[petsc-users] Petsc Fortran Memory stack trace
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Mon Nov 21 14:23:57 CST 2022
Thanks for the information, that clarifies quite a bit. Unfortunately I
probably have a number of memory issues that are colliding that I need to
clean up.
Thanks
On Mon, Nov 21, 2022 at 3:18 PM Barry Smith <bsmith at petsc.dev> wrote:
> My understanding of Fortran bounds checking is that before each array
> access in Fortran it checks to see if the index is valid for the array you
> are accessing; that is it is from start to end if you had declared the
> array as
> double precision, dimension (start:end) :: A
> It should also work if the array is a Fortran allocatable array or if you
> obtain the array from PETSc with VecGetArrayF90() and all its friends and
> relations.
> PETSc should not change the behavior above.
> Now if there is memory corruption (or some other error) somewhere else
> (like in PETSc or a more subtle problem in your code) then simply array out
> of bounds then yes you can get more complicated error messages that would
> usually include the PETSc stack trace.
> Instead of using valgrind you can also try running the PETSc program
> with -malloc_debug, this is sort of a poor person's version of valgrind but
> can sometimes provide more useful information than valgrind.
> When debugging always make sure PETSc was NOT ./configure with
> --with-debugging=0
> You can send specific error messages that are cryptic to
> petsc-maint at mcs.anl.gov and we may be able to help decipher them.
> Barry
> On Nov 21, 2022, at 2:16 PM, Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
> Hi Petsc users
> I'm working on an integration of Petsc into an existing fortran code. Most
> of my memory debugging is very primitive and is usually accomplished using
> the -check bounds option in the compiler. However with Petsc attached the
> stack trace becomes much more opaque compared to the original code. At
> least as far as I can tell the error becomes much harder to pin down (just
> pointing to libpetsc.so). Any assistance in getting more informative error
> messages or checks would be much appreciated.
> Sincerely
> Nicholas
> Ph.D. Candidate
> Computational Aeroscience Lab
> University of Michigan
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221121/1b75af64/attachment-0001.html>
