of something to this impossible stack trace
I ran Valgrind on it, and it looks like it could be a bug in MatFD
tau/w=26225.459!
initial!
copy!
Write output at step= 0!
==51148== Invalid write of size 4
==51148==    at 0x105D22252: MatFDColoringSetUpBlocked_AIJ_Private
(fdaij.c:149)
==51148==    by 0x105D2402C: MatFDColoringSetUp_SeqXAIJ (fdaij.c:281)
==51148==    by 0x10678B2B2: MatFDColoringSetUp (fdmatrix.c:234)
==51148==    by 0x108738AE5: SNESComputeJacobianDefaultColor (snesj2.c:95)
==51148==    by 0x1086E2F31: SNESComputeJacobian (snes.c:2804)
==51148==    by 0x1084A8AA0: SNESSolve_NEWTONLS (ls.c:207)
==51148==    by 0x1087097B9: SNESSolve (snes.c:4689)
==51148==    by 0x1088A22F7: TSTheta_SNESSolve (theta.c:174)
==51148==    by 0x108888568: TSStep_Theta (theta.c:210)
==51148==    by 0x1089FD12B: TSStep (ts.c:3445)
==51148==    by 0x108A08112: TSSolve (ts.c:3836)
==51148==    by 0x100009F83: main (one.c:392)
==51148==  Address 0x16905b000 is not stack'd, malloc'd or (recently) free'd
When I remove PERIODIC from the DM, this goes away.
     Matt
> ==236074==    by 0x6FD160F: SNESSolve (snes.c:4569)
> ==236074==    by 0x711917E: PetscMemcpy (bdf.c:223)
> From
> ==236074== Conditional jump or move depends on uninitialised value(s)
> ==236074==    at 0x5F10977: MatFDColoringSetUpBlocked_AIJ_Private
> (fdaij.c:146)
> ==236074==    by 0x5F10977: MatFDColoringSetUp_SeqXAIJ.A (fdaij.c:284)
> ==236074==    by 0x585892A: MatFDColoringSetUp (fdmatrix.c:242)
> ==236074==    by 0x6FE5037: SNESComputeJacobianDefaultColor (snesj2.c:79)
> ==236074==    by 0x6FC8E4E: SNESComputeJacobian (snes.c:2717)
> ==236074==    by 0x70236E7: SNESSolve_NEWTONTR (tr.c:324)
> ==236074==    by 0x711917E: PetscCitationsRegister (petscsys.h:2689)
> ==236074==    by 0x711917E: TSStep_BDF.A (bdf.c:265)
> ==236074==    by 0x70C363A: TSStep (ts.c:3757)
> ==236074==    by 0x70C1999: TSSolve (ts.c:4154)
> ==236074==    by 0x402594: main (one.c:391)
> I suggest you run with -malloc_debug instead of valgrind and see if any
> errors are reported. If so you can add the macro CHKMEMQ; inside your
> function evaluation where you write to memory to see if anything is writing
> to the wrong location. For example wherever you assign aF such as
> aF[j][i].vx=(x3+x4+x5+x6+x7+x8+x9-x1-x2)*user->hx;
> this can help you determine the exact line number where you are writing to
> the wrong location and determine what might be the cause.
> On Oct 20, 2022, at 6:45 PM, Sepideh Kavousi <kavousi at mines.edu> wrote:
> Hello,
> I want to solve my 5 PDEs based on finite  difference method using
> periodic BC in x-direction and non-periodic in y-direction but I run into
> error (Segmentation Violation, probably memory access out of range).
> For this, I discretize my equation in FormFunction function. My PDE
> discretization in (i,j) node needs data on (i+1,j), (i+2,j), (i-1,j),
> (i-2,j), (i,j+1), (i,j+2), (i,j-1), (i,j-2) points.
> In my previous codes that the x-direction was non-periodic (no flux)
> boundary condition, I:
> i)                    implemented the no flux BC for i=0 and i=Nx-1,
> ii)                   set i+2= Nx-1 in discretizing (Nx-2,j) and i+2= 0
> in discretizing (1,j)
> iii)                 discretized my equation for i=1..Nx-2.
> I am not sure how I should do the periodic BC. From the following
> discussions (
> https://lists.mcs.anl.gov/pipermail/petsc-users/2012-May/013476.html  and
> https://lists.mcs.anl.gov/pipermail/petsc-users/2016-May/029273.html), I
> guess I should not do step (i) (stated above) for the x-boundaries and just
> do step (iii) for i=0..Nx-1. If I just focus on solving 2 of the PDEs which
> does need data on (i+2,j), (i-2,j), (i,j+2), (i,j-2) points for
> discretizing equation in (i,j) node, I still run into error:
> Running with Valgrind (just 1 processor) gave the following file. I did
> not find any information which gives me hint on the error source.
> Can you please help me to find the error?
> Best,
> Sepideh
> ==236074==    at 0x4C29E39: malloc (vg_replace_malloc.c:309)
> ==236074==    by 0x1B79E59B: MPID_Init (mpid_init.c:1649)
> ==236074==    by 0x1B73FAEA: MPIR_Init_thread (initthread.c:717)
> ==236074==    by 0x1B73D795: PMPI_Init_thread (initthread.c:1061)
> ==236074==    by 0x5264A94: PetscInitialize (pinit.c:907)
> ==236074==    by 0x40219D: main (one.c:335)
> ==236074==
> ==236074==    at 0x2183B805: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x218323C1: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x218341C7: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x400F9C2: _dl_init (in /usr/lib64/ld-2.17.so)
> ==236074==    by 0x401459D: dl_open_worker (in /usr/lib64/ld-2.17.so)
> ==236074==    by 0x400F7D3: _dl_catch_error (in /usr/lib64/ld-2.17.so)
> ==236074==    by 0x4013B8A: _dl_open (in /usr/lib64/ld-2.17.so)
> ==236074==    by 0x1AEA4FAA: dlopen_doit (in /usr/lib64/libdl-2.17.so)
> ==236074==    by 0x1AEA55AC: _dlerror_run (in /usr/lib64/libdl-2.17.so)
> ==236074==    by 0x1AEA5040: dlopen@@GLIBC_2.2.5 (in /usr/lib64/
> libdl-2.17.so)
> ==236074==    by 0x1B8198DC: MPID_nem_ofi_init (ofi_init.c:158)
> ==236074==    by 0x1B7B5C55: ??? (mpid_nem_init.c:231)
> ==236074==    by 0x1B7B3F92: MPID_nem_init_ckpt (mpid_nem_init.c:954)
> ==236074==    by 0x1B580640: MPIDI_CH3_Init (ch3_init.c:125)
> ==236074==    by 0x1B79F02D: MPID_Init (mpid_init.c:1857)
> ==236074==
> ==236074==    at 0x2183B810: ??? (in /usr/lib64/libpsm2.so.2.2)
> libdl-2.17.so)
> ==236074==
> ==236074==    at 0x218323C8: ??? (in /usr/lib64/libpsm2.so.2.2)
> libdl-2.17.so)
> ==236074==
> ==236074== Use of uninitialised value of size 8
> ==236074==    at 0x218323CF: ??? (in /usr/lib64/libpsm2.so.2.2)
> libdl-2.17.so)
> ==236074==
> ==236074==    at 0x218323E5: ??? (in /usr/lib64/libpsm2.so.2.2)
> libdl-2.17.so)
> ==236074==
> ==236074==    by 0x218343EC: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x2180E4F3: psm2_init (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x2112D7E6: psmx2_getinfo (in
> /opt/apps/libfabric/1.7.0/lib/libfabric.so.1.10.0)
> ==236074==    by 0x210AC753: fi_getinfo@@FABRIC_1.2 (in
> ==236074==    by 0x1B819AB7: MPID_nem_ofi_init (ofi_init.c:245)
> ==236074==
> ==236074==
> ==236074==
> ==236074==
> ==236074==
> ==236074==    at 0x2183B69A: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x218371EC: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x21837077: hfi_get_port_lid (in
> ==236074==    by 0x21836F9A: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x21834872: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x217F7F5D: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x217FDC29: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x217FCA91: psm2_ep_open (in /usr/lib64/libpsm2.so.2.2)
> ==236074==    by 0x2112FB19: psmx2_trx_ctxt_alloc (in
> ==236074==    by 0x21138089: psmx2_ep_open (in
> ==236074==    by 0x1B81A6A1: fi_endpoint (fi_endpoint.h:155)
> ==236074==    by 0x1B81A6A1: MPID_nem_ofi_init (ofi_init.c:377)
> ==236074==
> ==236074==    at 0x2183B7B8: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==
> ==236074==    by 0x217F88C8: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==
> ==236074==
> ==236074==    by 0x217F916B: ??? (in /usr/lib64/libpsm2.so.2.2)
> ==236074==
> ==236074==
> ==236074==    at 0x1B1DA260: __I_MPI___intel_sse2_strncmp (in
> /opt/intel/compilers_and_libraries_2018.2.199/linux/mpi/intel64/lib/libmpifort.so.12.0)
> ==236074==    by 0x1B8CFBA1: ??? (simple_pmi.c:2376)
> ==236074==    by 0x1B8CBDAD: PMIi_InitIfSingleton (simple_pmi.c:2883)
> ==236074==    by 0x1B8CBDAD: iPMI_KVS_Get (simple_pmi.c:751)
> ==236074==    by 0x1B7CCC1E: ??? (mpidi_pg.c:949)
> ==236074==    by 0x1B817EAA: MPID_nem_ofi_post_init (ofi_init.c:1736)
> ==236074==    by 0x1B7B3575: MPID_nem_init_post (mpid_nem_init.c:1421)
> ==236074==    by 0x1B5806E3: MPIDI_CH3_Init (ch3_init.c:146)
> ==236074==
> ==236074==    at 0x1B1DA383: __I_MPI___intel_sse2_strncmp (in
> ==236074==
> ==236074==    at 0x1E48032E: __intel_sse4_strcpy (in
> /opt/intel/compilers_and_libraries_2018.2.199/linux/compiler/lib/intel64_lin/libirc.so)
> ==236074==    by 0x51FD8BE: PetscStrcpy (str.c:354)
> ==236074==    by 0x51FD7A3: PetscStrallocpy (str.c:188)
> ==236074==    by 0x52A39CE: PetscEventRegLogRegister (eventlog.c:313)
> ==236074==    by 0x527D89A: PetscLogEventRegister (plog.c:693)
> ==236074==    by 0x6A56A20: PCBDDCInitializePackage (bddc.c:3115)
> ==236074==    by 0x6E1A515: PCInitializePackage (dlregisksp.c:59)
> ==236074==    by 0x6DB1A86: PCCreate (precon.c:382)
> ==236074==    by 0x6E05167: KSPGetPC (itfunc.c:1837)
> ==236074==    by 0x6E0FC5C: KSPSetDM (iterativ.c:1150)
> ==236074==    by 0x6FDD27B: SNESSetDM (snes.c:5402)
> ==236074==    by 0x70B85F7: TSGetSNES (ts.c:2914)
> ==236074==    by 0x70BE430: TSSetDM (ts.c:4949)
> ==236074==    by 0x402496: main (one.c:378)
> ==236074==
> ==236074==    at 0x1E4782BA: __intel_ssse3_strncpy (in
> ==236074==    by 0x51FFD24: PetscStrncpy (str.c:392)
> ==236074==    by 0x51FEB03: PetscStrreplace (str.c:1142)
> ==236074==    by 0x52C9958: PetscViewerFileSetName (filev.c:659)
> ==236074==    by 0x52B743B: PetscViewerVTKOpen (vtkv.c:279)
> ==236074==    by 0x70C76E6: TSMonitorSolutionVTK (ts.c:5580)
> ==236074==    by 0x40313C: FormFunction (one.c:120)
> ==236074==    by 0x7066531: TSComputeIFunction_DMDA (dmdats.c:82)
> ==236074==    by 0x70BA5EF: TSComputeIFunction (ts.c:857)
> ==236074==    by 0x711E2DC: SNESTSFormFunction_BDF (bdf.c:368)
> ==236074==    by 0x70C6E46: SNESTSFormFunction (ts.c:5014)
> ==236074==    by 0x6FDC8A6: SNESComputeFunction (snes.c:2383)
> ==236074==    by 0x7023556: SNESSolve_NEWTONTR (tr.c:297)
> ==236074==
> ==236074==    by 0x5224E4B: PetscFOpen (mpiuopen.c:52)
> ==236074==    by 0x63A074B: DMDAVTKWriteAll_VTS.A (grvtk.c:72)
> ==236074==    by 0x639A589: DMDAVTKWriteAll (grvtk.c:545)
> ==236074==    by 0x52B66F3: PetscViewerFlush_VTK (vtkv.c:100)
> ==236074==    by 0x52CFAAE: PetscViewerFlush (flush.c:26)
> ==236074==    by 0x52CEA95: PetscViewerDestroy (view.c:113)
> ==236074==    by 0x70C7717: TSMonitorSolutionVTK (ts.c:5582)
> ==236074==
> (fdaij.c:146)
> ==236074==
> ==236074== Invalid write of size 4
> ==236074==    at 0x5F10983: MatFDColoringSetUpBlocked_AIJ_Private
> (fdaij.c:150)
> ==236074==    by 0x5F10983: MatFDColoringSetUp_SeqXAIJ.A (fdaij.c:284)
> ==236074==  Address 0x3a94fa80 is 0 bytes after a block of size 73,960,000
> alloc'd
> ==236074==    at 0x4C2C480: memalign (vg_replace_malloc.c:909)
> ==236074==    by 0x522FFE2: PetscMallocAlign (mal.c:52)
> ==236074==    by 0x52305F9: PetscMallocA (mal.c:418)
> ==236074==    by 0x5F10778: MatFDColoringSetUpBlocked_AIJ_Private
> (fdaij.c:125)
> ==236074==    by 0x5F10778: MatFDColoringSetUp_SeqXAIJ.A (fdaij.c:284)
> ==236074==
> ==236074== Invalid write of size 8
> ==236074==    at 0x5F10991: MatFDColoringSetUpBlocked_AIJ_Private
> (fdaij.c:151)
> ==236074==    by 0x5F10991: MatFDColoringSetUp_SeqXAIJ.A (fdaij.c:284)
> ==236074==  Address 0x3a94fa88 is 8 bytes after a block of size 73,960,000
> alloc'd
> (fdaij.c:125)
> ==236074==
> Sent from Mail <https://go.microsoft.com/fwlink/?LinkId=550986> for
> Windows
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221021/3c8afa57/attachment-0001.html>
