[petsc-users] how to reuse Mumps factorization
袁煕
yuanxi at advancesoft.jp
Wed Oct 19 19:50:46 CDT 2022
Got it.
Thanks for your detailed explanation.
YUAN
2022年10月19日(水) 23:58 Barry Smith <bsmith at petsc.dev>:
> Every time a matrix entry gets changes PETSc tracks these changes so
> for the next KSP by default solve it repeats the numerical factorization if
> the matrix has changed. Otherwise it reuses the still current
> factorization.
> If you are calling KSP directly, you can call
> KSPSetReusePreconditioner() to prevent KSP from automatically performing a
> new factorization, so it will use the out-of-date preconditioner but if you
> use a KSPType of, for example, KSPGMRES, it will still solve the linear
> system correctly just taking some iterations. Reusing the preconditioner
> can be faster if the matrix does not change too much since a numerical
> factorization takes a lot of time
> If you use SNES you can control "lagging" the preconditioner
> with SNESSetLagPreconditioner()
> Barry
> On Oct 19, 2022, at 9:15 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Oct 19, 2022 at 9:13 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>> Hello,
>> I am using Mumps to solve a problem with multiple time steps. The matrix
>> structure does not change but its value may or may not change during
>> those steps. That means I should reuse the symbolic factorization but
>> recall numeric factorization when needed.
>> I have found the following anwser of a similar question
>> https://lists.mcs.anl.gov/pipermail/petsc-users/2020-August/041846.html
>> which says "it automatically uses the same factorization", but I don't
>> know if it includes numerical factorization also.
>> My question is :
>> 1. Does numeric factorization do automatically? If not
> Yes.
> Thanks,
> Matt
>> 2. Could I control when numeric factorization should be done and how to
>> do it?
>> Much thanks
>> YUAN
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221020/3ee83a08/attachment.html>
