[petsc-users] suppress CUDA warning & choose MCA parameter for mpirun during make PETSC_ARCH=arch-linux-c-debug check
Rob Kudyba
rk3199 at columbia.edu
Sun Oct 9 21:28:42 CDT 2022
I did have -DMPI_CXX_COMPILER set, so I added -DCMAKE_C_COMPILER and now
get these errors:
[ 25%] Linking CXX shared library librichdem.so
/lib/../lib64/crt1.o: In function `_start':
(.text+0x24): undefined reference to `main'
CMakeFiles/richdem.dir/src/random.cpp.o: In function
`richdem::rand_engine()':
random.cpp:(.text+0x45): undefined reference to `omp_get_thread_num'
`richdem::seed_rand(unsigned long)':
random.cpp:(.text+0xb6): undefined reference to `GOMP_parallel'
`richdem::uniform_rand_int(int, int)':
random.cpp:(.text+0x10c): undefined reference to `omp_get_thread_num'
`richdem::uniform_rand_real(double, double)':
random.cpp:(.text+0x1cb): undefined reference to `omp_get_thread_num'
`richdem::normal_rand(double, double)':
random.cpp:(.text+0x29e): undefined reference to `omp_get_thread_num'
`richdem::seed_rand(unsigned long) [clone ._omp_fn.0]':
random.cpp:(.text+0x4a3): undefined reference to `GOMP_critical_start'
random.cpp:(.text+0x4b1): undefined reference to `GOMP_critical_end'
random.cpp:(.text+0x4c3): undefined reference to `omp_get_thread_num'
/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libompitrace.so.40.30.0:
undefined reference to `PMPI_Comm_rank'
undefined reference to `PMPI_Get_address'
undefined reference to `PMPI_Comm_get_name'
undefined reference to `PMPI_Add_error_string'
undefined reference to `PMPI_Type_get_name'
undefined reference to `PMPI_Abort'
undefined reference to `PMPI_Alloc_mem'
undefined reference to `PMPI_Isend'
undefined reference to `PMPI_Barrier'
undefined reference to `PMPI_Allgather'
undefined reference to `PMPI_Reduce'
undefined reference to `PMPI_Send'
undefined reference to `PMPI_Init'
undefined reference to `PMPI_Type_size'
undefined reference to `PMPI_Accumulate'
undefined reference to `PMPI_Add_error_class'
undefined reference to `PMPI_Finalize'
undefined reference to `PMPI_Allgatherv'
undefined reference to `PMPI_Bcast'
undefined reference to `PMPI_Recv'
undefined reference to `PMPI_Request_free'
undefined reference to `PMPI_Allreduce'
undefined reference to `ompi_mpi_comm_world'
undefined reference to `PMPI_Sendrecv'
undefined reference to `PMPI_Add_error_code'
undefined reference to `PMPI_Win_get_name'
collect2: error: ld returned 1 exit status
make[2]: *** [common/richdem/CMakeFiles/richdem.dir/build.make:163:
common/richdem/librichdem.so] Error 1
make[1]: *** [CMakeFiles/Makefile2:306:
common/richdem/CMakeFiles/richdem.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
I took a guess at using
-DOpenMP_libomp_LIBRARY="/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libompitrace.so.40.30.0"
as
as otherwise I'd get:
CMake Error at
/path/to/cmake/cmake-3.22.1-linux-x86_64/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:230
(message):
Could NOT find OpenMP_CXX (missing: OpenMP_libomp_LIBRARY
OpenMP_libomp_LIBRARY) (found version "4.5")
So perhaps that's the real problem?
On Sun, Oct 9, 2022 at 9:31 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> In the last link step to generate the executable
> /cm/local/apps/gcc/10.2.0/bin/c++ -isystem -O3 -g -Wall -Wextra -pedantic
> -Wshadow CMakeFiles/wtm.x.dir/src/WTM.cpp.o -o wtm.x
> -Wl,-rpath,/path/to/WTM/build/common/richdem:/path/to/
> gdal-3.3.0/lib:/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_
> support/lib:/path/to/petsc/arch-linux-cxx-debug/lib libwtm.a
> common/richdem/librichdem.so /path/to/gdal-3.3.0/lib/libgdal.so
> common/fmt/libfmt.a /path/to/petsc/arch-linux-cxx-debug/lib/libpetsc.so
> I did not find -lmpi to link in the mpi library. You can try to use cmake
> -DCMAKE_C_COMPILER=/path/to/mpicc -DCMAKE_CXX_COMPILER=/path/to/mpicxx to
> build your code
> On Sat, Oct 8, 2022 at 9:32 PM Rob Kudyba <rk3199 at columbia.edu> wrote:
>> Perhaps we can back one step:
>>> Use your mpicc to build a "hello world" mpi test, then run it on a
>>> compute node (with GPU) to see if it works.
>>> If no, then your MPI environment has problems;
>>> If yes, then use it to build petsc (turn on petsc's gpu support,
>>> --with-cuda --with-cudac=nvcc), and then your code.
>>> --Junchao Zhang
>> OK tried this just to eliminate that the CUDA-capable OpenMPI is a factor:
>> ./configure --with-debugging=0 --with-cmake=true --with-mpi=true
>> --with-mpi-dir=/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support --with-fc=0
>> --with-cuda=1
>> cuda:
>> Version: 11.7
>> Includes: -I/path/to/cuda11.7/toolkit/11.7.1/include
>> Libraries: -Wl,-rpath,/path/to/cuda11.7/toolkit/11.7.1/lib64
>> -L/cm/shared/apps/cuda11.7/toolkit/11.7.1/lib64
>> -L/path/to/cuda11.7/toolkit/11.7.1/lib64/stubs -lcudart -lnvToolsExt
>> -lcufft -lcublas -lcusparse -lcusolver -lcurand -lcuda
>> CUDA SM 75
>> CUDA underlying compiler:
>> CUDA_CXX="/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/bin"/mpicxx
>> CUDA underlying compiler flags: CUDA_CXXFLAGS=
>> CUDA underlying linker libraries: CUDA_CXXLIBS=
>> Configure stage complete. Now build PETSc libraries with:
>> make PETSC_DIR=/path/to/petsc PETSC_ARCH=arch-linux-c-opt all
>> C++ compiler version: g++ (GCC) 10.2.0
>> Using C++ compiler to compile PETSc
>> Using C/C++ linker:
>> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/bin/mpicxx
>> Using C/C++ flags: -Wall -Wwrite-strings -Wno-strict-aliasing
>> -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector
>> -fvisibility=hidden -g -O0
>> Using system modules:
>> shared:slurm/20.02.6:DefaultModules:openmpi/gcc/64/4.1.1_cuda_11.0.3_aware:gdal/3.3.0:cmake/3.22.1:cuda11.7/toolkit/11.7.1:openblas/dynamic/0.3.7:gcc/10.2.0
>> Using mpi.h: # 1
>> "/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/include/mpi.h" 1
>> Using libraries: -Wl,-rpath,/path/to/petsc/arch-linux-cxx-debug/lib
>> -L/path/to/petsc/arch-linux-cxx-debug/lib -lpetsc -lopenblas -lm -lX11
>> -lquadmath -lstdc++ -ldl
>> Using mpiexec: mpiexec -mca orte_base_help_aggregate 0 -mca pml ucx
>> --mca btl '^openib'
>> Using MAKE: /path/to/petsc/arch-linux-cxx-debug/bin/make
>> Using MAKEFLAGS: -j24 -l48.0 --no-print-directory -- MPIEXEC=mpiexec\
>> -mca\ orte_base_help_aggregate\ 0\ \ -mca\ pml\ ucx\ --mca\ btl\ '^openib'
>> PETSC_ARCH=arch-linux-cxx-debug PETSC_DIR=/path/to/petsc
>> make[3]: Nothing to be done for 'libs'.
>> Now to check if the libraries are working do:
>> make PETSC_DIR=/path/to/petsc PETSC_ARCH=arch-linux-cxx-debug check
>> [me at xxx petsc]$ make PETSC_DIR=/path/to/petsc
>> PETSC_ARCH=arch-linux-cxx-debug MPIEXEC="mpiexec -mca
>> orte_base_help_aggregate 0 -mca pml ucx --mca btl '^openib'" check
>> Running check examples to verify correct installation
>> Using PETSC_DIR=/path/to/petsc and PETSC_ARCH=arch-linux-cxx-debug
>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>> processes
>> ./bandwidthTest
>> [CUDA Bandwidth Test] - Starting...
>> Running on...
>> Device 0: Quadro RTX 8000
>> Quick Mode
>> Host to Device Bandwidth, 1 Device(s)
>> PINNED Memory Transfers
>> Transfer Size (Bytes) Bandwidth(GB/s)
>> 32000000 12.3
>> Device to Host Bandwidth, 1 Device(s)
>> 32000000 13.2
>> Device to Device Bandwidth, 1 Device(s)
>> 32000000 466.2
>> Result = PASS
>> On Sat, Oct 8, 2022 at 7:56 PM Barry Smith <bsmith at petsc.dev> wrote:
>>> True, but when users send reports back to us they will never have used
>>> the VERBOSE=1 option, so it requires one more round trip of email to get
>>> this additional information.
>>> > On Oct 8, 2022, at 6:48 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> > Barry Smith <bsmith at petsc.dev> writes:
>>> >> I hate these kinds of make rules that hide what the compiler is
>>> doing (in the name of having less output, I guess) it makes it difficult to
>>> figure out what is going wrong.
>>> > You can make VERBOSE=1 with CMake-generated makefiles.
>>> Anyways, either some of the MPI libraries are missing from the link line
>>> or they are in the wrong order and thus it is not able to search them
>>> properly. Here is a bunch of discussions on why that error message can
>>> appear
>>> https://stackoverflow.com/questions/19901934/libpthread-so-0-error-adding-symbols-dso-missing-from-command-line
>> Still same but more noise and I have been using the suggestion of
>> LDFLAGS="-Wl,--copy-dt-needed-entries" along with make:
>> make[2]: Entering directory '/path/to/WTM/build'
>> cd /path/to/WTM/build &&
>> /path/to/cmake/cmake-3.22.1-linux-x86_64/bin/cmake -E cmake_depends "Unix
>> Makefiles" /path/to/WTM /path/to/WTM /path/to/WTM/build /path/to/WTM/build
>> /path/to/WTM/build/CMakeFiles/wtm.x.dir/DependInfo.cmake --color=
>> make[2]: Leaving directory '/path/to/WTM/build'
>> make -f CMakeFiles/wtm.x.dir/build.make CMakeFiles/wtm.x.dir/build
>> [ 66%] Building CXX object CMakeFiles/wtm.x.dir/src/WTM.cpp.o
>> /cm/local/apps/gcc/10.2.0/bin/c++ -I/path/to/WTM/common/richdem/include
>> -I/path/to/gdal-3.3.0/include -I/path/to/WTM/common/fmt/include -isystem
>> /path/to/petsc/arch-linux-cxx-debug/include -isystem /path/to/petsc/include
>> -isystem -O3 -g -Wall -Wextra -pedantic -Wshadow -Wfloat-conversion -Wall
>> -Wextra -pedantic -Wshadow -DRICHDEM_GIT_HASH=\"xxx\"
>> -DRICHDEM_COMPILE_TIME=\"2022-10-09T02:21:11Z\" -DUSEGDAL -Xpreprocessor
>> -fopenmp
>> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libmpi.so.40.30.1
>> -I/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/include -std=gnu++2a -MD
>> -MT CMakeFiles/wtm.x.dir/src/WTM.cpp.o -MF
>> CMakeFiles/wtm.x.dir/src/WTM.cpp.o.d -o CMakeFiles/wtm.x.dir/src/WTM.cpp.o
>> -c /path/to/WTM/src/WTM.cpp
>> c++: warning:
>> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libmpi.so.40.30.1:
>> linker input file unused because linking not done
>> [ 70%] Linking CXX executable wtm.x
>> /path/to/cmake/cmake-3.22.1-linux-x86_64/bin/cmake -E cmake_link_script
>> CMakeFiles/wtm.x.dir/link.txt --verbose=1
>> -Wl,-rpath,/path/to/WTM/build/common/richdem:/path/to/gdal-3.3.0/lib:/path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib:/path/to/petsc/arch-linux-cxx-debug/lib
>> libwtm.a common/richdem/librichdem.so /path/to/gdal-3.3.0/lib/libgdal.so
>> /usr/bin/ld: CMakeFiles/wtm.x.dir/src/WTM.cpp.o: undefined reference to
>> symbol 'ompi_mpi_comm_self'
>> /path/to/openmpi-4.1.1_ucx_cuda_11.0.3_support/lib/libmpi.so.40: error
>> adding symbols: DSO missing from command line
>> make[2]: *** [CMakeFiles/wtm.x.dir/build.make:103: wtm.x] Error 1
>> make[1]: *** [CMakeFiles/Makefile2:225: CMakeFiles/wtm.x.dir/all] Error 2
>> make[1]: Leaving directory '/path/to/WTM/build'
>> Anything stick out?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221009/f0afc828/attachment-0001.html>
