[petsc-users] PetscSF Fortran interface
Junchao Zhang junchao.zhang at gmail.com
Sat Nov 19 19:21:31 CST 2022
Hi, Nicholas,
  See this MR, https://gitlab.com/petsc/petsc/-/merge_requests/5860
  It is in testing, but you can try branch jczhang/add-petscsf-fortran to
see if it works for you.
  Thanks.
--Junchao Zhang
On Sat, Nov 19, 2022 at 4:16 PM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi Junchao
> Thanks. I was wondering if there is any update on this. I may write a
> small interface for those two routines myself in the interim but I'd
> appreciate any insight you have.
> Sincerely
> Nicholas
> On Wed, Nov 16, 2022 at 10:39 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Hi, Nicholas,
>>   I will have a look and get back to you.
>>   Thanks.
>> --Junchao Zhang
>> On Wed, Nov 16, 2022 at 9:27 PM Nicholas Arnold-Medabalimi <
>>> Hi Petsc Users
>>> I'm in the process of adding some Petsc for mesh management into an
>>> existing Fortran Solver. It has been relatively straightforward so far but
>>> I am running into an issue with using PetscSF routines. Some like the
>>> PetscSFGetGraph work no problem but a few of my routines require the use of
>>> PetscSFGetLeafRanks and PetscSFGetRootRanks and those don't seem to be in
>>> the fortran interface and I just get a linking error. I also don't seem to
>>> see a PetscSF file in the finclude. Any clarification or assistance would
>>> be appreciated.
>>> Sincerely
>>> Nicholas
>>> Ph.D. Candidate
>>> Computational Aeroscience Lab
>>> University of Michigan
> Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221119/1fac303d/attachment.html>
