[petsc-users] How to use Intel OneApi mpi wrappers on Linux
Mark Adams
mfadams at lbl.gov
Mon Oct 3 06:19:54 CDT 2022
Hi Paolo,
You can use things like this in your configure file to set compilers and
options.
And you want to send us your configure.log file if it fails.
'--with-cc=gcc-11',
'--with-cxx=g++-11',
'--with-fc=gfortran-11',
'CFLAGS=-g',
'CXXFLAGS=-g',
'COPTFLAGS=-O0',
'CXXOPTFLAGS=-O0',
On Mon, Oct 3, 2022 at 5:43 AM Paolo Lampitella <paololampitella at hotmail.com>
wrote:
> Dear PETSc users and developers,
> as per the title, I recently installed the base and HPC Intel OneApi
> toolkits on a machine running Ubuntu 20.04.
> As you probably know, OneApi comes with the classical compilers (icc,
> icpc, ifort) and relative mpi wrappers (mpiicc, mpiicpc, mpiifort) as well
> as with the new LLVM based compilers (icx, icpx, ifx).
> My experience so far with PETSc on Linux has been without troubles using
> both gcc compilers and either Mpich or OpenMPI and Intel classical
> compilers and MPI.
> However, I have now troubles using the MPI wrappers of the new LLVM
> compilers as, in fact, there aren’t dedicated mpi wrappers for them.
> Instead, they can be used with certain flags for the classical wrappers:
> mpiicc -cc=icx
> mpiicpc -cxx=icpx
> mpiifort -fc=ifx
> The problem I have is that I have no idea how to pass them correctly to
> the configure and whatever comes after that.
> Admittedly, I am just starting to use the new compilers, so I have no clue
> how I would use them in other projects as well.
> I started with an alias in my .bash_aliases (which works for simple
> compilation tests from command line) but doesn’t with configure.
> I also tried adding the flags to the COPTFLAGS, CXXOPTFLAGS and FOPTFLAGS
> but didn’t work as well.
> Do you have any experience with the new Intel compilers and, in case,
> could you share hot to properly use them with MPI?
> Thanks
> Paolo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221003/63a0752d/attachment-0001.html>
