[petsc-users] compiling with Intel 2022.3
Pierre Jolivet
pierre at joliv.et
Fri Oct 14 02:57:39 CDT 2022
Or you can use the up-to-date release branch, cf. https://gitlab.com/petsc/petsc/-/merge_requests/5727
Pierre
> On 14 Oct 2022, at 9:52 AM, Martin Diehl <martin.diehl at kuleuven.be> wrote:
> FYI: Classic Intel compilers/MPI wrappers give a warning that confuses
> configure.py. The solution is to add "-diag-disable=10441" when
> invoking the compiler.
> source:
> https://community.intel.com/t5/Intel-C-Compiler/undefined-reference-for-2022-3-mpiicc/td-p/1420526
> KU Leuven
> Department of Computer Science
> Department of Materials Engineering
> Celestijnenlaan 200a
> 3001 Leuven, Belgium
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221014/1f51ce14/attachment.html>
