[petsc-users] About MatMumpsSetIcntl function
Pierre Jolivet
pierre at joliv.et
Wed Nov 30 09:02:50 CST 2022
> On 30 Nov 2022, at 3:54 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 30, 2022 at 9:31 AM 김성익 <ksi2443 at gmail.com <mailto:ksi2443 at gmail.com>> wrote:
>> After folloing the comment, ./app -pc_type lu -ksp_type preonly -ksp_monitor_true_residual -ksp_converged_reason -ksp_view -mat_mumps_icntl_7 5
> Okay, you can see that it is using METIS:
> INFOG(7) (ordering option effectively used after analysis): 5
> It looks like the server stuff was not seeing the option. Put it back in and send the output.
With a small twist, the option should now read -mpi_mat_mumps_icntl_7 5, cf. https://petsc.org/release/src/ksp/pc/impls/mpi/pcmpi.c.html#line126
Pierre
> Thanks,
> Matt
>> The outputs are as below.
>> 0 KSP none resid norm 2.000000000000e+00 true resid norm 4.241815708566e-16 ||r(i)||/||b|| 2.120907854283e-16
>> 1 KSP none resid norm 4.241815708566e-16 true resid norm 4.241815708566e-16 ||r(i)||/||b|| 2.120907854283e-16
>> Linear solve converged due to CONVERGED_ITS iterations 1
>> KSP Object: 1 MPI process
>> type: preonly
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> left preconditioning
>> using NONE norm type for convergence test
>> PC Object: 1 MPI process
>> type: lu
>> out-of-place factorization
>> tolerance for zero pivot 2.22045e-14
>> matrix ordering: external
>> factor fill ratio given 0., needed 0.
>> Factored matrix follows:
>> Mat Object: 1 MPI process
>> type: mumps
>> rows=24, cols=24
>> package used to perform factorization: mumps
>> total: nonzeros=576, allocated nonzeros=576
>> MUMPS run parameters:
>> Use -ksp_view ::ascii_info_detail to display information for all processes
>> RINFOG(1) (global estimated flops for the elimination after analysis): 8924.
>> RINFOG(2) (global estimated flops for the assembly after factorization): 0.
>> RINFOG(3) (global estimated flops for the elimination after factorization): 8924.
>> (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant): (0.,0.)*(2^0)
>> INFOG(3) (estimated real workspace for factors on all processors after analysis): 576
>> INFOG(4) (estimated integer workspace for factors on all processors after analysis): 68
>> INFOG(5) (estimated maximum front size in the complete tree): 24
>> INFOG(6) (number of nodes in the complete tree): 1
>> INFOG(8) (structural symmetry in percent of the permuted matrix after analysis): 100
>> INFOG(9) (total real/complex workspace to store the matrix factors after factorization): 576
>> INFOG(10) (total integer space store the matrix factors after factorization): 68
>> INFOG(11) (order of largest frontal matrix after factorization): 24
>> INFOG(12) (number of off-diagonal pivots): 0
>> INFOG(13) (number of delayed pivots after factorization): 0
>> INFOG(14) (number of memory compress after factorization): 0
>> INFOG(15) (number of steps of iterative refinement after solution): 0
>> INFOG(16) (estimated size (in MB) of all MUMPS internal data for factorization after analysis: value on the most memory consuming processor): 0
>> INFOG(17) (estimated size of all MUMPS internal data for factorization after analysis: sum over all processors): 0
>> INFOG(18) (size of all MUMPS internal data allocated during factorization: value on the most memory consuming processor): 0
>> INFOG(19) (size of all MUMPS internal data allocated during factorization: sum over all processors): 0
>> INFOG(20) (estimated number of entries in the factors): 576
>> INFOG(21) (size in MB of memory effectively used during factorization - value on the most memory consuming processor): 0
>> INFOG(22) (size in MB of memory effectively used during factorization - sum over all processors): 0
>> INFOG(23) (after analysis: value of ICNTL(6) effectively used): 0
>> INFOG(24) (after analysis: value of ICNTL(12) effectively used): 1
>> INFOG(25) (after factorization: number of pivots modified by static pivoting): 0
>> INFOG(28) (after factorization: number of null pivots encountered): 0
>> INFOG(29) (after factorization: effective number of entries in the factors (sum over all processors)): 576
>> INFOG(30, 31) (after solution: size in Mbytes of memory used during solution phase): 0, 0
>> INFOG(32) (after analysis: type of analysis done): 1
>> INFOG(33) (value used for ICNTL(8)): 7
>> INFOG(34) (exponent of the determinant if determinant is requested): 0
>> INFOG(35) (after factorization: number of entries taking into account BLR factor compression - sum over all processors): 576
>> INFOG(36) (after analysis: estimated size of all MUMPS internal data for running BLR in-core - value on the most memory consuming processor): 0
>> INFOG(37) (after analysis: estimated size of all MUMPS internal data for running BLR in-core - sum over all processors): 0
>> INFOG(38) (after analysis: estimated size of all MUMPS internal data for running BLR out-of-core - value on the most memory consuming processor): 0
>> INFOG(39) (after analysis: estimated size of all MUMPS internal data for running BLR out-of-core - sum over all processors): 0
>> linear system matrix = precond matrix:
>> type: seqaij
>> rows=24, cols=24
>> total: nonzeros=576, allocated nonzeros=840
>> total number of mallocs used during MatSetValues calls=48
>> using I-node routines: found 5 nodes, limit used is 5
>> 2022년 11월 30일 (수) 오후 11:26, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>님이 작성:
>>> On Wed, Nov 30, 2022 at 9:20 AM 김성익 <ksi2443 at gmail.com <mailto:ksi2443 at gmail.com>> wrote:
>>>> In my code there are below.
>>>> PetscCall(KSPCreate(PETSC_COMM_WORLD, &ksp));
>>>> PetscCall(KSPSetOperators(ksp, xGK, xGK));
>>>> PetscCall(KSPGetPC(ksp, &pc));
>>>> PetscCall(PCSetType(pc, PCLU));
>>>> PetscCall(PCFactorSetMatSolverType(pc, MATSOLVERMUMPS));
>>>> PetscCall(KSPSetFromOptions(ksp));
>>>> and my runtime options are as below.
>>>> mpirun -np 3 ./app -mpi_linear_solver_server -mpi_linear_solver_server_view -pc_type mpi -ksp_type preonly -mpi_ksp_monitor -mpi_ksp_converged_reason -mpi_pc_type lu -pc_mpi_always_use_server -mat_mumps_icntl_7 5
>>> 1) Get rid of the all server stuff until we see what is wrong with your code
>>> 2) Always run in serial until it works
>>> Send the output so we can see what the solver is.
>>> Thanks,
>>> Matt
>>>> 2022년 11월 30일 (수) 오후 11:16, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>님이 작성:
>>>>> On Wed, Nov 30, 2022 at 9:10 AM 김성익 <ksi2443 at gmail.com <mailto:ksi2443 at gmail.com>> wrote:
>>>>>> When I adopt icntl by using option, the outputs are as below.
>>>>>> WARNING! There are options you set that were not used!
>>>>>> WARNING! could be spelling mistake, etc!
>>>>>> There is one unused database option. It is:
>>>>>> Option left: name:-mat_mumps_icntl_7 value: 5
>>>>>> Is it work??
>>>>> Are you calling KSPSetFromOptions() after the PC is created?
>>>>> -pc_type lu -pc_factor_mat_solver_type mumps -mat_mumps_icntl_7 3
>>>>> Thanks,
>>>>> Matt
>>>>>> Thanks,
>>>>>> Hyung Kim
>>>>>> 2022년 11월 30일 (수) 오후 11:04, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>님이 작성:
>>>>>>> On Wed, Nov 30, 2022 at 8:58 AM 김성익 <ksi2443 at gmail.com <mailto:ksi2443 at gmail.com>> wrote:
>>>>>>>> I'm working on FEM.
>>>>>>>> When I used mumps alone, I fount it efficient to use mumps with metis.
>>>>>>>> So my purpose is using MUMPSsolver with METIS.
>>>>>>>> I tried to set metis (by icntl_7 : 5) after global matrix assembly and just before kspsolve.
>>>>>>>> However there is error because of 'pcfactorgetmatrix' and 'matmumpsseticntl'.
>>>>>>>> How can I fix this?
>>>>>>> Give the Icntrl as an option.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Hyung Kim
>>>>>>>> 2022년 11월 30일 (수) 오후 10:44, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>>님이 작성:
>>>>>>>>> On Wed, Nov 30, 2022 at 8:40 AM 김성익 <ksi2443 at gmail.com <mailto:ksi2443 at gmail.com>> wrote:
>>>>>>>>>> Following your comments,
>>>>>>>>>> After matrix assembly end,
>>>>>>>>>> PetscCall(KSPGetPC(ksp,&pc));
>>>>>>>>>> PetscCall(KSPSetUp(ksp));
>>>>>>>>>> PetscCall(PCFactorGetMatrix(pc,&xGK));
>>>>>>>>>> However there is another error as below.
>>>>>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>>>>>> [0]PETSC ERROR: Not for factored matrix
>>>>>>>>> The error message is telling you that you cannot alter values in the factored matrix. This is because
>>>>>>>>> the direct solvers use their own internal storage formats which we cannot alter, and you should probably
>>>>>>>>> not alter either.
>>>>>>>>> What are you trying to do?
>>>>>>>>> Thanks,
>>>>>>>>> Matt
>>>>>>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>>>>>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443 Wed Nov 30 05:37:52 2022
>>>>>>>>>> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack -download-parmetis -download-metis
>>>>>>>>>> [0]PETSC ERROR: #1 MatZeroEntries() at /home/ksi2443/petsc/src/mat/interface/matrix.c:6024
>>>>>>>>>> [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:339
>>>>>>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>>>>>>> How can I fix this?
>>>>>>>>>> Thanks,
>>>>>>>>>> Hyung Kim
>>>>>>>>>> 2022년 11월 30일 (수) 오후 4:18, Jose E. Roman <jroman at dsic.upv.es <mailto:jroman at dsic.upv.es>>님이 작성:
>>>>>>>>>>> You have to call PCFactorGetMatrix() first. See any of the examples that use MatMumpsSetIcntl(), for instance https://petsc.org/release/src/ksp/ksp/tutorials/ex52.c.html
>>>>>>>>>>> Jose
>>>>>>>>>>> > El 30 nov 2022, a las 6:52, 김성익 <ksi2443 at gmail.com <mailto:ksi2443 at gmail.com>> escribió:
>>>>>>>>>>> > Hello,
>>>>>>>>>>> > I tried to adopt METIS option in MUMPS by using
>>>>>>>>>>> > ' PetscCall(MatMumpsSetIcntl(Mat, 7, 5));'
>>>>>>>>>>> > However, there is an error as follows
>>>>>>>>>>> > [0]PETSC ERROR: Only for factored matrix
>>>>>>>>>>> > [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443 Tue Nov 29 21:12:41 2022
>>>>>>>>>>> > [0]PETSC ERROR: #1 MatMumpsSetIcntl() at /home/ksi2443/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:2478
>>>>>>>>>>> > [0]PETSC ERROR: #2 main() at /home/ksi2443/Downloads/coding/a1.c:149
>>>>>>>>>>> > How can I fix this error?
>>>>>>>>>>> > Thank you for your help.
>>>>>>>>>>> > Hyung Kim
>>>>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>>>>>>> -- Norbert Wiener
>>>>> -- Norbert Wiener
>>> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221130/0f517ddc/attachment-0001.html>
