[petsc-users] Some questions about KSP type and PC type selection
Jackie Chan
chenlonglong0099 at 163.com
Wed Oct 19 10:30:54 CDT 2022
Dear All,
I hope you're having a nice day.
In finite element problems, the stiffness matrix and load vector are constructed to calculate the displacement vector using DMCreateMatrix and DMCreateGlobalVector, respectively. For some reason, I need to make sure that the displacements of nodes on the opposite edges of two-dimensional structured grid domain satisfy relative displacement condition. For example, the displacements of two points with natural coordinates (x,Ymin) and (x,Ymax), i.e. the points are located on the upper and lower edges of 2D grid domain and have the same x-coordinates, are equal respectively. To achieve this, I need to add particularly big numbers to specific entries in stiffness matrix. In this way, the positions of big numbers are usually far away from each other and belong to different processes. I have tried many KSP types and PC settings to solve displacement vector. However, the final results are mostly incorrect. The best solver type I have tried is cg, but it still has some problems like excessive time consuming and convergence steps. So, for this problem, what kind of KSP type and PC type are suitable? Or is there a way to speed up the calculation process?
Jackie Chan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221019/fc3333ba/attachment.html>
