[petsc-users] Slepc, shell matrix, parallel, halo exchange
Sun Oct 9 07:11:35 CDT 2022
On Fri, Oct 7, 2022 at 5:48 PM feng wang <snailsoar at hotmail.com> wrote:
> Hi Mat,
> I've tried the suggested approach. The halo cells are not exchanged
> somehow.  Below is how I do it, have I missed anything?
> I create a ghost vector *petsc_dcsv* and it is a data member of the class
> cFdDomain, which is a context of the shell matrix.
> *   PetscCall(VecCreateGhostBlock(*A_COMM_WORLD, blocksize,
> blocksize*nlocal, PETSC_DECIDE ,nghost, ighost, &petsc_dcsv));*
> blocksize and nv have the same value. nlocal is number of local cells and
> nghost is number of halo cells. ighost contains the ghost cell index.
> Below is how I compute a matrix-vector product with a shell matrix
> *   PetscErrorCode cFdDomain::mymult_slepc(Mat m ,Vec x, Vec y)*
> *      void *ctx;*
> *      cFdDomain *myctx;*
> *      PetscErrorCode ierr;*
> *      MatShellGetContext(m, &ctx);*
> *      myctx = (cFdDomain*)ctx;*
> *//matrix-vector product*
> *      ierr = myctx->myfunc(x, y); CHKERRQ(ierr);*
> *      ierr = 0;*
> *      return ierr;*
> *  PetscErrorCode cFdDomain::myfunc(Vec in, Vec out)*
> *//some declaration *
> *      ierr = VecGetArray(petsc_dcsv,&array_g); CHKERRQ(ierr);*
> *      ierr = VecGetArrayRead(in,    &array);   CHKERRQ(ierr);*
> *      //assign in to petsc_dcsv, only local cells*
> *      for(iv=0; iv<nv; iv++)*
> *         for(iq=0; iq<nlocal; iq++)*
> *            array_g[iv+nv*iq] = array[iv + nv*iq];*
> *      ierr = VecRestoreArray(petsc_dcsv,&array_g); CHKERRQ(ierr);*
> *      ierr = VecRestoreArrayRead(in,     &array);   CHKERRQ(ierr);*
> *      //update halo cells?*
> *      PetscCall(VecGhostUpdateBegin(petsc_dcsv, INSERT_VALUES,
> SCATTER_FORWARD));*
> *      PetscCall(VecGhostUpdateEnd(petsc_dcsv, INSERT_VALUES,
> SCATTER_FORWARD));*
> *      PetscCall(VecGhostGetLocalForm(petsc_dcsv,&veclocal));*
> *//read in v*
> *      ierr = VecGetArray(veclocal,&array_ghost); CHKERRQ(ierr);*
> *            jq = ilocal[iq];*
> *            dq[iv][jq] = array_ghost[iv + nv*iq];*
> *         for(iq=nlocal; iq<nlocal+nghost; iq++)*
> *            jq = ighost_local[iq-nlocal];*
> *      ierr = VecRestoreArray(veclocal,&array_ghost); CHKERRQ(ierr);*
> *      //some computations *
> *      PetscCall(VecGhostRestoreLocalForm(petsc_dcsv,&veclocal)); *
> so I fill the local part of the ghost vector *petsc_dcsv* for each rank
> and then call ghost update, and think this will update the halo cells. it
> seems not doing that.
I can only think you are misinterpreting the result. There are many
examples, such
  src/vec/tutorials/ex9.c (and ex9f.F)
I would start there and try to change that into the communication you want,
since it definitely works. I cannot
see a problem with the code snippet above.
      Matt
> Thanks,
> Feng
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* 21 September 2022 14:36
> *To:* feng wang <snailsoar at hotmail.com>
> *Cc:* Jose E. Roman <jroman at dsic.upv.es>; petsc-users at mcs.anl.gov <
> petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Slepc, shell matrix, parallel, halo exchange
> On Wed, Sep 21, 2022 at 10:35 AM feng wang <snailsoar at hotmail.com> wrote:
> Hi Jose,
> For your 2nd suggestion on halo exchange, I get the idea and roughly know
> how to do it, but there are some implementation details which I am not
> quite sure.
> If I understand it correctly, in MatMult(Mat m ,Vec x, Vec y), Vec *x* is
> a normal parallel vector and it does not contain halo values. Suppose I
> create an auxiliary ghost vector * x_g*, then I assign the values of *x*
> to *x_g*. The values of the halo for each partition will not be assigned
> at this stage.
> But If I call VecGhostUpdateBegin/End(*x_g*, INSERT_VALUES,
> SCATTER_FORWARD), this will fill the values of the halo cells of *x_g *for
> each partition. Then *x_g* has local and halo cells assigned correctly
> and I can use *x_g* to do my computation. Is this what you mean?
> Yes
>   Matt
> Thanks,
> Feng
> *From:* Jose E. Roman <jroman at dsic.upv.es>
> *Sent:* 21 September 2022 13:07
> *Cc:* Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov <
> > El 21 sept 2022, a las 14:47, feng wang <snailsoar at hotmail.com>
> escribió:
> > Thanks Jose, I will try this and will come back to this thread if I have
> any issue.
> > Besides, for EPSGetEigenpair, I guess each rank gets its portion of the
> eigenvector, and I need to put them together afterwards?
> Eigenvectors are stored in parallel vectors, which are used in subsequent
> parallel computation in most applications. If for some reason you need to
> gather them in a single MPI process you can use e.g.
> VecScatterCreateToZero()
> > Thanks,
> > Feng
> > From: Jose E. Roman <jroman at dsic.upv.es>
> > Sent: 21 September 2022 12:34
> > To: feng wang <snailsoar at hotmail.com>
> > Cc: Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov <
> > Subject: Re: [petsc-users] Slepc, shell matrix, parallel, halo exchange
> > If you define the MATOP_CREATE_VECS operation in your shell matrix so
> that it creates a ghost vector, then all vectors within EPS will be ghost
> vectors, including those that are received as arguments of MatMult(). Not
> sure if this will work.
> > A simpler solution is that you store a ghost vector in the context of
> your shell matrix, and then in MatMult() you receive a regular parallel
> vector x, then update the ghost points using the auxiliary ghost vector, do
> the computation and store the result in the regular parallel vector y.
> > Jose
> > > El 21 sept 2022, a las 14:09, feng wang <snailsoar at hotmail.com>
> escribió:
> > > Thanks for your reply.
> > > For GMRES, I create a ghost vector and give it to KSPSolve. For Slepc,
> it only takes the shell matrix for EPSSetOperators. Suppose the shell
> matrix of the eigensolver defines MatMult(Mat m ,Vec x, Vec y), how does it
> know Vec x is  a ghost vector and how many ghost cells there are?
> > > Thanks,
> > > Feng
> > > From: Matthew Knepley <knepley at gmail.com>
> > > Sent: 21 September 2022 11:58
> > > Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> > > On Wed, Sep 21, 2022 at 7:41 AM feng wang <snailsoar at hotmail.com>
> wrote:
> > > Hello,
> > > I am using Slepc with a shell matrix. The sequential version seems
> working and now I am trying to make it run in parallel.
> > > The partition of the domain is done, I am not sure how to do the halo
> exchange in the shell matrix in Slepc. I have a parallel version of
> matrix-free GMRES in my code with Petsc. I was using VecCreateGhostBlock to
> create vector with ghost cells, and then used  VecGhostUpdateBegin/End for
> the halo exchange in the shell matrix, would this be the same for Slepc?
> > > That will be enough for the MatMult(). You would also have to use a
> SLEPc EPS that only needed MatMult().
> > >   Thanks,
> > >      Matt
> > > Thanks,
> > > Feng
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221009/80d43447/attachment.html>
