[petsc-users] Petsc Section in DMPlex
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Sun Nov 27 21:21:43 CST 2022
Hi Petsc Users
I have a question about properly using PetscSection to assign state
variables to a DM. I have an existing DMPlex mesh distributed on 2
processors. My goal is to have state variables set to the cell centers. I
then want to call DMPlexDistribute, which I hope will balance the mesh
elements and hopefully transport the state variables to the hosting
processors as the cells are distributed to a different processor count or
simply just redistributing after doing mesh adaption.
Looking at the DMPlex User guide, I should be able to achieve this with a
single field section using SetDof and assigning the DOF to the points
corresponding to cells.
call DMPlexGetHeightStratum(dm,0,c0,c1,ierr)
call DMPlexGetChart(dm,p0,p1,ierr)
call PetscSectionCreate(PETSC_COMM_WORLD,section,ierr)
call PetscSectionSetNumFields(section,1,ierr) call
PetscSectionSetChart(section,p0,p1,ierr)
do i = c0, (c1-1)
call PetscSectionSetDof(section,i,nvar,ierr)
end do
call PetscSectionSetup(section,ierr)
call DMSetLocalSection(dm,section,ierr)
>From here, it looks like I can access and set the state vars using
call DMGetGlobalVector(dmplex,state,ierr)
call DMGetGlobalSection(dmplex,section,ierr)
call VecGetArrayF90(state,stateVec,ierr)
do i = c0, (c1-1)
call PetscSectionGetOffset(section,i,offset,ierr)
stateVec(offset:(offset+nvar))=state_i(:) !simplified assignment
end do
call VecRestoreArrayF90(state,stateVec,ierr)
call DMRestoreGlobalVector(dmplex,state,ierr)
To my understanding, I should be using Global vector since this is a pure
assignment operation and I don't need the ghost cells.
But the behavior I am seeing isn't exactly what I'd expect.
To be honest, I'm somewhat unclear on a few things
1) Should be using nvar fields with 1 DOF each or 1 field with nvar DOFs or
what the distinction between the two methods are?
2) Adding a print statement after the offset assignment I get (on rank 0 of
2)
cell 1 offset 0
cell 2 offset 18
cell 3 offset 36
which is expected and works but on rank 1 I get
cell 1 offset 9000
cell 2 offset 9018
cell 3 offset 9036
which isn't exactly what I would expect. Shouldn't the offsets reset at 0
for the next rank?
3) Does calling DMPlexDistribute also distribute the section data
associated with the DOF, based on the description in DMPlexDistribute it
looks like it should?
I'd appreciate any insight into the specifics of this usage. I expect I
have a misconception on the local vs global section. Thank you.
Sincerely
Nicholas
Ph.D. Candidate
Computational Aeroscience Lab
University of Michigan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221127/ba97e48e/attachment.html>
