[petsc-users] code with TS throws error at the end
ashish bhole ashishbhole07 at gmail.com
Wed Oct 5 06:39:26 CDT 2022
Hi All,
I am writing a code in Fortran to solve a linear advection equation using
PETSc 3.18.0 (Vec and TS). It seems to work fine on my HP elitebook laptop
with Fedora 30 OS and GCC 9.3.1. It gives acceptable numerical solutions,
but throws the following error at the end, with as well as without parallel
computing. The same error also appears with the slightly older version I
tried: PETSc 3.14.0.
The error message gives a hint for error locations, but I am unable to
figure out what is wrong. I have attached a snippet for my TS usage lines.
I spent some time searching for similar error reports but it was not so
fruitful. So I am approaching the PETSc community for help understanding
this error.
Thank you.
[0]PETSC ERROR: PetscTrFreeDefault() called from VecDestroy_Seq() at
/home/abhole/lib/petsc-3.18.0/src/vec/vec/impls/seq/bvec2.c:753
[0]PETSC ERROR: Block [id=2154(800)] at address 0x2309ac0 is corrupted
(probably write past end of array)
[0]PETSC ERROR: Block allocated in VecCreate_Seq() at
/home/abhole/lib/petsc-3.18.0/src/vec/vec/impls/seq/bvec3.c:34
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Memory corruption: https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: Corrupted memory
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.18.0, Sep 30, 2022
[0]PETSC ERROR: ./exe on a arch-linux-c-debug named ischia by abhole Wed
Oct  5 13:06:27 2022
[0]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpicxx
--with-fc=mpif90 --download-fblaslapack --download-scalapack
--download-mumps --download-superlu --download-ptscotch
--with-metis-include=/user/abhole/home/lib/metis-5.1.0/include
--with-metis-lib=/user/abhole/home/lib/metis-5.1.0/lib/libmetis.a -lmetis
--with-parmetis-include=/user/abhole/home/lib/parmetis-4.0.3/include
--with-parmetis-lib=/user/abhole/home/lib/parmetis-4.0.3/lib/libparmetis.a
-lparmetis -lmetis
--with-hdf5-include=/user/abhole/home/lib/hdf5-1.8.18/include
--with-hdf5-lib=/user/abhole/home/lib/hdf5-1.8.18/lib64/libhdf5.a
--with-valgrind=1 --with-scalar-type=real --with-precision=double
[0]PETSC ERROR: #1 PetscTrFreeDefault() at
/home/abhole/lib/petsc-3.18.0/src/sys/memory/mtr.c:305
[0]PETSC ERROR: #2 VecDestroy_Seq() at
[0]PETSC ERROR: #3 VecDestroy() at
/home/abhole/lib/petsc-3.18.0/src/vec/vec/interface/vector.c:521
[0]PETSC ERROR: #4 VecDestroyVecs_Default() at
/home/abhole/lib/petsc-3.18.0/src/vec/vec/interface/vector.c:977
[0]PETSC ERROR: #5 VecDestroyVecs() at
/home/abhole/lib/petsc-3.18.0/src/vec/vec/interface/vector.c:606
[0]PETSC ERROR: #6 TSRKTableauReset() at
/home/abhole/lib/petsc-3.18.0/src/ts/impls/explicit/rk/rk.c:1102
[0]PETSC ERROR: #7 TSReset_RK() at
/home/abhole/lib/petsc-3.18.0/src/ts/impls/explicit/rk/rk.c:1109
[0]PETSC ERROR: #8 TSReset() at
/home/abhole/lib/petsc-3.18.0/src/ts/interface/ts.c:2644
[0]PETSC ERROR: #9 TSDestroy() at
/home/abhole/lib/petsc-3.18.0/src/ts/interface/ts.c:2706
[0]PETSC ERROR: #10 main.F90:159
-- With Regards
Ashish Bhole
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221005/c89bc183/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221005/c89bc183/attachment-0001.png>
