[petsc-users] DMLocalToLocal with DMPlex in Fortran
Mike Michell mi.mike1021 at gmail.com
Tue Oct 11 17:04:47 CDT 2022
Thank you for the reply and checking.
Indeed, it seems that local-to-local halo is still not implemented for
DMPlex. But I believe this is a very required feature for large 3D
simulations with DMPlex.
Would you mind if I ask for any estimated timeline to fix this issue and
put it on the official version of PETSc? If I remember correctly, we had a
similar discussion a few months ago.
Mike
On Mon, Oct 10, 2022 at 10:41 PM Mike Michell <mi.mike1021 at gmail.com> wrote:
>> Hi, I was wondering if there is any comment on the example file that I
>> can refer to.
> I see the problem. Local2Local is not implemented for Plex. I thought we
> had this automated, but it was only
> coded for DMDA. It is a fairly mechanical transformation of the
> Global2Local, just remapping indices, but it
> will take some time since there is a lot of backlog this semester.
> I have fixed the error message so now it is obvious what the problem is.
>   Thanks,
>       Matt
>> Thanks,
>> Mike
>>> Thank you for the reply.
>>> Sure, a short example code is attached here with a square box mesh and a
>>> run script.
>>> Inside the source, you may find two versions of halo exchange; one is
>>> for local to global (Version-1) and another one is for local to local
>>> (Version-2), which is not working in my case.
>>> In the output.vtu, you will see the halo exchanged vector resolved to
>>> each vertex with (myrank + 1), so if the code is running with 2procs, at
>>> the parallel boundary, you will see 3. In this example, there is no ghost
>>> layer.
>>> Thanks,
>>> Mike
>>>> On Sat, Oct 1, 2022 at 8:51 PM Mike Michell <mi.mike1021 at gmail.com>
>>>> wrote:
>>>>> Thank you for the reply. There is that file in
>>>>> src/dm/interface/ftn-auto/ for me, instead of the path you mentioned.
>>>>> After "make allfortranstubs" was done and, PETSc reconfigured and
>>>>> reinstalled.
>>>>> However, I still have the same problem at the line in which
>>>>> DMLocalToLocalBegin() is used. What I am doing to setup halo exchange is as
>>>>> follows;
>>>>> - declare DMPlex
>>>>> - PetscSectionCreate()
>>>>> - PetscSectionSetNumFields()
>>>>> - PetscSectionSetFieldComponents()
>>>>> - PetscSectionSetChart()
>>>>> - do loop over dofs: PetscSectionSetDof() and PetscSectionSetFieldDof()
>>>>> - PetscSectionSetUp()
>>>>> - DMSetLocalSection()
>>>>> - PetscSectionDestroy()
>>>>> - DMGetSectionSF()
>>>>> - PetscSFSetUp()
>>>>> Then, the halo exchange is performed as follows;
>>>>> - DMGetLocalVector()
>>>>> - Fill the local vector
>>>>> - DMLocalToLocalBegin() --(*)
>>>>> - DMLocalToLocalEnd()
>>>>> - DMRestoreLocalVector()
>>>>> Then, the code crashes at (*).
>>>> Can you send something I can run? Then I will find the problem and fix
>>>> it.
>>>>   Thanks,
>>>>      Matt
>>>>> Previously(at the time PETSc did not support LocalToLocal for DMPlex
>>>>> in Fortran), the part above, "DMLocalToLocalBegin() and
>>>>> DMLocalToLocalEnd()", consisted of;
>>>>> - DMLocalToGlobalBegin()
>>>>> - DMLocalToGlobalEnd()
>>>>> - DMGlobalToLocalBegin()
>>>>> - DMGlobalToLocalEnd()
>>>>> and it worked okay.
>>>>> I am unclear which part is causing the problem. Shall I define the
>>>>> PetscSection and PetscSF in different ways in case of Local to Local Halo
>>>>> exchange?
>>>>> Any comment will be appreciated.
>>>>> Thanks,
>>>>> Mike
>>>>>> On Fri, Sep 30, 2022 at 4:14 PM Mike Michell <mi.mike1021 at gmail.com>
>>>>>> wrote:
>>>>>>> Hi,
>>>>>>> As a follow-up to this email thread,
>>>>>>> https://www.mail-archive.com/petsc-users@mcs.anl.gov/msg44070.html
>>>>>>> Are DMLocalToLocalBegin() and DMLocalToLocalEnd() really available
>>>>>>> for DMPlex with Fortran on the latest version of PETSc (3.17.99 from
>>>>>>> GitLab)? Matt commented that the Fortran bindings were updated so that
>>>>>>> those functions must be available in the latest version of PETSc, however,
>>>>>>> it seems still they are not working from my test with DMPlex in Fortran.
>>>>>>> Can anyone provide some comments? Probably I am missing some mandatory
>>>>>>> header file? Currently, I have headers;
>>>>>>> #include "petsc/finclude/petscvec.h"
>>>>>>> #include "petsc/finclude/petscdmplex.h"
>>>>>>> #include "petsc/finclude/petscdmlabel.h"
>>>>>>> #include "petsc/finclude/petscdm.h"
>>>>>> The source for these functions is in
>>>>>>   src/dm/ftn-auto/dmf.c
>>>>>> Is it there for you? If not, you can run
>>>>>> Fortran functions are not declared, so the header should not matter
>>>>>> for compilation, just the libraries for linking.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thanks,
>>>>>>> Mike
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221012/573f0e2b/attachment.html>
