[petsc-users] suppress CUDA warning & choose MCA parameter for mpirun during make PETSC_ARCH=arch-linux-c-debug check
Junchao Zhang junchao.zhang at gmail.com
Mon Oct 10 08:52:42 CDT 2022
On Mon, Oct 10, 2022 at 8:13 AM Rob Kudyba <rk3199 at columbia.edu> wrote:
> OK, let's walk back and don't use -DCMAKE_C_COMPILER=/path/to/mpicc
> Will do
>> libompitrace.so.40.30.0 is not the OpenMP library; it is the tracing
>> library for OpenMPI, https://github.com/open-mpi/ompi/issues/10036
> Does that mean I should remove this option in the cmake command?
>> In your previous email, there was
>> /path/to/cmake/cmake-3.22.1-linux-x86_64/bin/cmake -E cmake_link_script
>> CMakeFiles/wtm.x.dir/link.txt --verbose=1
>> /cm/local/apps/gcc/10.2.0/bin/c++ -isystem -O3 -g -Wall -Wextra
>> -pedantic -Wshadow CMakeFiles/wtm.x.dir/src/WTM.cpp.o -o wtm.x
>>  -Wl,-rpath,/path/to/WTM/build/common/richdem:/path/to/
>> gdal-3.3.0/lib:/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_
>> support/lib:/path/to/petsc/arch-linux-cxx-debug/lib libwtm.a
>> common/richdem/librichdem.so /path/to/gdal-3.3.0/lib/libgdal.so
>> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libompitrace.so.40.30.0
>> common/fmt/libfmt.a /path/to/petsc/arch-linux-cxx-debug/lib/libpetsc.so
>> /usr/bin/ld: CMakeFiles/wtm.x.dir/src/WTM.cpp.o: undefined reference to
>> symbol 'ompi_mpi_comm_self'
>> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libmpi.so.40: error
>> adding symbols: DSO missing from command line
>> Let's try to add -lmpi (or /path/to/openmpi-4.1.1_ucx_
>> cuda_11.0.3_support/lib/libmpi.so) manually to see if it links
>> -lmpi
> so just adding that to the make command? Sttil seeing linking errors:
>  make VERBOSE=1 LDFLAGS="-Wl,--copy-dt-needed-entries" -lmpi
 make VERBOSE=1 LDFLAGS="-Wl,--copy-dt-needed-entries -lmpi"
/path/to/cmake/cmake-3.22.1-linux-x86_64/bin/cmake -S/path/to/WTM
> -B/path/to/WTM/build --check-build-system CMakeFiles/Makefile.cmake 0
> /path/to/cmake/cmake-3.22.1-linux-x86_64/bin/cmake -E cmake_progress_start
> /path/to/WTM/build/CMakeFiles /path/to/WTM/build//CMakeFiles/progress.marks
> make  -f CMakeFiles/Makefile2 all
> make[1]: Entering directory '/path/to/WTM/build'
> make  -f common/fmt/CMakeFiles/fmt.dir/build.make
> common/fmt/CMakeFiles/fmt.dir/depend
> make[2]: Entering directory '/path/to/WTM/build'
> cd /path/to/WTM/build &&
> /path/to/cmake/cmake-3.22.1-linux-x86_64/bin/cmake -E cmake_depends "Unix
> Makefiles" /path/to/WTM /path/to/WTM/common/fmt /path/to/WTM/build
> /path/to/WTM/build/common/fmt
> /path/to/WTM/build/common/fmt/CMakeFiles/fmt.dir/DependInfo.cmake --color=
> make[2]: Leaving directory '/path/to/WTM/build'
> [  4%] Building CXX object common/fmt/CMakeFiles/fmt.dir/src/format.cc.o
> cd /path/to/WTM/build/common/fmt && /cm/local/apps/gcc/10.2.0/bin/c++
>  -I/path/to/WTM/common/fmt/include -isystem -std=gnu++11 -MD -MT
> common/fmt/CMakeFiles/fmt.dir/src/format.cc.o -MF
> CMakeFiles/fmt.dir/src/format.cc.o.d -o CMakeFiles/fmt.dir/src/format.cc.o
> -c /path/to/WTM/common/fmt/src/format.cc
> [  8%] Building CXX object common/fmt/CMakeFiles/fmt.dir/src/os.cc.o
> common/fmt/CMakeFiles/fmt.dir/src/os.cc.o -MF
> CMakeFiles/fmt.dir/src/os.cc.o.d -o CMakeFiles/fmt.dir/src/os.cc.o -c
> /path/to/WTM/common/fmt/src/os.cc
> [ 12%] Linking CXX static library libfmt.a
> /path/to/cmake/cmake-3.22.1-linux-x86_64/bin/cmake -P
> CMakeFiles/fmt.dir/cmake_clean_target.cmake
> CMakeFiles/fmt.dir/link.txt --verbose=1
> /usr/bin/ar qc libfmt.a CMakeFiles/fmt.dir/src/format.cc.o
> /usr/bin/ranlib libfmt.a
> [ 12%] Built target fmt
> make  -f common/richdem/CMakeFiles/richdem.dir/build.make
> common/richdem/CMakeFiles/richdem.dir/depend
> Makefiles" /path/to/WTM /path/to/WTM/common/richdem /path/to/WTM/build
> /path/to/WTM/build/common/richdem/CMakeFiles/richdem.dir/DependInfo.cmake
> --color=
> [ 16%] Building CXX object
> common/richdem/CMakeFiles/richdem.dir/src/richdem.cpp.o
> cd /path/to/WTM/build/common/richdem && /cm/local/apps/gcc/10.2.0/bin/c++
> -Drichdem_EXPORTS -I/path/to/WTM/common/richdem/include
> -I/path/to/gdal-3.3.0/include -isystem -fPIC
> -DRICHDEM_GIT_HASH=\"3313b290725509d694da1fba83d0f32cca68cc70\"
> -DRICHDEM_COMPILE_TIME=\"2022-10-10T13:09:39Z\" -DUSEGDAL -Xpreprocessor
> -fopenmp
> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libmpi.so.40.30.1
> -I/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/include -std=gnu++17 -MD
> -MT common/richdem/CMakeFiles/richdem.dir/src/richdem.cpp.o -MF
> CMakeFiles/richdem.dir/src/richdem.cpp.o.d -o
> CMakeFiles/richdem.dir/src/richdem.cpp.o -c
> /path/to/WTM/common/richdem/src/richdem.cpp
> c++: warning:
> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libmpi.so.40.30.1:
> linker input file unused because linking not done
> [ 20%] Building CXX object
> common/richdem/CMakeFiles/richdem.dir/src/random.cpp.o
> -fopenmp
> -MT common/richdem/CMakeFiles/richdem.dir/src/random.cpp.o -MF
> CMakeFiles/richdem.dir/src/random.cpp.o.d -o
> CMakeFiles/richdem.dir/src/random.cpp.o -c
> /path/to/WTM/common/richdem/src/random.cpp
> c++: warning:
> [ 25%] Building CXX object
> common/richdem/CMakeFiles/richdem.dir/src/gdal.cpp.o
> -fopenmp
> -MT common/richdem/CMakeFiles/richdem.dir/src/gdal.cpp.o -MF
> CMakeFiles/richdem.dir/src/gdal.cpp.o.d -o
> CMakeFiles/richdem.dir/src/gdal.cpp.o -c
> /path/to/WTM/common/richdem/src/gdal.cpp
> c++: warning:
> [ 29%] Building CXX object
> common/richdem/CMakeFiles/richdem.dir/src/terrain_generation/terrain_generation.cpp.o
> -fopenmp
> -MT
> -MF
> CMakeFiles/richdem.dir/src/terrain_generation/terrain_generation.cpp.o.d -o
> CMakeFiles/richdem.dir/src/terrain_generation/terrain_generation.cpp.o -c
> /path/to/WTM/common/richdem/src/terrain_generation/terrain_generation.cpp
> c++: warning:
> [ 33%] Building CXX object
> common/richdem/CMakeFiles/richdem.dir/src/terrain_generation/PerlinNoise.cpp.o
> -fopenmp
> -MT
> -MF CMakeFiles/richdem.dir/src/terrain_generation/PerlinNoise.cpp.o.d -o
> CMakeFiles/richdem.dir/src/terrain_generation/PerlinNoise.cpp.o -c
> /path/to/WTM/common/richdem/src/terrain_generation/PerlinNoise.cpp
> c++: warning:
> [ 37%] Linking CXX shared library librichdem.so
> CMakeFiles/richdem.dir/link.txt --verbose=1
> /cm/local/apps/gcc/10.2.0/bin/c++ -fPIC -isystem -shared
> -Wl,-soname,librichdem.so -o librichdem.so
>  -Wl,-rpath,/path/to/gdal-3.3.0/lib:/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib:
> /lib/../lib64/crt1.o: In function `_start':
> (.text+0x24): undefined reference to `main'
> CMakeFiles/richdem.dir/src/random.cpp.o: In function
> `richdem::rand_engine()':
> random.cpp:(.text+0x45): undefined reference to `omp_get_thread_num'
> `richdem::seed_rand(unsigned long)':
> random.cpp:(.text+0xb6): undefined reference to `GOMP_parallel'
> `richdem::uniform_rand_int(int, int)':
> random.cpp:(.text+0x10c): undefined reference to `omp_get_thread_num'
> `richdem::uniform_rand_real(double, double)':
> random.cpp:(.text+0x1cb): undefined reference to `omp_get_thread_num'
> `richdem::normal_rand(double, double)':
> random.cpp:(.text+0x29e): undefined reference to `omp_get_thread_num'
> `richdem::seed_rand(unsigned long) [clone ._omp_fn.0]':
> random.cpp:(.text+0x4a3): undefined reference to `GOMP_critical_start'
> random.cpp:(.text+0x4b1): undefined reference to `GOMP_critical_end'
> random.cpp:(.text+0x4c3): undefined reference to `omp_get_thread_num'
> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libompitrace.so.40.30.0:
> undefined reference to `PMPI_Comm_rank'
> undefined reference to `PMPI_Get_address'
> undefined reference to `PMPI_Comm_get_name'
> undefined reference to `PMPI_Add_error_string'
> undefined reference to `PMPI_Type_get_name'
> undefined reference to `PMPI_Abort'
> undefined reference to `PMPI_Alloc_mem'
> undefined reference to `PMPI_Isend'
> undefined reference to `PMPI_Barrier'
> undefined reference to `PMPI_Allgather'
> undefined reference to `PMPI_Reduce'
> undefined reference to `PMPI_Send'
> undefined reference to `PMPI_Init'
> undefined reference to `PMPI_Type_size'
> undefined reference to `PMPI_Accumulate'
> undefined reference to `PMPI_Add_error_class'
> undefined reference to `PMPI_Finalize'
> undefined reference to `PMPI_Allgatherv'
> undefined reference to `PMPI_Bcast'
> undefined reference to `PMPI_Recv'
> undefined reference to `PMPI_Request_free'
> undefined reference to `PMPI_Allreduce'
> undefined reference to `ompi_mpi_comm_world'
> undefined reference to `PMPI_Sendrecv'
> undefined reference to `PMPI_Add_error_code'
> undefined reference to `PMPI_Win_get_name'
> collect2: error: ld returned 1 exit status
> make[2]: *** [common/richdem/CMakeFiles/richdem.dir/build.make:163:
> common/richdem/librichdem.so] Error 1
> make[1]: *** [CMakeFiles/Makefile2:306:
> common/richdem/CMakeFiles/richdem.dir/all] Error 2
> make[1]: Leaving directory '/path/to/WTM/build'
> make: *** [Makefile:136: all] Error 2
>> On Sun, Oct 9, 2022 at 9:28 PM Rob Kudyba <rk3199 at columbia.edu> wrote:
>>> I did have -DMPI_CXX_COMPILER set, so I added -DCMAKE_C_COMPILER and
>>> now get these errors:
>>> [ 25%] Linking CXX shared library librichdem.so
>>> I took a guess at using -DOpenMP_libomp_LIBRARY="/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libompitrace.so.40.30.0"
>>> as
>>> as otherwise I'd get:
>>> CMake Error at
>>> /path/to/cmake/cmake-3.22.1-linux-x86_64/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:230
>>> (message):
>>>   Could NOT find OpenMP_CXX (missing: OpenMP_libomp_LIBRARY
>>>   OpenMP_libomp_LIBRARY) (found version "4.5")
>>> So perhaps that's the real problem?
>>> On Sun, Oct 9, 2022 at 9:31 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> In the last link step to generate the executable
>>>> I did not find -lmpi to link in the mpi library.  You can try to use  cmake
>>>> -DCMAKE_C_COMPILER=/path/to/mpicc  -DCMAKE_CXX_COMPILER=/path/to/mpicxx to
>>>> build your code
>>>> On Sat, Oct 8, 2022 at 9:32 PM Rob Kudyba <rk3199 at columbia.edu> wrote:
>>>>> Perhaps we can back one step:
>>>>>> Use your mpicc to build a "hello world" mpi test, then run it on a
>>>>>> compute node (with GPU) to see if it works.
>>>>>> If no, then your MPI environment has problems;
>>>>>> If yes, then use it to build petsc (turn on petsc's gpu support,
>>>>>>  --with-cuda  --with-cudac=nvcc), and then your code.
>>>>>> --Junchao Zhang
>>>>> OK tried this just to eliminate that the CUDA-capable OpenMPI is a
>>>>> factor:
>>>>> ./configure --with-debugging=0 --with-cmake=true   --with-mpi=true
>>>>>  --with-mpi-dir=/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support --with-fc=0
>>>>>   --with-cuda=1
>>>>> cuda:
>>>>>   Version:    11.7
>>>>>   Includes:   -I/path/to/cuda11.7/toolkit/11.7.1/include
>>>>>   Libraries:  -Wl,-rpath,/path/to/cuda11.7/toolkit/11.7.1/lib64
>>>>> -L/cm/shared/apps/cuda11.7/toolkit/11.7.1/lib64
>>>>> -L/path/to/cuda11.7/toolkit/11.7.1/lib64/stubs -lcudart -lnvToolsExt
>>>>> -lcufft -lcublas -lcusparse -lcusolver -lcurand -lcuda
>>>>>   CUDA SM 75
>>>>>   CUDA underlying compiler:
>>>>> CUDA_CXX="/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/bin"/mpicxx
>>>>>   CUDA underlying compiler flags: CUDA_CXXFLAGS=
>>>>>   CUDA underlying linker libraries: CUDA_CXXLIBS=
>>>>>  Configure stage complete. Now build PETSc libraries with:
>>>>>    make PETSC_DIR=/path/to/petsc PETSC_ARCH=arch-linux-c-opt all
>>>>> C++ compiler version: g++ (GCC) 10.2.0
>>>>> Using C++ compiler to compile PETSc
>>>>> Using C/C++ linker:
>>>>> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/bin/mpicxx
>>>>> Using C/C++ flags: -Wall -Wwrite-strings -Wno-strict-aliasing
>>>>> -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector
>>>>> -fvisibility=hidden -g -O0
>>>>> Using system modules:
>>>>> shared:slurm/20.02.6:DefaultModules:openmpi/gcc/64/4.1.1_cuda_11.0.3_aware:gdal/3.3.0:cmake/3.22.1:cuda11.7/toolkit/11.7.1:openblas/dynamic/0.3.7:gcc/10.2.0
>>>>> Using mpi.h: # 1
>>>>> "/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/include/mpi.h" 1
>>>>> Using libraries: -Wl,-rpath,/path/to/petsc/arch-linux-cxx-debug/lib
>>>>> -L/path/to/petsc/arch-linux-cxx-debug/lib -lpetsc -lopenblas -lm -lX11
>>>>> -lquadmath -lstdc++ -ldl
>>>>> Using mpiexec: mpiexec -mca orte_base_help_aggregate 0  -mca pml ucx
>>>>> --mca btl '^openib'
>>>>> Using MAKE: /path/to/petsc/arch-linux-cxx-debug/bin/make
>>>>> Using MAKEFLAGS: -j24 -l48.0  --no-print-directory -- MPIEXEC=mpiexec\
>>>>> -mca\ orte_base_help_aggregate\ 0\ \ -mca\ pml\ ucx\ --mca\ btl\ '^openib'
>>>>> PETSC_ARCH=arch-linux-cxx-debug PETSC_DIR=/path/to/petsc
>>>>> make[3]: Nothing to be done for 'libs'.
>>>>> Now to check if the libraries are working do:
>>>>> make PETSC_DIR=/path/to/petsc PETSC_ARCH=arch-linux-cxx-debug check
>>>>> [me at xxx petsc]$ make PETSC_DIR=/path/to/petsc
>>>>> PETSC_ARCH=arch-linux-cxx-debug MPIEXEC="mpiexec -mca
>>>>> orte_base_help_aggregate 0  -mca pml ucx --mca btl '^openib'" check
>>>>> Running check examples to verify correct installation
>>>>> Using PETSC_DIR=/path/to/petsc and PETSC_ARCH=arch-linux-cxx-debug
>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>> process
>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>> processes
>>>>> ./bandwidthTest
>>>>> [CUDA Bandwidth Test] - Starting...
>>>>> Running on...
>>>>>  Device 0: Quadro RTX 8000
>>>>>  Quick Mode
>>>>>  Host to Device Bandwidth, 1 Device(s)
>>>>>  PINNED Memory Transfers
>>>>>    Transfer Size (Bytes) Bandwidth(GB/s)
>>>>>    32000000 12.3
>>>>>  Device to Host Bandwidth, 1 Device(s)
>>>>>    32000000 13.2
>>>>>  Device to Device Bandwidth, 1 Device(s)
>>>>>    32000000 466.2
>>>>> Result = PASS
>>>>> On Sat, Oct 8, 2022 at 7:56 PM Barry Smith <bsmith at petsc.dev> wrote:
>>>>>>   True, but when users send reports back to us they will never have
>>>>>> used the VERBOSE=1 option, so it requires one more round trip of email to
>>>>>> get this additional information.
>>>>>> > On Oct 8, 2022, at 6:48 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>>>> > Barry Smith <bsmith at petsc.dev> writes:
>>>>>> >>   I hate these kinds of make rules that hide what the compiler is
>>>>>> doing (in the name of having less output, I guess) it makes it difficult to
>>>>>> figure out what is going wrong.
>>>>>> > You can make VERBOSE=1 with CMake-generated makefiles.
>>>>>> Anyways, either some of the MPI libraries are missing from the link
>>>>>> line or they are in the wrong order and thus it is not able to search them
>>>>>> properly. Here is a bunch of discussions on why that error message can
>>>>>> appear
>>>>>> https://stackoverflow.com/questions/19901934/libpthread-so-0-error-adding-symbols-dso-missing-from-command-line
>>>>> Still same but more noise and I have been using the suggestion of
>>>>> LDFLAGS="-Wl,--copy-dt-needed-entries" along with make:
>>>>> Makefiles" /path/to/WTM /path/to/WTM /path/to/WTM/build /path/to/WTM/build
>>>>> /path/to/WTM/build/CMakeFiles/wtm.x.dir/DependInfo.cmake --color=
>>>>> make  -f CMakeFiles/wtm.x.dir/build.make CMakeFiles/wtm.x.dir/build
>>>>> [ 66%] Building CXX object CMakeFiles/wtm.x.dir/src/WTM.cpp.o
>>>>>  -I/path/to/WTM/common/richdem/include -I/path/to/gdal-3.3.0/include
>>>>> /path/to/petsc/arch-linux-cxx-debug/include -isystem /path/to/petsc/include
>>>>> -isystem -O3 -g -Wall -Wextra -pedantic -Wshadow -Wfloat-conversion -Wall
>>>>> -Wextra -pedantic -Wshadow -DRICHDEM_GIT_HASH=\"xxx\"
>>>>> -DRICHDEM_COMPILE_TIME=\"2022-10-09T02:21:11Z\" -DUSEGDAL -Xpreprocessor
>>>>> -fopenmp
>>>>> -I/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/include -std=gnu++2a -MD
>>>>> -MT CMakeFiles/wtm.x.dir/src/WTM.cpp.o -MF
>>>>> CMakeFiles/wtm.x.dir/src/WTM.cpp.o.d -o CMakeFiles/wtm.x.dir/src/WTM.cpp.o
>>>>> -c /path/to/WTM/src/WTM.cpp
>>>>> c++: warning:
>>>>> [ 70%] Linking CXX executable wtm.x
>>>>> cmake_link_script CMakeFiles/wtm.x.dir/link.txt --verbose=1
>>>>>  -Wl,-rpath,/path/to/WTM/build/common/richdem:/path/to/gdal-3.3.0/lib:/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib:/path/to/petsc/arch-linux-cxx-debug/lib
>>>>> libwtm.a common/richdem/librichdem.so /path/to/gdal-3.3.0/lib/libgdal.so
>>>>> to symbol 'ompi_mpi_comm_self'
>>>>> make[2]: *** [CMakeFiles/wtm.x.dir/build.make:103: wtm.x] Error 1
>>>>> make[1]: *** [CMakeFiles/Makefile2:225: CMakeFiles/wtm.x.dir/all]
>>>>> Error 2
>>>>> Anything stick out?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221010/aa76622f/attachment-0001.html>
